Question about Kenmore 24032\24036 Top Load Washer
Machine fills up with water and got partway through the cycle before it shut off...when i went in the basement i smelled a slight burning smell and the washer wouldnt start up or anything i unplugged it, switched outlets, took out some clothes and then i let it cool off for a while.then it just made a buzzing sound when i tried to turn it on. is it the motor or belt? is there anything i can do myself or do i have to get it serviced?
    President:
  • 1,136 Answers
Hi, It does sound like the motor is locked up. The first thing you need to check is the pump. Sometimes the pump will get plugged so it will not turn in either wash or spin cycle. Does this sound like the issue you are having?
Here is some instruction on removing the cabint to check the pump:
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
Please let me know if I can assist you further.
Vic
Posted on Jun 20, 2009
Nav5800aww
The motor sounds like it is overloading and kicking out. Most likely cause: binding brake pads.
Sep 13, 2013 | Amana NAV5800A Top Load Washer
Washing Machine shuts off by itself during cycle
Not sure what you are saying.. if washer is off balance, it will shut off, check legs are secure to floor and unit is leveled. If washer lid isnt sealed or lid switch is bad it can shut off at spin or start cycle. Depends on unit model. The smell can be a burning belt from a heavy wet comforter or you have mildew from water not properly drained from unit.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a fisher paykel GWL10 washing machine. It shuts off while
At this stage i can suggest that the inlet valve may be faulty & giving off this burning smell.open the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Jun 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
Washer won't do anything but fill.
It is very likely that the motor has burned out. What happens is that the water solenoid allows water to fill to a certain point where a fill sensor stops it. The program then moves on to activate the motor which will agitate the wash. So when power is supplied to the motor, it tries to start, overheats because of a break down of insulation in the windings, and you smell burning. Replace the motor.
Nov 18, 2009 | Maytag Atlantis MAV6260AWW Top Load Washer
Fisher & paykel GWL11 washer won't rinse
sounds like you have two problems, the burning smell is probably the pump,out of balance is usually due to worn aout suspension rods
Oct 14, 2017 | Fisher and Paykel GWL11 Top Load Washer
Agitator no longer moving
sounds like you may have burned out the lid switch. if it is not working the timer thinks the lid is not closed and will not advance.
Oct 04, 2009 | KitchenAid KAWS850L Top Load Washer
Whirlpool Ultimate Care II washer went dead during fill cycle
Start with the capacitor. It has a funny smell when they go bad. The motor will smell bad as well when it burns up.
May 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Model 24642300
It is usually a coupler, look under to see if black shavings
Oct 20, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
67 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
