Question about Honeywell CT3600 7 Day Electronic Programmable Thermostat Heater
Honeywell CT3600-AC not working
The AC is somehow not fully entering the house. It worked perfectly a month ago, and now my house does not get cold even with the cooling temperature set. The temperature has been rising and is past 80 degrees now, and is not decreasing. The AC seems to be running outside, however the temperature is still rising inside, and there is a very faint flow of cool air coming through the vents.
What could be wrong and how do I fix it?
    Sergeant:
  • 340 Answers
Could be froze up if it is turn it off to melt ice clean unit could be low on freon or bad blower motor
Posted on Jun 17, 2009
I need to clear the program in my Honeywell model # CT3600A4
OWNER?S GUIDE
Honeywell CT3600/CT3697
PROGRAMMABLE THERMOSTAT
9k=
Dec 26, 2014 | Heating & Cooling
Manual honeywell programmable thermostat
Follow the below link, select thermostat on the upper box, then type CT3600 on the lower box.
http://yourhome.honeywell.com/home/Applications/FindOwnersManual.aspx
Oct 09, 2012 | Honeywell CT3600 7 Day Electronic...
My honeywell timer for the back boiler heating is blank
need to contact the people who worked on it yesterday to come back and look at it again because it sounds like you have no power to now.
Jan 29, 2010 | Honeywell CT3600 7 Day Electronic...
CT3600 display went out. Replaced all 3
My honeywell CT3600 thermostat went blank.
Replaced batteries - no change ?
Dec 25, 2009 | Honeywell CT3600 7 Day Electronic...
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Oct 01, 2009 | Honeywell Electronic Programmable...
Thermostat just stopped working.
is the tstat in cool mode? if not hit the mode button untill cool pops up then hit the down airow untill desired temp. sometimes the thermostat has a 5 min delay so be patent. If unit still does not run call the service co. and find out about how long they warranty their service call. usualy one month.
Jun 14, 2009 | Honeywell Electronic Programmable...
Need a "trouble shooting" guide for FocusPRO TH6000
i have the heat set at 73 the temp in the house is getting colder it is at 67 now and it won't come on . why?
Jun 12, 2009 | Honeywell Electronic Programmable...
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
Honeywell humidistat stuck
what i would do is make sure tha the hole for the wires that go to the humidistat is completely closed and that you are sensing the true humidity for the space also have the tech wire the so that the heat comes on instead of the ac for the de-hiumidification process.
Feb 10, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
EEE error message
I just talked to Honeywell support - they claim that an eee error means there has been a "unique error" and that the unit will need to be replaced - cannot be fixed. They were pretty good about giving a suggestion for a new thermostat and wiring directions if you want to DIY. Otherwise, call a pro.
Oct 29, 2007 | Honeywell CT3600 7 Day Electronic...
Heating & Cooling Logo
382 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
