Question about Garden
How to change air filter on Snapper Model MRP216014B?
  • 376 Answers
It should be on the right front side behind a flat vertical cover with a 5/16 screw at the top.
Posted on Jun 18, 2009
22' snapper walk behind mowewont start .cleaned spark plug and still wont start .swapped spark plugs from another mower that does work and the other mower starts with the snapper mower's spark plug .
You need several things for a running internal combustion engine:
  • Air
  • Spark (to start)
  • Fuel
  • Compression
  • Lubrication
  • Exhaust.
You've shown that you have a workable spark plug so far. Going from the above, consider as well
  • Fuel. Bad / old / contaminated fuel. Clogged fuel filter. If it's a motor that needs gas/oil mix, does your gas have the right oil mix?
  • Air: Dirty, clogged air filter or air inlet.
  • Spark. Is any electricity making it to that proven-workable spark plug?
  • Compression. For this one, the most likely problem (other than a toss-the-engine thing like a broken piston) would be if the spark plug is not tightened into the mount hole, allowing the air to leak out rather than compress.
  • Exhaust. Most lawn mowers will have a spark arrestor on the exhaust to make sure you don't set a dry yard on fire with your exhaust. It's often overlooked in diagnosing two-stroke engines. Make sure it's not clogged or blocked.
  • Lubrication. Is there oil of the right type, and up to a proper level on the dipstick. No oil equals way too much friction in the engine.
Good Luck!
DH
Apr 25, 2016 | Snapper Garden
On the Zero turn mower , how do you relieve the air in the pump lines after replacing a bad pump . Please advise.
How To Release Pressure From Fuel Lines - YouTube
? 0:51
www.youtube.com/watch?v=6oo9zlTMPOQ
Oct 15, 2009 - Uploaded by YeechBlitz
See a demonstration on how to release the pressure from fuellines of a 1997-2000 ... in the tank, but do not let the air out, so pressure can build up in there. ... Diesels is where you want to be extra careful, the injector pump to ...
5900748 Snapper Zero Turn Mower - Hammerwall
www.hammerwall.com/.../Snapper/.../5900748/Snapper%20Zero%20Tur...
Back To Snapper Tractors-Riding-Lawnmowers Model: 5900748 Snapper Zero ......Reinstall each mower blade with the air lifts pointing up towards the mower deck ... The fuel filter is located in the fuel line betweenthe fuel tank and fuel pump . .....TROUBLESHOOTINGTHE RIDER PROBLEM CAUSE REMEDY Enginewill ...
Sep 25, 2015 | Briggs & Stratton Snapper 5900748 355Z...
725 ex briggs and stratton
Might be the carburetor or air filter dirty. Need right amount of air to mix with fuel at the right time.
To service these best to check this video out. Yours may not be the same exact model but gives an idea.
REPAIR BRIGGS STRATTON LAWNMOWER TUNE UP CARBURETOR CLEAN
Sep 01, 2014 | Snapper Garden
Chainsaw will only run with choke on and cant get it to idle back
there is a jet inside the carb that is plugged up leaning it out
Aug 18, 2012 | RTO Spur Sprocket For Stihl 017, 021...
Garden Logo
343 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
