Question about Brother HL-2040 Laser Printer
Red "Paper" light blinking Brother HL-2040
Just started happening.
No paper jams, checked every possible nook and crevice in the printer.  Took out the toner, drum, etc.  Turned the printer upside down, shook it, cursed at it, but no luck.  Tried it with the paper tray full and almost empty.  No go..
When trying to reset, all lights go on in proper sequence, fan runs, "Ready" light goes on for a second and then goes off - the red "paper" light then starts blinking.
Any ideas?  Thanks.
  • 20 more comments
  • SpartanSteve Nov 16, 2007
    Ink cartridge light blinking - got a dialog box that said color cartridge needs replacing (empty ink, etc.) so I replaced the cartidge with a new one (removed the clear paper tab) and the light continues to blink. Aaagghhh!
    If I remove the color cartridge it will print in b/w.
    What gives?
  • Anonymous Nov 23, 2007
    Bloody hell yes. Paper light flashing. Exactly what happened to you. How the hell did you fix it.
  • River123 Dec 18, 2007
    Same problem - see my below solution which I accidentally posted...
    Anyone have the solution? Please?
  • Anonymous Dec 23, 2007
    THE RED LIGHT want stop blanking
  • testtest Jan 03, 2008
    don't throw it out yet. Here is how I got mine to work: flip down the back cover and lower the flap that covers the rollers. On the inside of that flap, right in the middle of it, you will see a small, one inch long lever that helps keep the paper up against the roller. This lever was moved to the left a bit to far, so I nudged it to the right. As soon as I did this, the light stopped blinking and the printer worked.
  • garvus Jan 03, 2008
    Just got a used HL 2040 from ebay. I turn on the printer... fan starts, ready light goes on for about 3 seconds, then a light "chug" sound comes from the toner drum area and then the RED PAPER LED blinks. None of the paper wheels spin.
    I turned on the printer with no toner or drum and the printer wheels spin, the printer comes to life just fine. I try to print a demo page and then the solid yellow toner light goes on (obviously)...the second I put the toner/drum back in the red blinking light starts again!
    AHHHHHH! I bought this printer for my special school for poor kids and I am beyond angry that my students have to suffer because of this! Please HELP!
  • Sharjo Jan 08, 2008
    I've got the same problem and have tried the same things. GOld paper light flashes and status light stays red (should be green i think)
  • Anonymous Jan 14, 2008
    I have the same freaking problem....how do you correct it
  • dkskkw Feb 09, 2008
    The printer ran out of paper. I filled the paper tray and Red Paper lights keeps flashing and won't reset so I can printer. I tried unplugging the printer checked the spool to clear any documents that failed to print. I don't know what else to do.
  • Anonymous Feb 14, 2008
    my printer says paper jam ,no jam and will not print any thing
  • suillus Mar 06, 2008
    same problem - red paper light flashes, no paper is jammed.  Turning the printer off and on doesn't reset it.  Reloading the paper doesn't either.  The printer utility says the back door is open, but its not.
  • tricefarm42 Mar 29, 2008
    I changed the ink cartiages and the light continues to blink and the E in count area
  • Anonymous Mar 30, 2008
    I've tried everything that everyone has said on the site yet it still blinks the red paper light. any other ideas before i throw it out the window?
  • Anonymous Jun 11, 2008
    I had the exact same problem. I blew a fuse in my house and then it started blinking.. after reading the remedy on this webside, I took out the drum and did wind up seeing a stuck sheet of paper inside that was not visible from opening the back door. It must have jammed when the printing simultaneously and blowing a fuse.
    THANK YOU!!!
  • christy888 Jul 14, 2008
    Printer had a paper jam. Second one today. This time there was one page stuck inside the printer and barely visible through the back door. All jams are cleared, more paper was loaded, printer turned off for few minutes and turned back on, several times. The red light still flashes. Is there a reset button somewhere that I'm missing?
  • Jack Davis
    Jack Davis Sep 21, 2008
    I have been to may websites and this one is the best. The problem with mine became evident when I removed the toner and drum assembly. There, within the bowels of the machine was a crumpled sheet of paper. Completely invisible before I removed the toner. I pulled out the paper gently and then washed my hands (it was covered with toner dust) and then when I plugged in the printer it printed out all the pages I had been trying to print out yesterday.
  • flamuri69 Oct 07, 2008
    i can print, but i can't copy! there is a message "drum empty" and also there appear a red light, and so.
    I hope u can help me as soon as possible.
    Thank you!
  • erosenau28 Oct 29, 2008
    I have refilled the paper drum and clicked the Ready button but the light keeps flashing and will not print. Why?
