Question about Garden
Slow starting tiller
I have a small garden tiller that uses a gas/oil mix. I have removed the spark plug to prime the engine. I can eventually get it to start, but when I adjust the choke, the tiller quits. Is it possible that my gas/oil mix is too rich? Any suggestions on how to get this to start? I'm going to pull out my shoulder.
    Scholar:
  • 81 Answers
Anytime an engine uses a gas/oil mix there is a possibility that the carbon this mix produces clogs the muffler making air flow next to impossible. First check to see if it will run better without the muffler. If it does you will need to clean the muffler by removing it and burning the carbon out with a torch. If this isn't the problem, then it may by your carb. Remove it, clean well with carb cleaner, replace the diaphragm if needed for as the diaphragm gets older it becomes stiff and will not pump the gas to the engine. When you reinstall the carb, turn the adjustment screws all the way in and the one and a quarter turns out to start with, making further adjustments from there after it starts. Hopefully one of these is your solution.
Posted on Jun 17, 2009
Smoke came out of the leaf blower while using it and it will not start again. What to do?
1 obtain new spark plug
2 completely empty the gas tank including the gas lines
3 Carefully remix proper amount of gas to oil ratio and try again.
Most Gas leaf blowers / weed eaters run on Gas mixed with Oil, if too much oil is present smoke will appear the spark plug will foul and it wont start. additionally nO oil at all in the gas will cause the engine to smoke seize .and never ever start again. so if you can still pull the starter rope try the above
:note: most small bottles of oil mix will do two gal
May 02, 2018 | Garden
Oil get mixed with gas and full in the cylinder makes spark plug wet and refuse to start on honda gc16o engine
You have trash in your carb....remove the carb and inside the bowl remove the float and needle valve. clean the valve and seat and replace...should fix you up
Aug 24, 2017 | Honda Garden
How do you start it/
Check:
- Gas in gas tank
- Oil level correct.
- Tiller drive in off/disengaged position.
Start procedure:
- Fuel selector - ON
- Ignition switch - On
- Choke - On
- Throttle position - Slow
- SAFETY - No children within 10 feet/
Pull Starter rope......
Repeat 3 - 5 times only.
If engine starts, release choke as required until engine runs smoothly.
If no start,
- set Choke to OFF, Throttle to FULL,
- pull starter rope 3 - 5 times only.
- if start, reduce throttle to obtain smooth idle
- if No start, start check for:
- Spark at plug
- Fuel in the jug
May 22, 2015 | Garden
What causes oil to come out of exhaust. was running fine 3 weeks ago.
ethanol gas for one thing. When it is left to set it breaks down the gasoline. You have a two cyc. engine (gas and oil mix) Clean the plug then take the unit and shake the unit to mix the gas back up. This may not work but its worth a try. Or drain the unit completely use non-ethanol gas make a new batch and replace plug.
Feb 22, 2013 | Troy-Bilt Pony Garden Tiller
I have a sears 2 cycle mini tiller that worked great for the first hour but now won't start.
Do not use pre-mix fuel. Clean carburetor. Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil) .Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
check age of gas. Cannot be more than 30 days old.
Oct 10, 2012 | Craftsman Gas Mini - Tiller/Edger
I have an older 5 hp. Mtd tiller Do I have to use
Look on top of the machine.If there is an oil fill then no you do not use mixed fuel if yes it needs engine oil,30 wt.If there is no engine oil fill then you use mixed oil and gas,at a 50:1 ratio.
May 30, 2011 | Mtd Garden Tiller (Mtd)
I have a TROY-BILT Tiller/Edger model 12216. I installed a brand new spark plug, fresh gas and new oil. It started and I even used it to break up a small portion of my yard. By small I mean probably 5...
check gas/oil, if all is good the pull the spark plug, hook the spark plug back up and pull the cord while observing the spark plug for spark, may be the coil. Hope this helps Tim
May 02, 2011 | Garden
Pony Garden Tiller: does a tiller with a briggs and straton engine nee...
The pony tiller with a Briggs and Stratton engine only uses gas do NOT mix oil with the gas.
Frank
May 18, 2010 | Troy-Bilt Pony Garden Tiller
I have compression, spark, and gas/oil mix. engine not starting.
When cleaning the carb., use a De tek Brush,(used for cleaning between teeth), to clean the small portals. The smallest particles can keep it from running. More than likely though, It will be the small screen in carb. It can become clogged up to the point where you can't even see daylight through it; not good!
Jim
Jun 04, 2009 | Honda Hmantis Mantis Garden Tiller with...
Garden Logo
105 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
