Question about Kirby G5 Bagged Upright Vacuum
Can't seem to pick up small items like lemon pips with Kirby G5. It just runs over them or pushes them backwards and forwards.
  • 10,865 Answers
It sounds like your belt is broken, OR your beater bar is rotating but has not been adjusted downward to reach the carpet pile. Check by running the vacuum and looking to see if the beater is moving.
Posted on Jun 17, 2009
Kirby G5 self propel problem
There is an adjustment for the transmission and it is wrong. It could also be worn. The Kirby has an amazing warranty. See if you can get it serviced for free.
Mar 22, 2013 | Kirby G5 Bagged Upright Vacuum
Kirby g5 self propels too fast
the slide has shifted forward slightly, this happens when the kirby
is hit against walls and skirting boards. you will need a service by your local kirby engineer. see kirby.com for local agent
In drive I can push kirby forward but not backwards
it will be the transmission this video will help you
Oct 17, 2012 | Kirby G5 Bagged Upright Vacuum
Kirby g series not picking up very well
Is the bag full? the bag is full when it has about 6 inches of dirt in the bottom.. I never use it when it reaches above that level.. The roller may be at an incorrect height.. Too High.. or TOO LOW.. Put the roller at the lowest point then press the lever until it gets to a level where its easy to push, so the brush is just above the carpet etc.. the vacuum has to be able to suck up past the roller..
there is a special roller brush for dog hair... Not many vacuum cleaners will pick up dog hair... as it clings to the carpet, and it is too thin to be pulled up by the vacuum.. regardless of the suction..
the hair has to be dislodged by the roller brush and then sucked up.
Lee in Australia
Oct 14, 2012 | Kirby G5 Bagged Upright Vacuum
My kirby g4 motor runs backwards and so the power drive when pushed forward wants to go backwards. I need the wiring diagram so I can get it wired correctly.
The wires to the switch, coming from the carbon brushes, have been reversed. The carbon brush closest to the switch goes on the lower switch terminal.
Dec 24, 2010 | Kirby Generation 3 Bagged Upright Vacuum
G5 kirby's drive feature isn't working
the gears or the drive is probably worn down or is broken.take it into kirby and they can fix it for you.
Jul 02, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby G5 - the Tech Drive does seem to have much power
you need either a new nutreal cam bracket assembly, that is what engages and disengages the tech drive.OR to adjust the handle pivot assy- diffucult . this is not for the faint of heart. it is possible to fix them as i used to repair kirbys, however, I remember how frustrating it was to figure out how to disassemble and reassemble them. it is very complicated to a novice. I would recomend having it repaired professionaly. it is possible for a professional to repair it in a very short period of time.
another thing to consider. look on the UNDERSIDE of your Kirby, between the two drive wheels. just in fronnt of the tech drive/nutreal switch. there should be a screw there, tighten that screw up. actually tighten all of them. on My generation 3 the center screw came loose and it would not go in to drive and it would make an aweful clatter. hope this was helpful
Jul 08, 2008 | Kirby G5 Bagged Upright Vacuum
New Kirby
Is the bag emptor all of the way on? It will blow out if it isn't, But being new, you must have a number to call, it is under warranty so they should be able to help you out.
May 25, 2008 | Kirby G5 Bagged Upright Vacuum
G2000 Kirby HELP
I'm not familiar with this type of vacuum, but if it's like most kirby's the powerhead gets all its motion off the tapered spindle underneath the powerhead. IF the belt is installed backwards on this spindle then all motions are reversed. there should be an arrow stamped into the blower housing. the belt should be installed so it is nearest to the arrow in the direction of the arrow on the housing.
Aug 22, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
100 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
