Question about HP PSC 1315 All-In-One InkJet Printer
Hp psc 1501xi ink printer - check paper orange light solid
My printer check paper/check print cartridge light is on solid orange after an align page.
I have checked no printer jams replaced cartridge unpluged and replugged all cables power and usb
printer still has soolid orange light on
the cartridges were in the left side and cant print nor does it initialize
this happend after a normal align page was printed
the align page did have some thin black fine lines (many about 2" from the top) on the 8 1/2  x `11 align pagger which printed clear
not sure if this device has died
  • Anonymous Nov 01, 2007
    I have hp1315 v all in one printer but it's stop working check paper and check printer cartridge red light in blinking it in not even taking any paper and it is giving me a message print cartridge cradle cannot move.
    pleasr turn device off. check device for a paper jam or othet obstruction.
    Genius:
  • 1,601 Answers
I have a hp psc 950 I set uo align cartridge clear cartridges, then Itha receive a report saying that align cartridge failed.. Bob
There are several possibilities that you can check. First, what is the ink level for all colors? You need enough ink in all of the cartridges, black and the three color tanks in the color cartridge. A low ink in any one cartridge could do this.
Second, make sure you are printing on clean white letter or A4 paper (no additional print on the page). Is the paper feeding correctly from the paper tray? Did the alignment page print and arrive in the output tray? Check for a paper mismatch warning or if 4x6 paper selector lever is pushed forward on the output tray. Make sure the selector is pushed all the way towards the printer. Did the alignment page look like the previous alignment pages or the ones shown here: http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00657&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=60259#Alignment_Pages .
If any color is missing, look for a problem with the cartridges. Try running a cleaning cycle: press Menu (or Setup, depending on the printer) on the printer. Press the right arrow until you see Maintenance or Tools. Press OK and then OK again if Clean Print Cartridges is highlighted. (Otherwise, highlight the Clean Print Cartridge by pressing the arrow keys and then press OK.) If the output is missing, faded, or streaked. Note: a low ink issue will be made worse with a cleaning. It is a cartridge issue. This could be a symptom of clogged nozzles on the cartridge, the protective tape still on the cartridge, or poor contact between the cartridge electrical contacts and the matching ones on the print head. Remanufactured and refilled cartridges are at higher risk of failing. However, the chip on the cartridge can also fail; in this case, if you have a genuine HP cartridge, contact HP. Replace the cartridges. You may want to clean the cartridges and the print head. Use distilled or bottled water and lint free paper or swabs. (coffee filters can be used.) Wipe away from the nozzles (the contacts, edges and ramps of the cartridge) of the cartridge and the contacts inside the printer. Wipe in one direction only even on the contacts inside the printer.
Reset the printer by unplugging the power cord for at least 5 seconds before plugging it back in. Print a new alignment page. Does the printer give one or two pages? If you only get one page, the alignment is automatic and you should see a blue light at times as the printer feeds and prints the page. If no light shows up, the printer needs service.
If you get two pages, check the scanner glass and white scan backing. Clean the surfaces with a soft cloth dampened with clean water, if they need cleaning. Check if the bulb assembly is lighting up when the unit is on. If that scanner light doesn't come on, the all-in-one needs service. Make sure to put the alignment page face down on the glass or face up in the ADF. Copy the alignment page. If the copy has vertical streaks, clean the scanner assembly. (If this cleaning doesn't help, again the unit needs service.)
You can bypass the required alignment. Press and hold the Enter button and then press the Setup button. The unit should print but the print quality will be poorer. If any colors are missing, check the ink level and for clogged nozzles.
I hope this helps.
Oct 28, 2010 | HP PSC 950 All-In-One InkJet Printer
I have a HP PSC 1410 printer Every time I turn it on, it prints a "Test Page". The Check cartridge light is On, but I just had the cartridges filled. "E" shows in the Copies section I am only printing...
