Question about GE Refrigerators
GE TFX24F Ice maker does not stop filling
I have an old GE that i put in my garage after we did some renovations. It worked fine when we moved it. It's been a few years but I just decided to hook up the water line to the fridge. I get it to fill and can get cold water but it fills the ice tray and then overflows. I don't have the old manual, but I suspect there must be a relay that stops the water to the ice maker when the tray fills or if the ice maker is ''off.'' Not sure if there is a relay that is bad, a bad valve, or the ice maker itself is bad. Any suggestions?
  • 3 Answers
Did you try pushing up the arm on the side of the ice cube tray
Posted on Aug 25, 2009
Replaced the defrost heater,defrost thermostat,worked good for about 3
If the icemaker refill solenoid does not close properly or stays open too long excess water enters freezer compartment and that will freeze over the ice making machine plus other areas of freezer. There is an adjustment on the ice maker to regulate the amount of water going in - locate the screw (behind front panel of maker) and turn counter clockwise to lessen time of fill operation). Problem is not with the GE
Sep 06, 2017 | GE GSH25JFR Side by Side Refrigerator
Hi, we just purchased an 5 year old GE profile refrigerator with full door/bottom freezer from a private party. It was working fine at his house. The refrigerator has a loud buzzing every 1/2 for a few...
The buzz is most likely coming from the water valve that feeds the ice maker. If the ice maker is not being used the buzz will continue unless the power is disconnected to the valve. It does not hurt anything but can be annoying.
If the ice maker does not have the shut off handle (arm) to lift then a solution would be to unplug the ice maker itself. If you look at the ice maker in the freezer it is usually held on by 3 screws to the side wall. If you remove these screws there will be a wire plug that you can unplug and remove the entire ice maker and free up room. With it disconnected the buzz will stop.
Apr 18, 2010 | GE Profile Stainless Bottom-Freezer...
GE Profile Refrig model PSC23SGRC ice maker stopped making ice. Water is ok, just stopped? Is this common? Its only 4 yrs old
Your model has an electronic ice maker part number Click Here=> WR30X10093 When the electronic ice maker fails you usually need to replace the complete ice maker. You can test the ice maker by filling the tray with tap water. If the water freezes aand then drops the ice then the water control on the back of your refrigerator is the reason. The water control valve is Click Here=> WR57X10032 Either way let me know your results, Thank You, Sea Breeze
Jan 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice maker doesnt stop making ice
Check with an identical unit to see how that one moves. Yours may be dislocated. The lever arm probably contacts small plastic parts in the timer that could be out of place. Ice makers aren't too tough to take out and check out in a more comfortable work location. Just put a towel to catch screws.
Apr 21, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker problems
If the ice bucket is over filling there may be a problem with the ice maker as this should stop making ice when the bucket is full. The ice in the bucket can freeze together just due to the weight of ice cubes . I suggest you check the ice within the bucket is all broken up and not frozen into big lumps
Aug 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE ice maker isn't working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
767676
Aug 08, 2008 | U-Line Refrigerator Ice Maker
Ice maker not working properly
could be the air damper. try adjusting air control for more air at icemaker.
May 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker just stopped making ice
As these ice makers cycle there is an arm that moves up while the ice is being freed from the ice maker. After the ice is dumped into the dispenser bin the arm continues a downward motion. If it encounters ice in the downward travel it shuts the ice maker off. If this arm is locked in the full up position the ice maker is manually shut off. Check this arm and make sure it is not locked in the up position.
May 15, 2008 | GE PSS26MGS Side by Side Refrigerator
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE ice maker
I carry this ice maker on my truck and they are supposed to come with a universal cup so it could be mounted either way. See if you can pull off the cup of the old one and switch it to the new one. If not have them send you another ice maker because that one is not right.
Nov 04, 2007 | Refrigerators
Refrigerators Logo
288 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
