Unable to use reverse cycle as I have no instructions for model LS 1108V Teco a/c
3 Suggested Answers
  • 70 Answers
SOURCE: installation manual required for teco split
Is the unit an AC only or a heat pump?
Wiring to the units should in the manual or online.
Both units proper house voltage to inside unit and outside unit.There will also be a two wire low voltage cable between thr two.This is so the inside unit can turn on the higher current draw of the compressor in the outside condenser unit thru it's relay.If you have a heat pump there will also be a set of two wires to the 4 way gas valve in the condenser unit to change from heating to cooling mode,a set of two wires to control the on/off function of the fan in the condenser unit when it needs to defrost and mayby a two wire set to a themal sensor in the condenser to sense if it is frosting up when system is in heat mode.
Try to get a wiring diagram and if you can't get to the point where you understand how to wire the unit don't guess! Call someone who knows wiring or call a pro, he can you money over the cost of replacing parts if unit is miswired.
Posted on Oct 06, 2009
  • 415 Answers
SOURCE: TECO AIR CON SYSTEM MANUAL
Perhaps the manufacturer can assist you with obtaining an electronic copy. Try this link:
http://www.teco.com.au/component/tecofaq/?search=show&task=showcatid&from=browse&divisionname=+Household+Appliances&categoryname=Air+Conditioning
Posted on Feb 25, 2010
I have a teco air con model LA0814C i attempt to set temp to 23 on cool and it just keeps going back to room temp and won't cool ?
Best bet is to call Teco tech support. It looks like another rebranded gree or shinco unit to me. Since teco is still in business, they should be able to help you figure out what's going wrong.
Contact Us
Please mark his answer as helpful.
Jan 06, 2015 | Heating & Cooling
Teco inverter airco LT404y will not go to heat cycle anymore why not must be a valve
The thermostat may be bad or the change over valve in the outside unit has stopped working.
Oct 15, 2014 | Heating & Cooling
Teco air conditioner LS1826H fault code F2
F2 on this model means that the indoor unit pipe sensor has failed. You would probably need someone who is at least a licences electrician or preferably an Air con tech to repair this. You will need a new pipe sensor. Contact Teco Australia who can put you in touch with your nearest service Agent.
Sep 09, 2013 | Electronics - Others
Installation manual required for teco split aircondtioner. Reverse cycle LS0909Y. I have operation manual but not sure how to install and wire up. Many thanks.
Oct 06, 2009 | Heating & Cooling
My battery seems to be very low in my key for my 1998 lexus ls 400. Can I replace the battery myself or is it tricky?
Usually not. Disconnect negative battery terminal, then positive. Next remove battery hold down (type is specific to car model). Battery then lifts out and replace with correct new one. Install is reverse.
Jul 12, 2009 | 1998 Lexus LS 400
I need operating instructions for a teco air con model LT2424YS
I have an TECO Model 7K34STC, that has the two end bearing & housings missing from the opposite end to the motor.
Could anyone tell me of a parts supplyer in Florida U.S.A.
Please reply to
Peter Lawrence
brin4512@hotmail.com
Jun 28, 2009 | Heating & Cooling
BROKEN TECO TV
Can't solve this problem (my power supply has gone as well!) but I have a contact at head office. Unfortunately it's in Tawain. Try Company: Teco Electric & Machinery Co., Ltd.
Address: 6F., No.49, Wugong 6th Rd., Wugu Township, Taipei County 248, Taiwan R.O.C.
Contact Person: Amanda Huang ext.1301 / Sales Specialist
E-mail: amanda_huang@teco.com.tw
Anyone know where I can get hold of a new power supply without going through Teco?
Dave...
Mar 28, 2008 | Televison & Video
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
