Question about Vizio SV470XVT 47 in. LCD TV
Vizio SV470XVT1A makes screeching sound
Vizio 47 inch 120hz SV470XVT1A
Ive had this for four days. The first day after about 20 minutes of being on for 15-20 minutes it made a short loud staticy screech sound for about a second and the picture screwd up with colorful lines all over the screen. the remote wouldnt turn off the TV, I had to unplug it. when plugged in and turned on again it didnt happen any more that night and the TV was on for hours. This has happened twice since, within an hour of turning on the TV, only the second and third time, the sound didnt stop until it was unplugged.However one day it didnt do it at all. Otherwise the TV works perfectly. I still have time to return it, but I am thinking perhaps maybe it is electrical interference? Id rather not have to return it, this would be the second time exchanging it
  • adetmar1 Jun 17, 2009
    For more information, I have it plugged into a Dynex power barhttp://www.dynexproducts.com/pc-333-6-dy... with nothing else plugged in to it. The only input source is my computer in the HDMI slot 2. If there is nothing I can try short of having someone come in and repair it, I will just echange it instead
    Genius:
  • 1,139 Answers
This sounds as if it could be a ballast problem, or a switching power supply transformer problem. Both of these can produce this sound. I would suggest that you have a qualified TV technician repair this set due to the dangerous voltages and currents that could be present. In my experience with these TV I would have the technician pay special attention to the power supply board and the backlight/inverter section which includes the ballast used to fire the backlight.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jun 17, 2009
    New Friend:
After a couple of years the Power supply and Inverter board capacitors are bad. This is common on most all LCD Tv's and monitors.They use cheap ones when made and can be replaced with better quality ones. Have a experienced technician check for bad cap's change them out.
Posted on Dec 24, 2012
My vizio will not turn on. The light on the bottom flashes on and off, but nothing on the screen. I replaced the main board. It worked for several days then went right back this issue.
Have just looked on you tube , I typed in fix for VIZIO E500i -B1 power off and a 2.24 minute video appeared . if that does not solve your problem type the product info and fault again and check the videos that pop up . hope this info is of use to you....
Dec 20, 2015 | Vizio 50-Inch LED Smart HDTV 1080p Full HD...
How to test a vizio main board.
It is no easy to check the main board without proper equipment. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 13, 2015 | Vizio E3d470vx 47 Inch Class Theater 3d...
I have a Vizio SV470XVT1a. When I turn the tv on I may get a normal picture for a minute or two then the screen goes black or I will have a greenish or pinkish screen. I continue to have sound. Afte
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 10, 2017 | Vizio SV470XVT 47 in. LCD TV
47 Vizio SV470XVT1A will not turn on
Check and replace its main power regulator board as card basis.
Sep 30, 2012 | Vizio L32 32 in. LCD HDTV
Turn on TV and picture and sound are great for about 60 seconds. Then the picture disappears but sound remains.
I would start with checking the power supply 12vdc output, make sure it is stable with no ripple. If the power supply checks out fine, I would then suspect the main board.
Sep 20, 2012 | Vizio VT470M 47-inch 1080p 120Hz 5ms LCD...
47" Vizio Flat screen HD LCD freezes up and remote will not work.
could it be Ch 9's digital signal is not broadcasting right? what is your refresh rate on your tv? 60 or 120hz? if its 120hz, then its more then likely the digital broadcast, if its 60hz I think its your tv can't keep up with their signal that may be at 120hz. Make since??
Jun 16, 2009 | Vizio VO47L 47 in. LCD TV
When my tv is on for about 15 mins the borders turn green. I have changed the hdmi cable and it hasn't fixed the problem. My tv is a 47" vizio 1080 and it's only 4 or 5 months old. can you help?
something is wrong call vizio i bought the same tv two days later all of the color on the screen that should be black is green called repairman who came tv was working and after he replaced the mother board and daughter board tv was black turned on but no pic he tried again and i heard the arching sound he zapped it i was told by repair we need to order the power board it willl be another 3 to 5 days
i called vizio the minute that he left i was so pissed and that is not like me they are sending a new tv that was thursday i still have to wait 7 to 10 days but they are standing behind there tv i will give them that
Jun 04, 2009 | Vizio SV470XVT 47 in. LCD TV
Vizio GV47L FHDTV10A
sounds like a lamp failure.
Dec 03, 2008 | Televison & Video
Vizio SV470XVT 47 in. LCD TV Logo
1,191 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
