Question about Sony Handycam CCD-TR818 Camcorder
Sony CCD-TR818 Will Not Power Up
I've tried the RESET button (per the manual), but still no results.
All I can say is there is a VERY low-volume sound that comes from the rear of the camera when it is powered up (for about 1/3 second; 2500hz). I checked the battery voltage, and it is OK. Any ideas?
At the very least, I need to get a trapped tape out of the unit.
  • 2 more comments
  • tim00789 Jun 17, 2009
    This battery had been working fine (I don't use the battery all that much).
    I was able to measure the battery voltage (by putting some very small wires on the contacts and running them to the outside of the battery) and it reads 7.92V, power on or off.
    When using the AC adapter, it makes no difference (trying the reset again, also).
    I only used the battery and the AC-L100 adapter supplied with the camera, so it was not a wrong voltage supplied by me. You are probably right about a part being fried. Sony's flat rate repair is $100.00; probably cheaper than that on eBay soon.
    How do I get the stuck tape out?
    Its dead. Nothing works. I give up.
    I'll just try to attack it with a screwdriver tomorrow to get the tape out.
    The camera probably is not worth trying to salvage.
    Thanks! That information is just what I needed to extract the "captive" 8mm cassette.
  • 10,594 Answers
CCD-TR818 is analog video-8 camcorder and I can help you to take out stuck tape. I have its service manual as below image shows...
Take off side cover of camera, unscrew metal shield that covers video head assembly and unplug one flexible wire that is connected with loading motor as shown and marked in below image...
Now apply 4-5 volts to loading motor terminals so mechanism will start unloading until tape door ejected, take out tape and apply same volts on loading motor in reverse order so mechanism will load again without tape. put back cabinet cover. Job is done.
Let me know further query / question.
Thanks.
Posted on Jun 17, 2009
    Scholar:
  • 106 Answers
Hi..
It seems your problem is most likely your power source. If you have a spare (fully charged) battery, give it a try. If that doesn’t help, switch to the A/C adapter/charger. Plug it into the camera, then to the wall outlet, and press and hold the power button for a second or two. If your camera still doesn’t turn on, be sure the outlet has power (by plugging in a lamp or some other device). If the outlet is working, but the camera still isn’t, check the connection between the A/C adapter and the camcorder. If everything seems securely connected, try cleaning the battery contacts. To do this, first disconnect the A/C adapter. Remove the battery from the camera, and with a pencil eraser and/or a clean, soft, lint-free cloth, rub the metal contacts of the battery as well as the battery terminals in the camera. Reinstall the battery and try turning the camera on. If it still doesn’t work, it’s probably time to buy a new battery...
rate me
  • 1 more comment
  • Praveen kumar V
    Praveen kumar V Jun 17, 2009
    i think you did not deliver the correct voltage to your camcorder and fried one or more parts. Though, if you only fried 1, it may be worthwhile to get it looked at and possibly repaired because the camcorder is pretty expensive, and depending on the part you fried you may still be able to repair it for the worth of the camera. But, don't get your hopes too high up, chances are its gone for good....
  • Praveen kumar V
    hi...
    just pull the camcorder appart with some screwdrivers and a large hammer. Tape will came out fine!!
    Or else u can try this steps
    Open the tape door on the bottom. LEAVE IT OPEN. Power off your camcorder and remove the battery. With the battery removed, move the power switch to ON. LEAVING THE POWER ON AND THE TAPE DOOR OPEN, replace the battery. The tape should eject without damage. This works for many other models as well.
  • Praveen kumar V
    dont forget to rate for my solutions....
    thank u
Sony tr818 drivers
There is no PC interface for this camera (USB, Firewire), hence no driver.
http://www.amazon.com/Sony-BP-512-CCD-TR818-Hi8mm-Camcorder/dp/B00005LDXN
Nov 20, 2012 | Sony Handycam CCD-TR818 Camcorder
Sony xperia ion troubleshooting
The phone have a battery issue.
Replacing battery is the only solution.
Nov 01, 2017 | Sony Ericsson Cell Phones
Sony Handycam CCD-TR818 Hi-8 Analog Camcorder: How can I transfer my vedios to my laptop.? Plz help.
You require an A-D Converter. Analogue to Digital Converter box.
Note: Many mini DV cameras can act as a Converter if they have analogue inputs.
Apr 15, 2011 | Sony Handycam CCD-TR818 Camcorder
Sony Handycam CCD-TR818: The camcorder cassette door stays in the open position. It won't stay closed. Even when you put a casette in, it will expell the casette, and the door will stay open. I have...
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jan 28, 2011 | Sony Handycam CCD-TR818 Camcorder
The Eject button on my Sony Handycam CCD-TR818 Hi-8 Analog Camcorder does not work. A tape is in there ( I can still record and view the tape fine) but I can't take it out and put a new one. Any...
This cannot be done by you and you need to refer this to a trained camera technician.
Any force applied to remove the cassette will damage the mechanism.
Jan 14, 2011 | Sony Handycam CCD-TR818 Camcorder
My sony wount record or playback a movie, there is a blinking symbol when i hit record.
I'm Sony tech and can help you to solve problem of CCD-TR818 camcorder.
Tap bottom of camcorder few times with your palm gently, now check playback of tape.
If problem still not solved, let me know what error code flashing on top right of view finder screen.
Thanks.
Dec 04, 2010 | Sony Handycam CCD-TR818 Camcorder
Sony CCD-V701have a blinking arrow and camera does not record or play back
THIS MAY SOUND A LITTLE STRANGE,BUT FIRST, HIT YOUR RESET BUTTON, THEN SET THE CORRECT DATE AND TIME. THEN POWER ON AND OFFA FEW TIMES. IT WORKED FOR ME.GOOD LUCK.
Jul 14, 2010 | Sony Handycam CCD-TR818 Camcorder
Ccd tr818 camcorder
what type of cables are you using to connect your camcorder to your pc? EX: 4 pin, 5pin, 6pin? or are you using an iLink cable?
Jan 11, 2009 | Sony Handycam CCD-TR818 Camcorder
Sony Handycam CCD-TR818 Camcorder Logo
145 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
