Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Murray riding mower won't start
Battery good, gas and oil good. I turn key and hear a click sound but starter will not crank engine. I did this 5-6 times and it finally started but when I tried it again, nothing. Up until now, I have had no problems.
  • thomasdenig Jun 18, 2009
    Absolutely correct. The solenoid. Thank you for the help.
  • 376 Answers
Sounds like a defective starter solenoid.
Posted on Jun 18, 2009
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
Can my battery amps be causing my 2004 dodge status not to crank? Its abattery.
the cold cranking amps rating can be found on the battery sticker. the higher the number the better it is since amperage is the flow of current and will withstand longer battery use by all electrical and electronic components on a car. amperage of a battery is also affected by temperature so if the battery cca rating is low and you live in cold weather it will cause slow cranking. your starter is only as good as the voltage and amperage contained within your battery. so start with a good battery before condemning a starter.
Aug 29, 2014 | 2004 Dodge Stratus
Why Craftsman riding mower wont turn over & only makes click sound when turn key on??
1.try jumping the battery with your car battery. I have had same issue in the past with a brand new battery.
2. Try spraying starter fluid into the carb while cranking. If it starts or at least tries to start (assuming cranking is fixed), you have a fuel problem. Again, when I first tried to fire my Used mower, had to use starter fluid to get it to start the first time, but never since.
Jun 19, 2014 | Craftsman Garden
93 toy truck doesn;t want to crank all the time, I hear a click when I turn key to crank. A few times it will crank but a lot of times just a click. I continue turning key and eventually it turns over and...
Could mean that you're washing the cylinders could be ******* the starter. A dry start. If it's not that then replace the starter. A symptom could be poor fuel mileage or you need to change your oil. Use a Lucas additive for dry start if it's not the starter.
Nov 06, 2017 | 1993 Toyota Pickup
Car will not crank and the timing chain is fine
Well, that's good, but even if the chain was broke, the starter would still be tryiing to start the car. Since your starter wont crank the engine over, your start circuit has a malfunction. Possibly the starter went out, so you need to have that tested for a malfunction. A simple test of part of the circuit is to turn the key to on.. Now your dash warnimg lights (oil, alternator, and check engine light) should be on. Are they on, and your gauges working? If not you have lost power to the ignition switch, so check your battery connections. If the key switch turns the dash on, then turn key to start. Do you hear a click from the engine area? If not, have the starter checked. If you do hear a click, or several clicks, then power from the switch is causing that click, probably at the starter. Turn the headlights on and observe them. Are they bright? If not, charge the battery up. If they are bright, watch them while a helper turns the key to start. If the lights go dim in start, probably a bad starter. If the lights don't dim, it could be a bad connection somewhere, like the battery or starter. Good luck
Jun 27, 2012 | 1999 Buick Century
2005 Altima won't start, hear clicking sound coming from fuse box,key stuck in ingintion,won;t turn over,tried to jump start.
the clicking that you hear is coming from the starter relay. sounds like your ignition starter switch or ignition lock cylinder is bad.
May 30, 2012 | 2005 Nissan Altima
Replaced sparkplug, solenoid, and battery - riding mower still won't start
check for spark if none remove the harness from the engine and crank it if you then get spark check the safety switches
Apr 22, 2012 | Garden
I have a 96 pontiac grand am that doesnt start all the time
Starting Problem # 1: Engine Won't Crank At All
Scenario: You turn the key, but nothing happens: And by nothing, we mean there is no dash light, no sound, nada. The first thing you should do in this case is to pop the hood and check the battery. Either the battery is completely dead or there's a wiring problem in the starting system. Try jump-starting the battery. If that doesn't work, you'll probably have to call for assistance.
Scenario: When you turn the key, you hear a rapid clicking sound, and the dash lights dim. This is your classic low-battery symptom. Jump-starting the battery should get the engine to start.However, if you keep experiencing this problem, you could have a bad battery or alternator, or it could be some­thing as simple as a loose alternator belt. Take your car to a mechanic just as soon as you can.
