Question about Thermos Gas Grill 4617222
I have changed the propane tank and hooked it up but now i get no propapne.
  • 986 Answers
Hate to be a smart ***, but if you dont have the tank hose screwed all the way pass the O-ring then the check valve on the fitting will not compress. Thats all I got. Good Luck
Posted on Jun 17, 2009
Hooked up bbq propane tank and smell gas?
I would turn the gas on and spray soapy water at the fittings if bubbles appear that is where your leak is. if it is leaking in the lines. turn gas off un screw fittings and wrap them with teflon or what some call plumbers tape they are both the same thing and very inexpensive. if it is at the valve on the tank I would get a different tank
Jul 26, 2012 | Grilling
Hooked up proane tank used once then no flame on grill. There is propane in the tank but no propane flows out of it either when hooked up to the grill or when opening the valve directly on the tank. This...
The valve on the tank has an internal valve that will not allow you to release propane into the atmosphere. It must be connected to a regulator line in order to open.
It sounds like your regulator has failed. Remove the regulator assembly, inspect it carefully for blockage or hose kinks. If there none, try replacing the regulator assembly.
Gary
Sep 24, 2011 | Weber Genesis E-310 Gas Grill
I bought the Brinkmann 5-Burner Grill Model 810-9520 a little under a year ago and recently have been having problems with the flame. The grill will lite with a strong flame if just one burner is on, but...
hello megan. actually the propane tank is causing this problem. the newer propane tanks have a safety feature built into them to prevent fires and explosions. that is a good thing. what is not so good is that the tanks are now a wee bit tempermental. this is what you now need to do. turn off the tank and unscrew the hose. let the hose sit unattached to the tank for 5 minutes then hook it back up and very s-l-o-w-l-y turn on the gas. That should solve the problem. if it doesn't repeat the procedure. joe
May 24, 2011 | Kitchen Ranges
Machine will not ignite...ignitor clicks...new battery...new fuel filter...new propane tank...cleaned machine...help!
is the propane hooked up correctly with the valve turned on, and verify that there is propane inside the tank as I have purchased new tanks that were empty. Hope this helps Tim
May 15, 2011 | Garden
I have 3 natural gas fire places. i would like to know if i can change it to propane. i'm thinking i would just have to change the logs and hook a tank up outside. can some tell me if this would work.
Typically gas log sets are factory made for either natural gas or propane. If you want to use them on propane you need to find out if a LP conversion kit is available for your brand/model #. Ask the place where you bought them or ask the company that installed them (if you didn't put them in yourself). If they can be changed over to propane, then you will need to buy the propane tanks, regulator and gasline or just have your local propane company put in a pair of 100# cylinders for each fireplace (or 420# cylinder to service all 3 fireplaces) with an auto-switchover regulator. They can also do the conversion, if the conversion kits are available. Let me now if you have any other questions. Douglas
Oct 21, 2010 | Reddy Heater RLP100 Portable Forced Air...
Gas gauge... how does it work... or is it supposed to be hooked up to the can somehow??
If it's like mine, you literally hang the propane tank on a hook. The gauge is basically a spring and as the propane is used and lightens the tank, the spring contracts.
Jul 27, 2010 | Weber Genesis E-320 Propane Grill
My propane ank is full, but when I turn it on high, the flame is barely lit. When I change it from high to low and back to high, the flame level never changes.
First disconnect tank. Hook back up and open very slowly. These new valves on tanks have a shut down if you open valve to fast, causing tank valve to think it is leaking, it slows down flow of propane. Always open tank valve slow when turning on grill. If this does not solve problem then regulator is going bad and need to be replaced.
Feb 07, 2010 | Grilling
Can i hook two 500 gallon propane tanks together instead of purchasing a 1000 gallon tank?
yes you can but please get a propane gas certified engineer to do it , its really a job to be done by experts , the explosive power of propane is just to dangerous to mess with
Nov 10, 2009 | All-Pro Propane Garage Shop Heaters - All...
Hooking up a pool heater to propane.
A pressure regulator and pipe or hose. Whoever is selling you the tank/propane should be able to help you size everything based on the tank hook-up and tank pressure. The heater nameplate will tell you the proper inlet gas pressure that the regulator will need to reduce the tank pressure to.
Sep 07, 2009 | Hayward H Series
Propane tank
yes, you need to buy an accessory cord that connects your tank to the regulator
Jul 03, 2008 | Coleman Roadtrip Grill LXE 9949-750
Thermos Gas Grill 4617222 Logo
167 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
kc5133
Level 1 Expert
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
