Question about KitchenAid KUDR01TJ Dishwasher
How long does it take a cycle to run? The wash light stayed on but when I turned it off it was already dry
  • 10,865 Answers
The cycles take between 75 minutes and two hours depending upon which cycle and chich machine.
Posted on Jun 17, 2009
Samsung DMT300RFW Builtin Dishwasher will not run past wash cycle. I start it and it fills and the wash cycle starts but won't cycle past the wash cycle. No error codes.
What do you mean, it won't "run past the wash cycle"? Do you mean it stays in the wash cycle forever? Or do you mean it quits in the wash cycle and doesn't rinse or dry?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 18, 2014 | Samsung DMT300RFW Builtin Dishwasher
My Whirlpool dishwasher washes but does not rinse or dry
Most likely the control panel is defective. Go to the repairclinic.com for further diagnostic help and parts.
Apr 25, 2017 | Dishwashers
My dishwasher does not go into the dry and clean cycle. It just stays in the wash cycle.
stwaterdog5,I am not sure what model it is but the heating element may be defective.Check to see if heating element is on right after it finishes draining.
Hope this helpsJoe Connolly
Nov 10, 2011 | Frigidaire Dishwashers
Start light keeps flashing - wont run. The normal wash and heated dry stay on too. Called tech support, only thing they could say is that the cycle was interrupted. The cycle never even started, cannot get...
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run yourdishwasher as normal. If this same light appears again then you have a bad element or thermostat.
Please take a second to rate your experience. Feel free to repost again if you have more questions.
Have a great day!
Dec 09, 2010 | Whirlpool MDBH969AWB Builtin Dishwasher
Clean light won't turn off, new wash cycle won't start.
Press these buttons in succession, within 5 seconds: high temp wash, air dry, high temp wash, air dry. If the sequence is entered properly, all of the control panel LED's will illuminate simultaneously. Once this happens, press the cancel button twice. Now you should run a complete cycle again. If the dishwasher actually has a problem, it will fault again (means the unit isn't heating properly). If not, it's business as usual.
Apr 25, 2009 | Dishwashers
Dishwasher will not start
Go to your electrical panel and turn off the circuit that feeds your dishwasher. It will also turn off the clean light. Wait three minutes and then turn the circuit back on. That should reset your machine.
Apr 07, 2009 | Electrolux Frigidaire Professional Series...
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
E20 During Drying Cycle
if the wash cycle runs ok then unlikely to be the drain pump or hoses. put drain hose into a bucket and check waster comes out during dry - it wont be large amounts of water. can you hear the drain pump running during the dry cycle?
Mar 08, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
KitchenAid KUDR01TJ Dishwasher Logo
249 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
