Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
My light wont even turn red.. much less green
I plugged my xbox 360 wirelees adapter into the back of my xbox and the light doesnt even turn on. it worked the first time now i have to constantly re-position it if i dont want to be kicked off of xbox live. even when the light is red when my xbox is off it never turns green when i turn my xbox back on. is it broken? What should i do.
If the adapert is red how do i get it green
Posted on Sep 17, 2009
Wont stop flashing green and I can not connect to xbox live yet I used to be able to Any Help Thanks, Paul
IF The LIGHT IS FLASHING GREEN then there is something wrong with your wireless network
Check your network settings and Retry connecting
Check the adapter's status light loadTOCNode(2, 'moreinformation'); The adapter's status light can tell you a lot about the state that the adapter is in. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is not recognized. Try plugging the adapter into a USB port on the front of the Xbox 360 console.
  • Flashing green: The adapter is attempting to connect to a wireless network.
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) .
  • No light: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console
Jan 10, 2011 | Microsoft Wireless Network Adapter Xbox...
All of sudden the xbox wont turn on, never had problems before
well if you press the power button and light isnt on check plug connection going into console and then from console it goes back into the ac adapter. make sure its plugged in tight. To make sure ac adapter is working fine there is a small light on the side if it is green it is working fine if it is either orange or red you have a problem and may need a new adapter. If so you can get a new/used one from your local game store. hope this helps and good luck
Jan 07, 2011 | Microsoft Xbox 360 Console
My xbox wont start up it flashes like it wants to kick on but doesnt. even ac adaptor wont flash green and stay on
Check power brick. The power cord could be loose. If your ac adapter is red unplug it from the wall, the surge protector and re plug it back in. If problem persist call ms and ask for replacement
Aug 04, 2010 | Microsoft Xbox 360 Console
I cant connect to xbox live
The red meant it was ready for configuration. If there is no light it means it is not receiving power. Try plugging it in again, or plugging it in to a front USB slot. If it still doesn't work your adapter has a defect and should be replaced.
Dec 30, 2009 | Microsoft Wireless Network Adapter Xbox...
Console flashing red, wont do anything,is there a reset
This may be an indicator of a problem with the Xbox 360's hardware. To help confirm this, turn on your console and check the power supply (the big gray brick) light. If the light on it is red, orange, unlit or anything other than green, make sure it's plugged in correctly. If that checks out, try a different outlet. If it still doesn't work, you'll have to buy a new power supply for it.
If the light is green, then you definitely have a hardware problem. The only way to resolve this is to go to this site where you can ship the 360 in for repairs. If you've bought the 360 less than 3 years ago, the repair will be of no cost to you, and Microsoft will even provide the box.
If it's been more than three years since you've purchased your 360, I believe it will cost $93 to have it repaired.
Hope this helps :)
Nov 30, 2009 | Microsoft Xbox 360 Console
Plugged in powerless 360
The power adapter would have gone green when it was working normlly, its what it does, you need to replace the power adapter 'brick' as it is either faulty or was over heated due to travel. Good luck.
Nov 06, 2009 | Microsoft Xbox 360 Console
My light stays red never turns green
This means that it hasnt connected to a wireless router. Make sure your router is wireless, that you have searched for you network and found it. If this still doesnt work then make sure that your routers wireless capabilities are working and try entering the settings in manually to the xbox 360 network settings.
Jan 17, 2009 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 wireless network adapter
Turn off the console. Take out the adapter and plug it into the ports on the front of the xbox 360. if this doesnt work, you will need a new on.e
Jun 23, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox 360
Check your AV cables. Make sure all the wires are plugged in and secure. Make sure the switch on your AV adapter is turned to TV, or HDTV, depending on which tv you have. If it still doesnt work, contact xbox customer support at 1-800-4MY-XBOX
Jan 20, 2008 | Microsoft Xbox 360 Console
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
493 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
