Question about Sta Rite Sr400na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 400,000 Btu Natural Gas
Error code 126
I have the same problem with my hayward pool heater. It's on - not heating though - i can change the temp up and down but then it immediately displays 126! What's up with that. And the service light does not go on.
  • 990 Answers
This is a bad thermister or heat sensor. It mounts in your water manifold and if it goes bad no error will show. The bad sensor is telling the heater that the water is to hot and it wont let the heater fire. This is a farley inexpensive part and easy to change out. With a new one it should read the proper temp and call for heat then fire the heater. Good luck.
Posted on Dec 08, 2009
Had a power outage yesterday now heater won't ignite. No error codes.
bo = 'Bypassed Operation'
heater is now controlled via your automation system.
Create a heat call, turn solar off if active.
Heaters should be set to auto on.
Mar 07, 2015 | Hayward Pool Products Hayward Universal...
I have a Hayward H400 that shuts off at 88 degrees. What could this be?
Is this heater standalone, or is it hooked up to an external controller? If it is standalone, it sounds like you need a water temp sensor for the heater. If its hooked up to an external controller, you likely need a 10k temp sensor. What error code does the heater display when it shuts down? And what temperature are you able to read on the heater and/or external controller?
Aug 25, 2014 | Hayward H Series Pool & Spa Heater 400k...
My Hayward pool/spa heater runs fine until the temp is about 92F. Then it shuts down and displays an error code (LO). It always shutdown at the same spa temp. I am assuming that it is probably a...
It sounds like it could be one of your high limit switches cutting the heater off because it thinks it is over heating. There are two, one at 135 F and one at 150 F. You can "jump" those and see if it heats above 92 F. Try that first, but there may be several other causes.
Oct 24, 2013 | Pool & Spa
Cant change pool heater temperature
see if set on remote if not bad display board or hold up and down at same time for 7 seconds maybe locked
May 21, 2013 | Hayward Pool & Spa
Hayward H-Series Not heating water
if all burners are working correctly then put a bypass on heater plumbing open it half way to slow down water flow that will give you a higher heat rise
May 05, 2013 | Hayward H-series Electronic Gas Pool...
Sta-rite heater error code 126
The 126 is not an error code, but it maybe the temp of the water that the heater is reading. If the heater thinks the water is 126 degrees, it will not start at all.
If the heater is reading the wrong water temp, the problem is the Thermister, which is the sensor that is suppose to read the water temp. You will need to replace this sensor in order to correct the problem with the heater. It is really easy to do!
If you have a manual for the heater, if you go to the Replacement Parts Listing for the Electrical System, page 53 in the online version, the Thermistor is Item #9. It goes into the left side of the manifold in the to place, between the first two manifold bolts.
Jun 22, 2009 | Sta Rite Sr200lp Max E Therm Pool & Spa...
I have a Hayward pool heater. It's about 5 years
would not suggest trying to manually light,its an electronic ign model so you may damage some wires with an open flame.try powering off then turning back on and see if display retuns to normal
Jun 19, 2009 | Hayward H Series Pool & Spa Heater 400k...
Sta Rite Sr400na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 400,000 Btu Natural Gas Logo
563 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