  • sylmarie Nov 09, 2008
    I changed the toner and start the red light blinking
  • Anonymous Jan 20, 2009
    Red light is blinking. No printed paper comes out. The cartridge was replaced last July. Printer is Brother HL 2040
  • Anonymous Feb 18, 2009
    i just put some more ******* paper in my printer but the god dame lights keep blinking......... any ideas on what i should do
  • Peter Maxwell Jun 28, 2012
    Had exactly the same issue, and had opened the back door, but on the first look not noticed the screwed up paper that had virtually jammed between the orange roller and the hinged deflection guide. After reading the cures below I took another look, before trashing the 2040, and there it was.....all working now, and no real use for the new printer I purchased today!!! Great site.
I agree with another su=olution. The paper light was blinking on and off sugesting a paper jam. Paper had jammed in the back roller and displaced the small lever out of its slot.
Open rear cover, open paper guide by pulling it downwards so you can see the rollers, In the middle of the guide you will see a black lever about 25mm long to the right of this you will see a small slot. The guide will have been pushed to the left of this slot and the Plastic cam will be bowing toward the front of the printer (about 3mm). You need to pull the 25mm lever towards the rear of the printer and then slide the plastic cam to the right so the blade part of the cam slides into its correct slot. The blade is about half a mm thick and the slot is the same and is about 60mm to the right of the lever Use a torch to see it easier. This is a 2 minute job once you see what is wrong.
Hope we have helped someone out there fix a printer
Posted on Jan 19, 2009
  • 7 more comments
  • hiace28 Sep 18, 2010
    Thank you Pat Malone - you are one clever f$%^
  • John Jury Nov 22, 2011
    Thanks Pat Malone - I was ready to throw my 2040 on the trash heap. Despaired who to contact for a fix and went to google, found your solution and opened the back, with 30 seconds printer back with green led ready to go. You're a champion!
  • nboutko
    nboutko Jan 19, 2013
    omg thank u so much!! saved my printer! (:
  • nboutko
    omg thank u so much!!! (:
  • Deborah Sweeney Feb 11, 2013
    I love you man, this worked perfectly!! To clarify the level is attached to a horizontal rod. I was able to shift that whole thing (had to apply a bitof pressure) and then the lever laid down in the obvious slot. This saved me a printer thanks!
  • bienbravo Mar 26, 2013
    Thank you Pat Malone. Worked like a charm!!!
  • Enrique Sosa
    Enrique Sosa May 23, 2014
    you are good!!! thank you so so much
  • Anonymous Nov 05, 2017
    Pat Malone - you are a genius!
  • Anonymous Jul 01, 2018
    Great solution! Solved my problem. I am adding images to illustrate the description. (By the way, the back cover and the black paper guide are easy to remove to work more comfortably. Remove the paper tray first.)
Alright, I had this same exact problem and have tried darn near everything. I even called brother to no avail. HOWEVER i have solved the problem with help from Fixya. Here are a few steps to take.
First take off the front cover. Pull the tabs on the side. Pull out the big toner and cartridge. Do you see the blue tab? Slide the tab from right to left 30 times. Pull out the black cartridge and check for a paper jam. Replace the cartridge and toner and reinsert into the printer. Turn the printer on and see if the light goes on.
If that doesnt work, open the back cover and pull down the black cover to see if there is any paperjam on the roller.
Turn off your printer. However you are connected, whether it be usb or other please unplug. Hold down the go button and turn the printer on. Keep the go button down the whole time. All led's should be lit. Release the go button. Let the printer do its thing for a second. Hit the go button 8 times exactly. This resets everything. Plug your usb or other back in.
If this still hasnt helped, and it didnt help me either you can try one last solution that i got from here.
Open the back cover again and pull down the black cover. Do you see the little one inch tab holder in the middle. Keep an eye on your paper light and move it to the left and push it up to the roller, if that doesnt work move it to the right and then push it up. Keep an eye on the red paper button. I fiddled and forced the tab to the left and boom i saw the green ready light go on. YES!!!!!!! Flipped up the black cover put the back cover up and Im back to printin.
I know other will benefit from this so i took some time and posted my solution. Good luck guys. Happy printing.
Posted on Jan 10, 2008
  • joeyvee
    joeyvee Nov 18, 2012
    That worked! Thank you!
  • Jaci Wollenberg
    Jaci Wollenberg Feb 03, 2014
    Thanks, Tdogg23! Your solution was not exactly what we needed, but it put us on the right road. The 1" black tab in the center has a spring that must somehow affect the sensor, and the spring was just floating free along the rod to the left of the tab. We slid it to the R and put the R arm that was sticking out in the slot and bingo, we were in business (obviously, we'd unplugged before doing this!) You will need a flashlight and probably someone to hold it.
