Question about Fisher and Paykel 24 in. DS603H I Built-In Dishwasher
I have a fisher paykel soft touch dishwasher about 10 years old. The F1 message came on and we have taken out the inside filters and cleaned enitirely., Was working fine until it came on by itself during the night. Unit is dry but the F1 light remains on. Do they have a sensor and where is it located?
  • Fisher and P... Master
  • 3,247 Answers
The sensor is a flood switch at the base of the housing under the drawer.
Posted on Jul 08, 2010
  • 205 Answers
The flood sensor is located below the bottom drawer. If you take the bottom drawer out and there is water in the pan then the flood switch is probably tripped. Soak up the water with a towel and apply a hair dryer towards the rear left corner of the cabinet. The flood switch is part of the Mains Filter control board and should not be messed with (even with the dishwasher unplugged)... There is an underlying problem that caused the F1 fault and you should have a technician look at it.
Posted on Jul 21, 2009
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
Hello, I have a Fisher and Paykel DD603I and both drawers have a red light on the play/pause button and won't stop beeping. Can you please help me with a solution to this problem?
It sounds like the dishwasher is in flood mode. You would need to dry up the water in the base pan and test. The link below is a video that explains how to repair your fisher paykel dishwasher.
Fisher Paykel Dishwasher Repair Video
Mar 23, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
Both drawers not cleaning well. Glassware comes out cloudy. Have cleaned all filters, taken out rotors etc. Some detergent remains in dispenser after wash cycle complete. Now 5 years old and was working...
Try running a hot wash without anything in and just use some dishwasher cleaner (normal cleaner).
Also make sure your water softness is set correctly and that your salt dispenser is full.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
I have a 10 year old dishdraw (Model No DD601v2). It is displaying a fault message "F1" on the top draw display and will not start. What fault is this indicating?
Normally F1 should display in both drawers.
But this is a bit unsual. Please confirm if you are still able to operate the bottom drawer.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F9 problem code Fisher and Paykel Dishwasher - Soft Touch
That's an electronics failure code. Bad news.
http://www.advantagesupplyfl.com/FisherPaykelDishwasherFaultCodes.html
Jan 21, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
My Fisher & Paykel DD 603 has the fault code
Check at bottom housing both top and bottom drawers for leaks.
Pull the tube out, on the left side below the tub you can access to touch the bottom housing. Dry it out with a tower. Un plug the power cord at least 24 hor so the flood sensor can be dried out before pluggin it back.
However, if you don't fix this leak, the sam F1 problem will happen again.
There is not much clogging up in filter. If you expect something clogged up, you have to take the spraying arm off then take out the bottom stainless steel with a lot of holes out to see the impeller clean or not. Good luck.
Sep 10, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & Paykel Dishwasher DW60CSX1
I have a dishwasher - "Soft Touch" which seems to be stuck on F1. This occured in the middle of the night and although turning off at wall cannot get it off this setting
Jul 11, 2009 | Fisher Dishwashers
Fisher & Paykel single drawer dishwasher F1 flashing.
F1 indicates a problem with the Flood sensor. I cleaned all the filters etc. removed the drawer viewed under the drawer, it was dry. There is nothing further I can do, so called the Appliances repair person and booked an appointment for him to determine if an outlet hose is blocked or has a hole in it or whatever. Thanks for all the suggestions Blokes. I'm technically challenged. Happy New Year
Dec 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DS603H I Built-In Dishwasher Logo
995 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