Scenario: When you turn the key, the lights on the dash come on, but you don't hear anything. Make sure you have the shift selector all the way in park. Move it out of park and then back, or try starting it with the shifter in neutral. If your car has a manual transmission, make sure you have the clutch pressed all the way to the floor. If that doesn't help, you can try jump-starting the battery, but it probably won't work. There's a good chance your car has a bad starter or a problem in the starting circuit. That could mean a prob­lem in the ignition switch, neutral safety switch or starter sole­noid.
Scenario: The dash lights come on when you turn the key, and then go right out, and the engine doesn't crank when you turn the key to start, But, the lights slowly come back on when you release the key. This is another classic: the bad battery connection. When you turn the key to start, the starter pulls so much current that it breaks the connection. Then, when you release the key, the connection slowly comes back. The connection provides enough power to turn the dash lights on, but not enough to crank the starter. Cleaning and tightening the battery terminals may fix this prob­lem.
Scenario: When you turn the key, you hear a single, hard clunk. Turn the headlights on and try again. Do the lights dim slightly when you turn the key? If so, you probably have a bad starter or a seized engine. If the headlights don't dim at all, or just barely dim, there may be a connection problem between the starter solenoid and the starter itself.
Scenario: When you turn the key, you hear a loud, scraping or grinding sound like metal on metal. The starter drive is bad, or the ring gear on the flywheel damaged, or both. You may get the starter to engage if you try turning the key a couple of times, but let go of the key right away if you hear the noise again. If the car does start, you should drive it right over to local repair shop and have the problem fixed.
Starting Problem #2: Engine Cranks but It Won't Start
Scenario: The engine seems to crank normally, but the engine doesn't even sound as if it's trying to start. Is there gas in the tank? Gas gauges are notoriously inaccurate. If you have to move your head to one side to get the needle to move off empty, try adding some gas to the tank.
Scenario: When you first turn the key on, you don't hear the fuel pump run. In cars with electronic fuel injection, you should hear a light hum a few seconds from around the fuel tank. That's the electric fuel pump running. If you don't hear the fuel pump run for a couple seconds when you first turn the key on, try cranking the engine until the oil light goes out. That may start the pump running and allow the engine to start.
Scenario: The engine cranks normally, and it sounds like it wants to start, but it won't. You may have flooded the engine. Hold the gas floor and try again. (Let the gas pedal up when it finally starts). If it's raining out, the ignition system may be wet.
Scenario: The engine cranks unevenly in a repetitive-sounding pattern. You may have a bad timing chain or timing belt. Call a tow truck and have it towed to the repair shop.
Starting Problem # 3: Engine Starts but It Shuts Off
Scenario: The engine starts right up, but shuts off as soon as you release the key. This is the classic symptom of a bad ignition switch. A new switch should fix it.
Scenario: The engine starts and runs, but when you put the transmission in gear, the car lurches and the engine shuts off. The converter clutch in the transmission torque converter probably is engaging when it shouldn't. On some cars, you can bypass this by disconnecting the torque converter clutch solenoid; but unless you know which wire to pull, forget about it. Call for assistance.
Scenario: The engine starts and runs, but seems to idle slowly and stalls when you come to a stop. This probably is a fast idle problem. When the engine is cold, it's supposed to idle a little faster than normal to keep the engine running. You may be able to drive using two feet until the engine warms up: one on the gas to hold the idle up a little and the other for the brake. However, don't keep driving it this way. Take your car to your repair shop just as soon as you
Jul 21, 2011 | 1996 Pontiac Grand Am
98 Corolla will not start. Turn the key and I hear one click from the lower front of the engine. Not a series of clicks but one click. Is it the solenoid?
sounds like your starter has given all it got, and yea it is under intake manifold between engine and firewall. something to take in countn: check battery state of charge, spin engine by hand to make sure nothing is locked. this litlle engines like to burn oil and see so many run out off oil and engine locks. good luck
Mar 05, 2011 | 1998 Toyota Corolla
I have a 2002 dodge intrepid se 2.7 with 105012 miles. when i first replaced the battery with a new one,the car started,but i would hear a knocking under the hood.I drove it about 10 miles and i started to...
It sounds like the engine is seized due to oil starvation.
The starter if changed will still not turnover the engine.
The engine must be rebuilt or replaced with one without the oil starvation and seized bearings.
Sep 18, 2010 | 2002 Dodge Intrepid
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
673 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
