Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Engine rpm is not steady.
When the engine is running in nutual or even when in gear (forward or reverse), it does not run at a steady rpm. It revs up and down no matter what the thottle is set at until the lawn mower blades are engaged. Once a load is placed on the engine, such as the engaging of the blades, it then seems to run at a steady rpm. What do we need to do?
Thank you so much for your help!
Ethelyn
    Problem Solver:
  • 7 Answers
Sounds like the spring on the carburator butterfly valve is weak ... when at idel it surges the engine but when the blade is enguaged the engine evens out
Posted on Jun 17, 2009
My ford telstar tx5 V6 idles correctly and revs clean when not in gear. When driving there are deadspots in the throttle
there is an idea that when it runs good in reverse but not in forward gears , there is a problem in bad engine mounts that is allowing the wiring to make a bad circuit for the electronics
could be a loose /bad connection for the cam/ crank sensors, injector operation or ignition control module
in forward gear , the engine reacts to the torque application and that would pull on the harness
when in reverse the reaction is opposite and not affect the wires
Jul 01, 2016 | Ford Cars & Trucks
I have a 1998 Suzuki bandit 1200.I'm having problems with the clutch.I think. I noticed when I would accelerate the rpm would jump 4 -5000 before the bike would respond . I let off throttle to stop rpm...
make sure there is 3mm play on the clutch lever , select 5th gear while engine is running and press the rear brake to stop you moving away ! with a little revs try and set off , if clutch is worn it will slip and not stall the engine ! if this happens then replace the clutch plates !
Sep 24, 2013 | 1998 Suzuki GSF 1200 Bandit S
Trasmission sleeps somtimes the gear works other times it doesnt
there are many gears.
are all gears dead, forward and reverse
even at 3000 engine RPM?
is the transmission slipping
if RPM gets stuck at say 1500 to 2000 that means the brakes are frozen in ICE.
Jul 30, 2013 | 1990 Honda Accord
My aprila rs50 starts fine and runs fine cold but if it heats up abit you pull the throttle and it sounds like its dieng
Instructions
    • 1 Park your RSV 1000R on a well-ventilated, level area, using its kickstand.
    • 2 Start the engine and let it idle in place until the temperature gauge built into the instrument cluster indicates a minimum internal temperature of 180 degrees Fahrenheit. This is the motorcycle's ideal operating temperature.
    • 3 Take note of the engine idle speed, using the tachometer needle, while the engine is running. Ideally, the engine should idle steadily at 1,250 rpm.
    • 4 Adjust the engine idle speed to 1,250 rpm, using the idle adjuster screw hidden between the lower right edge of the fuel tank and the upper edge of the right middle fairing panel. Turn the idle adjuster screw clockwise to increase the engine idle speed, or counterclockwise to decrease the engine idle speed, using a small flat screwdriver if your RSV 1000R's frame (VIN number) precedes ZD4MEE009YS000292. A plastic knob allows the engine idle speed to adjusted by hand on RSV 1000R models with a frame (VIN) numbers starting from ZD4MEE009YS000293.
    • 5 Rev the engine two to three times and observe the tachometer. The engine should return to a 1,250 rpm idle. Adjust the engine idle speed as needed, using the method described, then rev the engine again. Problems may exist within the throttle control, fuel-injection system or engine, if the engine idle speed will not hold steady at 1,250 rpm. Contact your local Aprilia service facility for assistance.
    • 6 Stop the engine, once you have obtained a steady 1,250 rpm idle speed.
Jan 17, 2013 | Aprilia Motorcycles
I have a 1999 suburban with a 5.7 vortec the engine wont build rpm while moving,but revs freely in nuetral or park.If the computer senses movement in forward or reverse the engine misses such as a rev...
The computer can't sense movement. An engine with worn spark plugs or bad coils can run perfectly fine at idle and begin misfire the second you put it into gear or under loads. Plugs/coils misfire most when under load. Have you checked them?
Oct 18, 2017 | 1997 Chevrolet Suburban
Cars cranks and runs but dies when put in gear
If it is a Stick shift or an Automatic, the engine speed needs to be at least 750 RPM, after the gear has been selected. Either Forward, or Reverse. Get the Engine "Warmed up", and make the necessary adjustment on the Throttle speed adjuster screw.
Regards,DT
Feb 15, 2011 | Ford Escape Cars & Trucks
Problems accelerating
the engine tickover is too slow when the engine is cold its running on cold start, ie:choke,, after it warms up the engine slows down this is what is causing it to stall in gear,, get some one to hold the brakes hard on and with the engine running in gear ajust the tick over till its reving at 750 - 850 rpm the revs will go up a bit when its out of gear,, before you pick a gear to go into push the foot brake down to stop the car lurching,,,
Feb 19, 2010 | 1997 Cadillac DeVille
35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Aug 22, 2009 | Boating
Car does not drive forward but works in reverse
Sad to say but your automatic transmission has bit the dust.
Jul 24, 2009 | 2004 Chevrolet Cavalier
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
646 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
