Question about Mitsubishi WD-52725 52". Rear Projection HDTV
My mitsubishi 52725 shuts itself off after acouple hrs
Th tv will shut itself off anywhere from 5minutes to 6 hrs of great operation then the blinking green light appears. I have to unplug wait then plug it back in wait 60seconds till it stops blinking green and then the process will be repeated in a short time and is very annoying and frustrating. I have replaced the 12 bad caqps and installed a dpdt switch made the picture cleaner but still shuts down im about to throw this thing out the bed of my pickup going 80 down the freeway, would be cool:) to see
  • Mitsubishi Master
  • 8,617 Answers
Its most likely the thermal fuse which is causing the problem. It gets up to operating temp then shuts down.
Posted on Jun 17, 2009
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
WD-62526 shuts off
The power supply is failing. Your TV is able to start but the power supply can't continue operating and shuts down.
Dec 12, 2013 | Mitsubishi Televison & Video
Posted a short while ago but have more information Mitsubishi DLP WD 52725 - sound no picture - blinks 3 short times and 1 long time
have you checked the lamp? with those models they will power up and if the lamp is bad you can hear audio until the tv shuts off. the lamp is located in the front behind the speaker grill assembly. if the "status" light is blinking then you are having a fan failure if the "lamp" light is on then check the lamp like i listed above.
Jan 06, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Have a Mitsubishi 52725 52" DLP The TV shuts off frequently. It tells you "the TV with shut off in 30 seconds". It seems warm but I have a fan in the rear to cool it down but sometimes it still...
does it give you the "airflow" message?
if so it needs a new thermal sensor by the lamp, known issue defective sensor..
if not, suspect bad capacitors
there are many bad caps across 3 board , all part of the chassis.
a repair center will ship the chassis into mits for rebuild, about 400 or 500 total bill
May 21, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Tv won't power on
I trashed the set and bought a new one.
Jul 02, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Blue Screen and then shuts off.
Is the LED blinking a 2 digit code? Let me know mitsubishi will blink a repeating diagnostic code when theset goes into shutdown. Which is what your set is doing. let me know if you can distinquish a blink code from the LED.
Feb 05, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Flashing green button, won't reset or turn on
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
Dec 18, 2007 | Mitsubishi WS-65513 65" Rear Projection...
TV just shuts itself off after 1/2 hr to 2 hrs ...
resolder the horizontal driver transformer and all of the coils that start with "L77xx" on the left side of the sweep board, there is also a jumper staple just above L7711 that must be soldered it does not have a designation number but you`ll see the solder is bad on one end, very common issue with your model.
Nov 29, 2007 | Hitachi 50UX57B 50" Rear Projection...
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
291 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
