Question about Cameras
I have a DRC-TRV330 Sony Handycam. I want to use the ilink aka 1394EEE port to capture the contents of the Hi8 tape onto my computer. My computer doesn't see the camera in 'My Computer' as a drive
    Scholar:
  • 89 Answers
I will forward a link to a page where you can get the information about transferring the videos from the Camcorder to the Computer using the i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
Posted on Jun 17, 2009
I have a working TRV81 Hi8 HandyCam and 15 Hi8 tapes I'd like to convert to digital and make ready for edit on IMovie (Mac). Would appreciate any advice....
The only way to do that is to play it in a device that plays Hi8 tapes and somehow converts it to a digital signal (likely through firewire as DV), then capture it to your computer just like a digital camcorder.
There are several ways:
1. Buy a device (like a camera) that plays it, output through RCA cables to your other camera or tape deck that is digital through the line in, and then just record that. (Alternatively, you could put that signal into a DVD-R machine and record onto a DVD, then just copy the files off the DVD, if you don't have a way to capture DV through firewire.)
2. Buy a device that plays Digital8 (same tapes, but miniDV FORMAT) and output directly from the tape through firewire. This means you must buy a SONY (only brand that made [now discontinued] Digital8) camcorder or deck [if decks were made, though those are usually expensive].
So, the simple answer: get a Digital8 camera and capture, or get another digital camcorder and a Hi8 camcorder and play through the digital one into the computer.
Buying a Sony Handycam (OLDER model) will be your easiest option, and probably possible on ebay, etc., for $100-$200.
Short of this, you could look to a friend or a professional solution for just getting the tape copied (like VHS->DVD services exist, there is probably some place you can mail your tape to).
EDIT: I should add: You included "8mm" in your title-- that is a bit confusing. 8mm refers to a few formats. One is film (obviously not what you're referring to), but then there is the older "8mm" tape format; it's like Hi8, but I believe it's actually not the same tape-- unlike Digital8 and Hi8which share a physical medium. I don't think you can get an 8mm -> Digital device, so you'd need to go through the RCA cables, as described above. [And though Hi8 is actually 8mm in width, it's not quite the same as the other "8mm" format... for whatever odd reason someone decided.... frown.gif]
However, I suspect you ARE actually working with Hi8, so this shouldn't be a problem.
Nov 24, 2010 | Sony Handycam CCD-TRV81 Camcorder
How do i transfer the 8mm tape to a dvd using I Link?
Download the video to a computer that has an iLink jack.
Nov 08, 2010 | Sony Handycam DCR-TRV330 Digital Camcorder
Need software for DCR-TRV330
If it is a Sony camera, and you contacted Sony e-support, and all they did waws tell you that you need the software that came with the camera, tell them you realise that, but do not have it - can they send it to you / sell it to you? That is the problem. Idiots at Sony not wanting to help.
Good luck.
Apr 26, 2009 | Sony Handycam DCR-TRV330 Digital Camcorder
Problem with compatibilty between windows vista
since you're using vista you can connect camcorder to pc uding ilink or firewire cable. usb conection would not work. no dirvers or sofwtare needed, you can use windows movie maker to capture videos. check your computer for any ilink port. it is a different connection from usb. go to www.sonystyle.com and type this model number, vmcil4615, for you to have an idea what firewire cable looks like.
Mar 22, 2009 | Sony Handycam DCR-HC14E Mini DV Digital...
Unable to use firewire Sony handycam DCR-HC 54E (mini DV)
Anyone try this on Windows XP? Apparently firewire doesn't work with Vista.
Dec 10, 2008 | Video Cameras
Get video off Sony Handycam DCR-TRV118 Hi8 to PC or Mac
Hi There,
MisterSony is quite correct about the Capture card.
While most computers have the built-in ability to capture sound via the 'Line In' port, digitally recording the Video signal is a totally different aspect.
Certain TV Tuner cards also have Video Capture abilities (in addition to the tuner they have a VCR input). They often work in tandem with your Video Display card via the 'Feature' connector.
Both types allow the incoming signal to be displayed and recorded digitally at your choice of speeds, resolutions and formats.
My preferences in the past have been the VideoBlaster line by Creative Labs. There are many others.
I'll do a little research as to what's currently out there and post my findings directly.
Mike
Nov 01, 2008 | Sony Handycam DCR-TRV118 Camcorder
MY SONY DCR-TRV140E WILL NOT PLAYBACK MY OLD VIDEO8 (PAL8) TAPES?
Vista should be able to download this without any issues as it already includes the drivers. i was able to do this with my sony dcr-trv250 painlessly over the ieee-1394 (firewire) port using the DVD capturing bloat-ware (Ulead DVD creater) Toshiba had already installed for me. My toshiba satellite is running Vista Home Premium.
as regards analog hi8 playback, the product manual for the 250 says that this is NOT supported, i.e., it CANNOT play back analog hi8 tapes. Also, i wonder if PAL would be supported here in the US (assuming you're in the US, of course). I would expect only NTSC support. but it's a moot issue, since it doesn't play analog
Oct 03, 2008 | Sony Handycam DCR-TRV140E Digital...
Windows Vista Home Premium, USB2, iLink and Sony Camcorder
http://forums.microsoft.com/MSDN/ShowPost.aspx?PostID=2707538&SiteID=1
Jan 02, 2008 | Sony EZ Editor Home Editing Kit for Mini...
Can't use my Sony TRV22 miniDV camcorder to pass through and record Hi8 analog signal to my PC
Just below, they noted you don't put a tape in the TRV... Otherwise it outsmarts you.
Sep 13, 2005 | Sony Handycam DCR-TRV22 Mini DV Digital...
Cameras Logo
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
