Question about Panasonic KX-T7730 Corded Phone
KX-T7730 phone. Need to reprogram one of the PF buttons as a CO2 button. I accidently messed up the programming of this button while trying to program a different PF button as a one-touch dialing button...
  • gulaslamkhan Oct 23, 2009
    sir i have deleted the co2 but i forgot the co setting .please tell me brief how can i replace co2
  • Panasonic Master
  • 2,460 Answers
Just so we're on the same page, the PF buttons are the 12 buttons on the right and their ONLY function is one-touch dialing. They can't be CO buttons. The 12 buttons on the left are called CO buttons and they can be programmed to do a number of things, including CO, DSS, and feature access buttons.
To reprogram the button, press PROGRAM, the button, the dial 0 + the CO number (1-8) and STORE. Extensions are 1+ext and one-touch are 2+. Other features are in the programming guide.
The PF buttons are programmed by just dialing the digits, but if it calls out, you must dial an access code first, usually "9".
Carl
Posted on Jun 17, 2009
Determining which CO you get when pressing 9
Set outgoing line preference.
Or simply swap the CO1 and CO2 line plugs.
The plug from your service provider that enters in CO1 put it in CO2 port and vice versa.You may need alittle config as well.
Oct 26, 2012 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    Our office pabx is a Panasonic KX-TA616. I am trying to program personal speed dial on a Panasonic KX-T7730 (which has 12 CO buttons on the right but no Personal Feature buttons). Neither of the...
    Look carefully at the part number on the phone and where you posted. A Panasonic 7730 set has 24 buttons, 12 left side C.O. buttons and 12 right side PF buttons. A TA30830 (new style) has 12 buttons with LED's. In our country, the TA30830 needed 824 version 2 or greater software to work.
    In your country the other mate to that is the KXT-7667.
    If your phone is one of those and actually works, as in any Panasonic set, the LED buttoon requires a "2" in front of the digit sequence to tell the system it's a PF button.. So, PROG button 2+access code+number STORE saves a speed dial. The access code is what you dial to get an outside line.
    Carl
    Jul 06, 2011 | Panasonic KX-T7730 Corded Phone
    I had a KX-T7730, i have 2 line and use to be store as CO1 & CO2.. then other time when i try to store a speed dial.. everything got mix up.. now when i colleague hold a call, i can't pick up the call...
    From the idle phone, press PROGRAM the button where line 1 used to be and dial 0 1 STORE do the same for line 2 if you unprogrammed that, using 2. Press PROGRAM or pick up the handset and drop it back down to end programming
    Carl
    Apr 18, 2011 | Panasonic KX-T7730 Corded Phone
    My problem was i can not enable the co2 flexible button how to enable and disable the button or assign
    I think you unprogrammed a button. Press PROGRAM and the button and read your display. It will either tell you what it is or be blank. To make it a CO button for lines, dial 0 + line number STORE.
    Nov 01, 2010 | Panasonic KX-T7730 Corded Phone
    HOW TO PROGRAM ONE TOUCH DIALLING FOR KX-T7730 WITH CO BUTTONS ONLY ON THE RIGHT?
    So that we're on the same page, a 7730 has PF bottons on the right and "CO" buttons on the left. If you have a different phone, like a TA-308xx or a Euro phone that isn't offered in the U.S., then it may only have a single row of buttons.
    Programming is the same. If the button is a CO button (with a light), then your one touch requres a "2" in front of it to speed dial a nunber and a "9" or outside line access code to dial an outside number. So, to call 212-555-1212 you press PROGRAM the CO button, 292125551212 STORE. An inside number is stored under the CO button with a "1" plus the extension number.
    A PF button already has the assumed "2", so you would just dial 92125551212 in the example above.
    Carl
    Dec 13, 2009 | Panasonic KX-T7730 Corded Phone
    Programming extensions in the phone
    If you have manual(z), they should. One, the OM (operating manual) will tell you how to set up your personal programming.
    The buttons on the left side of a 7730 have lights, the buttons on the right do not, so they are programmed differently. Left side is DSS, right side is PF (personal feature). If you have spare left side buttons, press PROGRAM the button and dial 1 plus the ext number and STORE. The light will now follow the activity of the extension you programmed.
    The buttons on the right have no lights, so you can only put in extension speed dial numbers. For that, press PROGRAM, the button, and dial the 3 digit extension number and STORE.
    Depending on the system your phone is connected with, you can just press the button to dial, or you have to pick up the handset or SP-PHONE and select intercom (if not selected) and it will dial that extension, or if the system is a TAW, TD or higher, just press the button.
    Carl
    Dec 03, 2009 | Panasonic KX-T7730 Corded Phone
    How to store numbers for speed dialling on Panasonic KX-T7730 having only 12 CO buttons.
    Well let's see. You have 12 CO buttons and 12 PF buttons, and at least 100 system speed dial numbers available.
    Which ones are you looking for?
    Depending on what Panasonic system you're connected to, the PF buttons program by pressing PROGRAM and the button, and dialing the number with a "9" or trunk access code in front of it then STORE. If you're connected to a TD system it's PROGRAM 99.
    System speed dial numbers are entered from the main or manager's phone under system program 001.
    Carl
    Jun 28, 2009 | Panasonic KX-T7730 Corded Phone
    How to program the phone
    simply press prog. button then press 1 of the 12 button press 0 then press 1 if its for button 1 and so on, and dont forget to press store button after each button is program.
    Jul 07, 2008 | Panasonic KX-T7730 Corded Phone
    Need to program pf buttons on kx-t7730
    Press Program Button
    Press Button to be Programmed
    Dial 1 - Plus extention number to be stored on button
    Press button directly under 'ENTER'
    Feb 12, 2008 | Panasonic KX-T7730 Corded Phone
    Panasonic KX-T7730 Corded Phone Logo
    588 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
