Question about Maytag Neptune MAH5500B Front Load Washer
I have a burned out resister which I need to replace.
I own a Maytag front loader washer, model no. MAH4000AWW. Resister no. R11 which is located on the "household machine control board" [Maytag's name for this control board], which board I have learned is identified as part 22002989, has burned up completely.
Its resistance code is no longer identifiable. Moreover, I have been unable to locate a circuit diagram for this board. Could you please tell what the actual resistance of resister R11 is so that I can replace it.
R11 = 3.9 K ohm 1/4 w If Q6 burned,change by NTE5657 ( 600v)
Posted on Jun 17, 2009
Maytag 2000 drains all water and spins but spins slow
two things, first one is could be the r-11 resister on main board burned or a tub bearing . check the main board inside touch panel. on it is a resister that tells computer door lock is or is not latched door lock light may be lit but computer indicates not and will not advance to max spin. if resister is burned and board is replaced be sure that you replace the wax motor door lock motor as well. if you don't replace locking motor you risk burning out new board again. tub bearing is easy to find out. just lift basket at top with finger and feel for vertical movement of basket alone,"slop" or "movement up/down. if so then replace the rear tub shell and spinner for basket . hope this helps.
Apr 18, 2014 | Maytag Washing Machines
Neptune front loader. doorlock light quit working. wont spin.
You will need to change the machine control board and door lock wax motor.
MAH3000AWW PART # 'S 22002988 AND 12002535
MAH4000AWW PART# 'S 22002989 AND 12002535
If yo look at your control board in the control panel you will find R11 burned.
Jun 10, 2011 | Maytag Washing Machines
My maytag MLE2000AYW will not lock, how hard is it to replace or fix?
I would be concerned about your door latch wax motor ( part # 12002535) though... See Neptune Help for more information about replacing the faulty wax motor with brown colored actuator tip before it damages your machine control board.
When the wax motor shorts out it will blow the Q6 triac and then the R11 resistor will burn and your door probably won't lock anymore as indicated by the door locked light not coming on. The next thing you will notice is that your clothes will be soaking wet after the wash cycle because the spin cycle will not work if the door does not lock...
Your machine control board is located above the dryer on the right side.
Every Maytag Neptune front loader with a timer knob (non digital) has a wax motor and all of them shipped with faulty one except the later 2000 series stacker models. You should proactively replace the wax motor with the new design (with black tip) to prevent the Q6 R11 failure on the control board. If you're too late you can try the STAGE 1 repair kit at the same site above.
To inspect your door latch wax motor on the stackers you:
  • Unplug machine
  • Remove the (2) screws holding center panel and remove panel
  • Remove the (1) center screw holding the top panel located inside compartment above washer
  • Remove the top panel to expose the door latch assembly
    I hope this helps you.
Mar 27, 2011 | Maytag Neptune MLE2000A Front Load Stacked...
Not spinning on spin cycle, also not draining all water during spin cycle
does the door lock?
if no remove the screws from the top of the consol and locate the control board....towards the center left look for R11 location on the board it is a resister is it burned ? if yes you need to replace your board and your wax motor in your door lock assembly.
let me know what you find
May 10, 2010 | Maytag Neptune Washer
I have a Neptune front loader that now spins slow on the final spin. Pushing max extract doesn't help. I need help - -wet sheets
does the door lock? if the answer is no then you have a blown resister on your main control board R11 and the reason it blew is your wax motor on your door lock is binding up. you need a new control board and wax motor.
Jun 15, 2009 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune MAH4000AWW
if r 11 is bad you should really check the bearing on the tub you will probably find it to be bad or going bad causing the moter to pull more amps causing r 11 to burn out.
Jan 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Machine stops on it own
Take the board out and flip it over and check the r11 resistor. It is usually burned out.
Nov 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag front lead stackable
That is correct. Take the screws out of the console up top. look for a burn mark on your circuit board. If it's on R11, replaced your door lock wax motor as well at the board.
Jun 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
232 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
