Question about Karcher 2500 PSI Pressure Washer
I need a pump rebuild kit
I was wondering where I can kit a pump rebuild kit and how much do they run for? THank you.
Rebuilt carb. now have to have choke partially on in order for it to run what might be the problem?
could be the float level is too low or there is still a blockage ( corrosion ) in the idle circuit of the carby
discuss the problem with a service center for your make of motor as some kits for carby rebuilds are missing several small "o" rings vital for correct operation
Mar 31, 2016 | Boating
Need a rebuild kit for pump not motor
A O Smith does not make a Pump,
they make motors, so...
what pump do you have, so pump rebuild kit can be recommended?
Apr 13, 2014 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Where can I get a rebuild kit for pump?model XR-2600.
remove the pump and throw it away. Buy a better designed pump on eBay. just search your pressure washer model number or the obsolete rebuild kit part number a14292 you'll find the better pump.
Apr 03, 2012 | Honda Black Max 2600 PSI Pressure Washer
I need a rebilding kit for a.osmith motor mod c48k2pa105 1 hp 115/230
There are no rebuilding kits per say. Rebuilding a motor entails stripping it down and replacing what's bad. whole inside should be cleaned of debris, dust, rust etc. Almost always bearing are replaced. Armature, rotor and stator are cleaned, motor windings tested, start/run caps tested and replaced as necessary. Thermal overload, contactor, relay, centrifugal switch, etc, tested and replaced if needed. You can order bearings and capacitors from several places online, other parts can be harder to find. I local pump repair shop may sell you parts as well.
Jul 14, 2010 | AO Smith Pool Pump Motor 1HP Square Flange...
Not staying running seems like its out of gas and it is getting fuel it runs a short wile and dies pump the fuel pump manual pump and it runs for 2 min and dies agin
it sounds like the carb is gummed up you will need to remove the carb and clean it out with carb cleaner and rebuild it with a rebuild kit(it's a fairly easy job)...good luck
Apr 12, 2010 | John Deere 3010,3020 Tractor Basic...
Only runs on prime.....9.9hp
Sounds like the diapraghm fuel pump needs rebuilding. Fairly cheap and simple procedure. Get a fuel pump kit from your local outboard dealer and follow exactly how the old one came apart.
You may also need to get a carby rebuild kit and do that too if it has been a while. Again pretty straight forward. Take photos of carby as you re pulling it apart.
Both these plus a new set of spark plugs and you should be good to go on the water.
Jul 12, 2009 | Bass Pro Boating
Rebuild kit for the Aquascape SFA3000 Pump???
I have had the same problem everyone else has had with these pumps. I did serious research on these pumps and came up with a rebuild kit some parts bought some I make. I did mine 2 years ago and still working like a champ and have done over 20 locally with no problems. If your pump is noisy or the impeller has fallen off (typical) due to water getting in the unit and causing the bearings to fail email me and I can rebuild your pump. The process is simple send me the pump I will look at it and see if it can be rebuilt at NO CHARGE if it can be rebuilt you will save over 60% of a new one. Don't spend $349 - $599 on a new one let me look at it for free if I can rebuild it great if not you will have to buy a new one. I am not a dealer for any pumps so you will not have to worry about me selling you a pump and if you want the old one back pay the shipping and it it all yours.
Jun 18, 2009 | Ultra Max Aquascape AquaBasin, Pond or...
Is a master cylinder kit available for my '83 Suzuki Tempter?
you should be able to get a rebuild kit from m&p in swansea.try them on line to check or try robinsons foundries they run an ad in the mcn
Jun 14, 2009 | 1983 Suzuki Tempter GR 650
Karcher 2500 PSI Pressure Washer Logo
502 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