  • 22 Answers
I found just doing this one simple thing sorted the problem.
First take off the front cover. Pull the tabs on the side. Pull out the big toner and cartridge. Do you see the blue tab on the top shaped like an arrow/triangle? Slide the tab from right to left - reinsert toner close door.
Hope it works for you
JPW
Posted on Oct 30, 2008
  • Tyronne Jul 18, 2013
    Thanks JPW it works amazing I tried almost 2 months and almost dump the printer. Fantastic solution well done!!!! Thank you again hoooooooooooray
  • Cristina M. A.
    Cristina M. A. Aug 18, 2016
    YESSS!!! Thanks a lot, it worked perfectly :))
OK, this may not be a printer problem. I've been having the same issue with my brother HL-5250DN printing out a word document. After getting to the brink of despair, I tried printing a different document, and that worked fine.
The document that wouldn't print was a job application form with lots of complicated tables and locked fields. I suspect that the page dimensions on the document were set up incorrectly, but as they were locked, I couldn't print. So the problem was with the document, not the printer.
So what to do if you want to print out such an awkward document? What I did was download a PDF converter - for example Primo Pdf (http://www.primopdf.com/) or better still the open source PDF Creator (http://www.pdfforge.org/) - installed, printed the troublesome document to a PDF file (using the print option in Word), then printed out the PDF file to the Brother printer.
Hey presto!
Good luck,
Will
Posted on Apr 15, 2008
I was printing labels. The red light would instantlty come on with the blinking amber paper light as soon as I clicked print.
All my problems were fixed when I unplugged the USB and power for 10 seconds to clear the memory from the previous print job and used the front tray.
Posted on Dec 13, 2008
My 2040 had the same blinking light issue. I have a solution that worked! I fed one sheet through the front of the unit (where you could put in larger paper or one sheet at a time) Then magically it started feeding from the tray. Now it works fine!
Posted on Dec 27, 2007
  • pinquin May 05, 2011
    it works . Thanks
The document you are trying to print is being sent to the MANUAL paper feed, instead of the auto paper drawer.
I had this same issue and could not figue it out for a long time. I would have to shut off the printer, dissconnect it, clear all print jobs and restart the printing. Then it wouldl happen again with this one document I was trying to print. Then I remembered that I had set that document to use the manual paper feed on a different printer (in MS WORD printing options). The document was a form which I USED to have to inseat in the manual feed on the old printer. But I had made some changes and no longer needed that manual feed.
Anyway , the doc was still set to go to the manual feed, I changed it in WORD and it worked fine.
I'm not exactly sure how the manual feed works. Once I figued out what it was doing, once the red light blinks, even if I open the manual feed and insert a sheet of paper, it won't print. I guess I'll play with it more to figue out exactly WHEN it wants me to insert the paper.
Hope this helps.
Posted on Dec 19, 2008
Don't throw it out yet. Here is how I got mine to work: flip down the back cover and lower the flap that covers the rollers. On the inside of that flap, right in the middle of it, you will see a small, one inch long lever that helps keep the paper up against the roller. This lever was moved to the left a bit to far, so I nudged it to the right. As soon as I did this, the light stopped blinking and the printer worked.
Posted on Jan 03, 2008
  • fliang1 Jan 02, 2013
    That was exactly what my issue was. This fixed the problem! Thanks!
THANKS MY PROBLEM IS SOLVED THERE WAS A PAPER JAME WITHIN THE DRUM AREA OPEN UP THE DRUM AREA BY REMOVING THE TONER CARTRIDGE AND IT SHOULD WORK
Posted on Jul 15, 2008
I went throught all the postings but paper (RED) light kept on blinking. So I change the Drum Unit and it worked. The Cause was that the drum Unit had so much dust in it.
Good luck
Posted on Oct 20, 2008
I too have had this problem. While the first place to check is an actual paper jam, if you don't find one, try the following:
Turn the printer off by disconnecting power. Before applying power, cancel all print jobs from the PC. Plug the printer back in and then prepare a job for printing but don't sent it yet. Go into the properties and make sure the paper size is the correct size.
My thinking is that the problem is caused by sending to the printer, a jop using a paper size that is not available. This may be one reason feeding paper into the manual slot works, it may bypass the paper size check feature.
By disconnecting power from the printer and canceling all print jobs, you insure any previous pending jobs with the wrong paper size will be sent.
Hope this works.
Posted on Sep 11, 2008
I've just tried everything suggested and it still won't work!!!!
