Question about Zanussi TD4112W Electric Dryer
Reset button i have a zanussi td4112w electric dryer and its lost its heat, the drum is still rotating, i have been told to press the reset button, but i cant seem to find one on the surface, i need to know if A) is there a reset button for this machine, and B) where is it? please help Alex
  • 121 Answers
Your heating element may have burned out
Posted on Jun 18, 2009
Zanussi white knight dryer - the dryer is not heating up. i have pressed the red reset button the back but no heat? the drum still rotates.
It is possible the heater element is faulty or a thermostat problem.
You need to test the element and stat's with a meter to check for continuity.
Dec 22, 2010 | Zanussi TD4100W Electric Dryer
I have a Zanussi TD4112W dryer and it works fine apart from the fact that only half of the element heats, I have checked there thermostats and they seem fine 2/3 ohm at cold and o/c at high temp. Also the...
sounds like you know what you are looking for, here is a website that may help you, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 30, 2010 | Zanussi TD4112W Electric Dryer
Zanussi TCE 7127 W, lights on, makes normal noise to start with, then no drum rotation, does this 3 times then buzzing (5 buzzes then a delay) starts, and 'end of programme' light comes on and stays...
5 beeps on the programme finished light means the motors knackered apparently, found that info elsewhere on the web. Done this to me today (and it's done it before as well, so i bought an extended warranty when the chance came fortunately). Time to get your guarantee or your wallet out i'm afraid.
Aug 19, 2010 | Zanussi TD4112W Electric Dryer
The drum wont go around and it smells like its burning.
if you can turn the drum by hand it may be the motor start capacitor.fitted just above the motor if you cant turn the drum one of the drum seals will have jammed the drum the belt will have snapped as well.
Aug 06, 2010 | Zanussi TD4112W Electric Dryer
No heat drum turns on td4212w
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 28, 2010 | Zanussi TD4112W Electric Dryer
Just bought 2nd hand a supposedly good working order zanussi tumble dryer got it home turned it on drum turning but cold air in dryer. we then noticed that the back got rather hot.and then nothing. due to...
this could be the stats or the drum is not turning Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Jan 10, 2010 | Zanussi TD4112W Electric Dryer
Td4112 which way does belt fit around drive and
check the drive it should have grooves on it. that means that the belt grooves should go around the drive and facing the drum. When you see the belt on the drum you should not see the grooves on the belt
Dec 31, 2009 | Zanussi TD4112W Electric Dryer
Zanussi td4112w drum stopped spinning
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 19, 2009 | Zanussi TD4112W Electric Dryer
TD 4112W Dryer does not auto reverse
my new dryer makes athumping sound when in use and it sounds like a pair tennis shoes are being dried
Feb 16, 2009 | Zanussi TD4112W Electric Dryer
Zanussi TD4112W Electric Dryer Logo
474 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Marvin
Marvin
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