I suspect by "Test Page" you may mean alignment page. If the printer senses a problem with black or yellow colors it will continue putting out this page each time you start the printer. Be sure you correctly installed the print cartridges then follow the instructions on the paper to scan it and do a proper alignment. If you have done the alignment chances are something is wrong with your ink. I recommend against getting carts refilled. In the future be sure to use a new name brand ink cart to ensure proper printing. Please consult the following page for detailed diagrams:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00473766&tmp_track_link=ot_recdoc/c00447737/en_us/c00473766/loc:1&lc=en&dlc=en&cc=us&lang=en&product=441115
If it is truly printing a Windows logo test page I'm sorry for time waste.
Oct 17, 2010 | Office Equipment & Supplies
Replaced ink cartlidge and now wont print
After replacing the ink cartridge you should print the alignment page to work product perfectly.
Follow the below instructions to print alignment page:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
If the issue still persists, perform semifull reset by following the below instructions
  1. Unplug the power cord from the wall outlet.
  2. Unplug the power cord from the back of the all-in-one.
  3. Wait 30 seconds and plug the power cord back into the wall outlet.
  4. Plug the power cord to the back of the all-in-one.
  5. When the lights begin to flash, press and hold the On/Resume and Number of Copies Buttons.
  6. When only the On/Resume light is flashing, release the buttons.
  7. When the On/Resume light is steady, the reset is complete.
Oct 12, 2009 | HP PSC 1350 All-In-One Thermal Printer
My HP printer PSC 1510 All-in-One no longer asks me to align my ink cartridges after a change of cartridges. Now, after a system recovery, it prints an alignment page every time I turn it on, whereas...
The only way to stop this is to press the cancel button, just as it tries to print the test page.
Various people have said the printer won't align (calibrate) successfully unless both ink cartridges are more than 50% full, and until it aligns successfully, it will continue to print the test page on start-up.
It is a total waste of ink and paper, so remember to hit the cancel button when you turn it on.
Apr 11, 2009 | HP PSC 1510 All-In-One InkJet Printer
It automatically print a page everytime I start my hp psc 1315
Hi Siddarth
In HP PSC 1315 printer after replacing new Ink Cartridges the printer always prints Alignment test page every time you turn it ON.To resolve this problem you must complete the alignment process.
Steps
1.Turn the printer ON.
2.Once its ON, it will print the Alignment page. Place the page in the scanner bed correctly.
3.Then Press START SCAN button.
4.The power light will start blinking, wait until the power lights turns solid.
5.Now Alignment process is over.Discard the paper from scanner.
6.Turn the printer OFF and then ON, it will not print that page again.
Note:Please follow this steps every time when you replace the Cartridges.
Thanks
Rizwan
rizwan84tx@gmail.com
Dec 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
WHEN I TURN ON THE PRINTER IT STARTS TO PRINT THE ALIGNMENT PAGE
Hi Mahdavi,
Steps
Thanks
Rizwan
Dec 06, 2008 | HP PSC 1315 All-In-One InkJet Printer
Not responding to PC instructions to print data
You need to load the PRINTED ALIGNMENT PAGE on the scanner glass, then press on "OK" button. It should start scanning the alignment page. That way, you are completing the PROCESS of ALIGNMENT.
Thank you so much.
adonscott
Jul 01, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP 1210. Copies light solid 'E'. Print Cartridge light, blinking orange. Happened out of blue, with 20 pages pending in cue on 4 different print jobs. Tried the reset, did not work. (hold cancel and...
hi,
seems like an hardware problem... anyway we will give a try
> unplug the usb cable
> open control panel and then open printers and faxes
> right click on each and every printer icon related to this particular printer and delete it.
> now turn off the printer
> keep pressing the on button for 20 seconds
> turn the printer on
> take out the ink cartridges
> now turn on the printer
> when the printer asks for the cartridges, insert them
> still if you have the problem, check for any jammed paper
> turn off the printer and open the rear access door. you will get full acces to the rollers, remove the jammed paper if any
> close the rear access door
> try to copy or print after turning on the printer
if still u have the problem service the unit.
you can also cal the tech support at 18004746836
thanks and regards
agnel
Mar 19, 2008 | HP PSC 1210v All-In-One InkJet Printer
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
      5. Press Copies .
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
558 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
