Question about SimpleTech Computers & Internet
My simpletech portable 250 gb hard drive wont read
No matter what computer I use the hard drive wil not be picked up by it and I dont want to lose all my files. What can I do to fix this?
  • 555 Answers
Hello my  friend, regarding on your problem we have to consider first the different possibilities that cause this hard drives won't work. First try to double check the connector if it is properly connected or the power cable connector that causes no power that eventually give no power to the hard-drive. Another if you can notice the hard-drive, if the power of that device if present then eventually the problem is your hard-drive but if doesn't have a power then their are possibility that the power supply is  wrong. My recommendation, if you could fine a technician in your place then better you have to seek assistance in order to help you save your files from lossing it and to check if what are the main reason why this device won't work properly even you tried different computers. In that way, you can save files. Or if that device is under warranty then ship it back to the supplier to have a replacement but make sure that they have to make a back up from all of your data.
Hope this advice helps you from your problem. If you need more assistance just reply to this post. Thanks
Posted on Jun 17, 2009
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Computer not reading hard drive
Usually a brand new HDD needs to be formatted.
Have you done that?
If not, then you should do as follows:
Right click on My Computer, click on manage.
A new window, called Computer Management. will appear.
Click the option Disk Management from the left pane.
On the right you will see ALL the drives connected to your computer.
Select the one you want top format, right click it and choose FORMAT.
When the process is completed, you'll be able to see and use your new HArd drive.
Hope this helps.
Jul 04, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
Which USB port on the computer do you plug in Simpletech? Or does it matter?
The current standard for USB 2.0 was released in 2000. All computers carry this standard so all USB ports will work...even the usb ports that also support E-Sata.
Jun 10, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 250 GB Pininfarina was knocked on the floor
oped it, maybe loose cables or connections. or the worst case, a faulty hd. ticking sound means bad drive, cannot read disks. retrieve data? the better chance will be a recover technician, dont try anything else, will turn a worst problem.
Jun 02, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
No software or instructions
simpletech is a plug and play device compatible with vista and xp. you dont need a software to use it unless you wanted to access the quick backup button function when you press the simpletech logo. software is available at their support website: www.simpletech.com/support/
Jul 16, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
My computer wont read my Simpletech 500gb hardrive
SimpleTech has problems with their controller board. The HDD inside probably still works fine. You might want to get an external chassis and take the hard drive from the SimpleTech and put it into the external chassis. You will need a sata one.
May 07, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 80 GB Portable HD Won't Read
It sounds like a problem with the board inside the case,- the actual hard drive is probably OK. Opening the case will void any warranty but there may not be much left anyway. There should be 4 screws in the bottom of the drive,- front 2 may be hidden under a sticker. Try installing the drive in your new case or an empty drive bay inside your computer. I have had external hard drive cases fail before and the actual hard drive was ok.
Jan 23, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Files on device become ''read only'' locked
i) i think this type of behaviours speciall due to presence of spware, virus in your system, initially to perform a full system scan on your disk and make sure that this not repeating in near future ...
ii) after do this try to change its mode(read only) by right-click on the folder or file u want to use and at the bottom you have to uncheck read only.........
Thanking youy
M. Sridhar
Dec 29, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Opening simpletech download onto Acer with Vista
hard drive with high capacity are always fagile and they get crashed easily.why not try a new hard drive.
Jan 27, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
164 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Ricky Ostrom
Ricky Ostrom
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
