Question about HP LaserJet 5500dtn Color Printer
Paper jam in printer
My husband changed the black ink cartridge and now the printer keeps jamming with paper. The paper rolls in and the somehow gets folded on one side and gets stuck.
    President:
  • HP Master
  • 1,996 Answers
See here. Also here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 17, 2009
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
Does not print, responds with paper jam. No paper jammed. Clean sheet of paper passes through. Could a buildup of dust be the problem and its age. Tried cleaning roll by command and changing the ink. I...
What you could try is let the printer to reset.
Remove both ink cartridges.
Close cover and turn off printer.
Unplug printer from electrical outlet.
Wait 15 minutes. This will let the printer to clear memory.
Plug printer back in.
Turn on printer, printer would cycle to the start position.
E5 error would appear.
Install ink cartridges.
If nothing is in the printer that prevent the printer from recycling.
There should be no paper jam error.
Jan 04, 2011 | Canon PIXMA MP170 All-In-One InkJet...
Jam inside top cover 13.05.00 also change fuser assembly
To remove paper jam. Just remove the toner cartridge and pullout jammed paper. If still coming paper jammed error message. Switch of the printer and the printer will roll over the paper jammed.
Changing of fuser drum is required if the print out came with the black strips. This happens when you print large volume of printing jobs.
Nov 26, 2010 | HP LaserJet P3005 Printer
IT KEEP SAYIN RMOVE PAPER JAM
  1. Turn off the printer.
    Remove any paper trays. Inspect them for wrinkled or damaged paper.Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  2. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
    If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
    If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though
    eplace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
    1. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
May 02, 2010 | Office Equipment & Supplies
Epson stylus cx6600 alll in one roller crimps and stops paper from rolling. My computer says it is working properly. It all started with a paper jam, which I cleared, hit "color" and thus my problem.Ally
Clean the machine, the rollers also and follow these steps to clear out any paper jams it might have
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jul 03, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Dear
It is the problem paper end sensor is open or fedd sensor is open.
power on then paper jum it is the same problem. or power on printer is ready after print command then paper jum it problem your cartridge chip is diable or feed claught is not active
Jun 17, 2009 | HP Color LaserJet 5550dn Q3715A Workgroup...
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
alternative :
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper Jam feeder
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Step
Step
Step
5
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Step
9
Aug 14, 2008 | Dell 3100cn Laser Printer
HP LaserJet 5500dtn Color Printer Logo
94 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
