Question about Dell OptiPlex GX520 PC Desktop
My Dell Optiplex GX520 will not boot. There is no video output and the 3 and 4 diagnostic lights remain on.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Try reseating the memory one stick at a time in each slot at a time and try turning on the computer after each stick reinsertion.
  • 3 Answers
For some reason Dell doesn't suggest one obvious alternative: the DIMM slots on the motherboard are dirty and not making good contact, so clean them. That's what worked for me (on my ancient Dimension E310).
I cleaned the sockets by spraying TV contact cleaner into them (after removing and draining power to remove the DIMMs of course) and inserting/fully-seating/unclipping/removing/rinse&repeat DIMMs 5-10 times. Then when I put everything back together it all worked!
(Every spray can of TV Contact Cleaner I've ever seen came with a red tube taped to the side. One end of that red tube just fits into the hole in the spray button on the top of the can, and the other end directs all the solvent right into the DIMM slot rather than spraying it all over the inside of the computer. I tried not to make too much of a mess ...but I didn't worry about the inevitable drips.)
Posted on Jan 09, 2012
    Scholar:
  • 124 Answers
If 1 & 2 are off ... then you have problems.
Memory modules are detected, but a memory failure has occurred.
  • If you have one memory module installed, reinstall it and restart the computer. (see Memory for instructions on how to remove and install memory modules.)
  • If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • If available, install properly working memory of the same type into your computer.
  • If the problem persists, contact Dell (see Contacting Dell).
According to Dell's notes:
Their remedies are:
Posted on Jun 17, 2009
How to solve orange solid light on my dell GX520 when i boot it
Nana, A solid amber power button on your GX520, indicates a motherboard failure. The motherboard will need replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Solid orange power button on Optiplex GX520
My Dell Optiplex GX520 will not boot Forums
Dell Optiplex GX520 amber solid light no power
Aug 05, 2016 | Dell Computers & Internet
1,4 diagnostic stable lights
A) What is the Power On LED light doing?
B) What is a Battery light?
Post back in a Comment
In the meantime, see if there is an unused KNOWN to be working computer; that you can borrow the Power Supply from temporarily.
DON'T install it yet.
Regards,
joecoolvette
Feb 19, 2013 | Dell OptiPlex GX520 PC Desktop
My GX520 pwr light is green, on the board is an amber Led, the somputer boots up, it goes the full process, until the arrow appears on the monitor. no Iconn are displayed on the desktop
If your computer gets to that stage, then I would guess you have an OS ( Operating System ) problem. Try booting from your XP installation CD. If that works then you may have to re-install Windows.
Jun 23, 2012 | Dell OptiPlex GX520 PC Desktop
Dell Optiplex gX520 will not boot beyond the splash screen. Dell Optiplex gX520 will not boot beyond the splash screen. There are not post code beeps.The lights on the front panel are 1 and 4. Both are...
Sounds like you may have multiple problems. Suggest trying to eliminate possible causes by removing components. Remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged. Remove the components one at a time and see if the LED's change.
Dec 10, 2011 | Dell Optiplex GX520 Desktop PC - Intel...
My using Dell optipulex Gx520 and i,m unable to turn my desktop its giving me a beep sound and 3 & 4 numbers are showing infront the machine
I believe there is a problem with the memory sticks on your optiplex. Please refer to the link below for the meaning of the diagnostic light on your desktop.
Diagnostic Lights
Meaning, it is most likely that you need to replace one or more memory sticks of your desktop.
Regards
Sep 14, 2011 | Dell OptiPlex GX520 PC Desktop
The monitor to my dell optiplex GX520 is displaying an "Input not supported" error. I suspect i need a new video card but want to try all options before going to the store. Is there anyway i can...
Yes there is. You will need to boot your pc into safe mode or VGA mode depending on the operating system. To do this when the computer boots up after the initial bios screen hit f8 and you will be prompted to boot into windows normally or safemode and some other options. Boot into safemode and place your video card at the lowest setings. Also you can update your drivers from here.
If you have windows 7 you have more options to play with on the f8 boot menu, they are pretty self explanatory but you may need to enter advanced options.
If still nothing please write me back and we can go from there.
If my answer helped you today please give four thumbs up as thanks!
Sep 04, 2011 | Dell Optiplex GX520 (DEGX520SDT2.85124) PC...
I have a dell Optiplex Gx520.When i put it on,the power button is a steady yellow clor and the PC will not boot up.Please help. Thanks, Farous.
here is the link that explains what these lights mean and how to resolve it. http://support.dell.com/support/edocs/systems/dim4700/sm/adtshoot.htm
Nov 04, 2010 | Dell OptiPlex GX520 PC Desktop
L have dell optiplex 520 and 330 computer and it now giving me amber light and how can l solve the promblem
See Diagnostic Lights, and Diagnostic Leds, on this page:
support.dell.com/support/edocs/systems/opgx520/en/ug/tools00.htm?dgc=CJ&cid=24471&lid=566643&acd=10550055-3312504-#wp1114558
computer has four lights labeled "1," "2," "3," and "4"on thefront or back panel. The lights can be off or green. When the computerstarts normally, the patterns or codes on the lights change as the bootprocess completes. When the computer starts normally, the patterns orcodes on the lights change as the boot process completes. If the POSTportion of system boot completes successfully, all four lights displaysolid green. If the computer malfunctions during the POST process, thepattern displayed on the LEDs may help identify where in the processthe computer halted
Jan 15, 2010 | Dell OptiPlex GX520 PC Desktop
Dell Optiplex GX520 PC won't boot - power light at front just blinks
OK the first step is to remove the side of the case and check that all the leads are firmly inplace. - If this does not fix it post a comment.
Nov 02, 2009 | Dell OptiPlex GX520 PC Desktop
Unable to upgrade onboard graphics on dell gx520
Try disabling your onboard graphics in the BIOS. Some BIOS allow this. If you have a sound card, disable the onboard sound too. Count your beeps. they contain a code. Go online and "Google" bios codes. This should give you a starting point to diagnose the problem.
Oct 10, 2009 | Dell OptiPlex GX520 PC Desktop
Dell OptiPlex GX520 PC Desktop Logo
1,662 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