Posted on May 06, 2008
HL 2040 laser printer - Assuming jammed paper bits are not the cause (if for example the paper does not feed out of the tray, or just barely does), then there are 2 good articles to read, which clearly point out that the culprit would be paper dust encrusted or worn out ribbed ribber belting on the pickup and separator rollers.
Try cleaning the dust off or else the rubber belt would have to be replaced.
These are the articles to read -
1. http://articles.techrepublic.com.com/5100-22_11-5140326.html
2. http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/002000/000024/faq002024_006.html?reg=eu&c=gb%E2%8C%A9=en%E2%88%8F=hl2070n_all
Posted on Dec 07, 2009
Same flashing red paper light. I found a rolled up piece of paper when looking behind the door on the back of the machine. I dragged it out and now all is good :-)
Posted on Jun 11, 2008
Same problem - when I hold the go button down, it goes through all the lights, and then the blinking alternates between ready and paper light blinking.
Posted on Dec 18, 2007
    New Friend:
Posted on Feb 03, 2014
If the red light is flashing try to insert paper manually. I was able to take a sheet of paper and insert into the front of the feed and it works. Sometimes documents can be saved in weird formats resulting in manual feeding of paper.
Hope that works!!
Posted on Jan 18, 2012
Solution 2 rocks!!!! Brother should put it in the manual.
Posted on Feb 06, 2010
I had this issue as well after completely clearing a paper jam from my second paper tray. After making sure I had every piece of paper to make the full sheet the LED's were still reporting a paper jam. I reseated all of the paper, and the toner cartridge. I reseated the second tray as well. Still the same issue. This is what corrected this for me.
  • If you have a second tray try disconnecting the second tray (Just lift the printer off of it.) Restart the printer and see if you still have the error.
  • If you do then check then grab a phillips head screw driver. Unscrew the 4 screws that hold the metal plate on top of the 2nd paper tray motor. There are two optical sensors that have little plastic levers that activate them. In my case one of these was not seated anymore. Gently pressing it back into the clip allowed it to move properly again.
  • Reattached the metal plate and reconnect to the printer.
  • Power cycle the unit.
  • Print a test page from Tray Two.
Posted on Feb 10, 2009
I just changed the cartrige and the no paper ight comes on,,,, There is no jam and there is paper. Have tried all the suggestions and nothing is working,,,,,, Brother HL 2040 printer
Please Help I have to get documents out today,
Thanks
Posted on Nov 06, 2008
Try printing from the manual feed tray. I had the same problem as nagarjuna, where the printer would print a simple page, but not a page (Word) full of tables (printer just blinked the yellow paper light). When I put a paper in the manual feed, voila!, it printed.
Posted on Jul 17, 2008
Printer keeps saying paper jam, open back door.
I have done this 10x and nothing changes.
Posted on Jan 17, 2008
Narijuana's fix worked!
Posted on Jun 25, 2008
  • 537 Answers
Did you take out the tab for the cartridge? Is this a new cartridge?
Posted on Nov 01, 2007
I had aproblem with my laser printer brother hl 2040 ,a red light blinks at the flasher
Posted on Oct 27, 2008
SOURCE:
Brother HL 20 printer paper jam light keeps blinking after jam removed
Please check paper sensor may e damage, need to relpace it on prior basis
Mar 30, 2013 | Brother HL-2040 Laser Printer
Brother HL-2040 paper light flashes red (and won't print) with plenty of paper in drawer
Check for a p[aper jam somewher in the route or at the single sheet feed entry
Mar 01, 2011 | Brother HL-2040 Laser Printer
Brand: Brother Model: HL-2040 Problem: cannot print, paper error, red light blink, did not feed paper. What should i do? thanks.
pull tray out load a couple sheets look underneath and see if paper is lifted up when closing paper drawer. If the paper is not raised to the up position you have broken the tray lift mechanism and it is not worth fixing. You can jam an eraser underneath the tray to manually raise the tray to do a dodgy fix.
Feb 28, 2011 | Brother HL-2040 Laser Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Mar 25, 2009 | Brother HL-2040 Laser Printer
HL 2040 paper jam light is blinking but there is no jam. the printer sounds like it dies out everytime it tries to print.
Often the paper jam light will stay on when the *back* paper jam door is not cleared.
Open up the back of your printer. There is a 2nd door behind this door that you can pull open. If there is a paper in this section, pull it out and it should clear your red light.
When clearing paper jams, clear the front first, and then if the red light is still on, you need to check the back hidden door for another piece of paper.
Dec 08, 2008 | Brother HL 1440 Laser Printer
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Sep 04, 2008 | Brother HL-2040 Laser Printer
RED LIGHT BROTHER 2040
light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Dec 22, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
24,082 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
