Question about HP OfficeJet 7310 All-In-One InkJet Printer
A piece of plastic broke off from my printer. it is the piece in front of where the cartridges are put in. it has a white label with a drawing, it is like the icon on the "on" button. is it fixable?
    President:
  • 828 Answers
I think yes, if that plastic cannot bother your printing...
Posted on Jun 17, 2009
  • Francis Mark Arango
    Francis Mark Arango Jun 17, 2009
    i think yes, if that plastic cannot bother your printing...
How do i change the ink cartridges for the photosmart 7960
Make sure the printer is ON.
2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place.
The print carriage moves to the far right side of the printer.
3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
4. Pull the print cartridge toward you out of its slot.
5. If you are removing the black print cartridge in order to install the photo print cartridge, store the black print cartridge in the print cartridge protector. For more information, see Use the print cartridge protector. If you are removing the print cartridge because it is low or out of ink, recycle the print cartridge. The HP Inkjet Supplies Recycling Program is available in many countries/regions, and lets you recycle used print cartridges free of charge.
6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place.
If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon.
8. Close the print-carriage access door.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 15, 2013 | Office Equipment & Supplies
How to change the ink cartridge
Checking the ink levels
  1. Open the HP Director .
  2. Click Settings , point to Print Settings , and then click Printer Toolbox .
  3. After the Printer Toolbox opens, click the Estimated Ink Level tab.
  4. For information on obtaining replacement cartridges, click Print Cartridge Ordering Information .
Replacing the print cartridges
  1. Make sure the HP all-in-one is on. WARNING: If the HP all-in-one is off when the print-carriage access door is lifted to access the print cartridges, the HP all-in-one will not release the cartridges for changing. Damage may occur to the HP all-in-one if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place. The print carriage is on the far right side of the HP all-in-one. c00228292.jpg 1 - Print carriage access door 2 - Print carriage
  3. When the print carriage is idle and silent, press down on the end of each cartridge to snap it out of the carriage. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If replacing the black or photo cartridge, remove the print cartridge from the slot on the right. c00228293.jpg 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print
  4. Gently pull the print cartridge toward you, out of its slot.
  5. If removing the black print cartridge to install the photo or gray photo print cartridge, store the black print cartridge in the print cartridge protector.
  6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. c00228294.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape c00228295.jpg
  7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place. If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle on it. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon on it. c00228296.jpg
Jan 21, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How to load the ink cartridge
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I need to know how to refill my ink for my nx110 printer
The ink cartridges used in Epson's Stylus line of printers are very similar to the ones used in its other printers. A handful of cartridges--like the S020034, S020047 or S020049--may require a slightly different refilling technique, but they all basically entail opening a fill hole in the top to run down into the ink chamber within. Once the chamber is accessible, you can use a basic refill kit with a syringe bottle to refill the chamber, as with most printer-ink cartridges.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
1. Hold the cartridge upside down so the outlet holes to the printer paper are on top. Cover each hole with a piece of tape, then turn the cartridge right-side up.
2. Make a hole in the top of the cartridge above each ink chamber. For most cartridges, simply poke a hole through the label with a toothpick. With cartridges like the Epson Stylus 34 (the casing of which is black), pull back the label to reveal the filling holes and puncture the seal of each home. For the 47 or 49 color cartridge, drill a 1/8-inch hole in the shell between the label and front edge.
3. Determine which color of ink is in which chamber (if you're refilling a color cartridge). The toothpick used to puncture the hole should draw out some ink to show you. If you have a cartridge in which you punctured the label directly, the order of the color chambers is usually cyan, magenta and yellow. If you created the hole in another way (like with the 34, 47 or 49 cartridges), the order is usually magenta, cyan and yellow.
4.Fill the syringe bottle with 5ml of ink. Insert the needle in the filling hole and inject the ink. There may be a sponge inside the chamber, so make sure the needle goes all the way through to the bottom. The 34 cartridge takes up to 12ml of ink.
5. Tape over the fill holes you created. If you drilled the holes, plastic plugs (like the ones included in a refill kit) can work as well. Leave the tape on the outlet holes as you replace the cartridge in the Epson Stylus printer.
6.
Dec 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Removing the print cartridge a plastic piece 20
if it is black plastic piece and the printer print blank paper then the piece lies behined the scan unit, at the top of the cartridge, i guedd you want to send the printer to a service center
contact me to get a free service manual at walid_sayed@hotmail.com
or visit www.eserviceinfo.com
Apr 12, 2010 | HP LaserJet 4 plus Printer
Piece that holds in the ink cartridge broke i need a part where
HP doesn't stock any of those small plastic pieces for us to order. The best bet is Ebay or garage sale for a scrapped printer.
Aug 11, 2009 | HP PSC 2175 All-In-One InkJet Printer
Ricoh C410DN set the toner cartridge correctly
If you look at one of the other colors you can see how the toner cart door slides under some plastic to open it. I bet the yellow one is broke. Tape a folded piece of paper to the end of the cartridge. That might hold it down so it will work.
May 26, 2009 | Ricoh Aficio SP C410DN Laser Printer
Long thin plastic piece fell out of Lexmark Z33
Google your printer, try pcappliancerepair.com. This item goes from one side of your printer to the other, passing through the cartridges holder. Look for the places it attaches. You may have to move the cartridge holder to the center to install the plastic.
May 01, 2009 | Lexmark JetPrinter Color Z33 InkJet
Hi I don't know how to insert the cartridges for the photosmart c4280, thank you so much maria
Pull down the front cover by placing your hand on the right hand side of the printer.  The white panel facing you will flip down.  The cartridges are found on the right side when looking at the front of the printer.  There is a diagram on the inside of the panel door which tells you how to insert the cartridges. There are two of them, the left one is color and the right one is black and white.  Depending on what the printouts look like, you'll need to either replace both or just one of them.  Place your thumb on the top of the cartridge and gently press down and pull towards the front.  It should "unclick" and come out.  If it's not moving and you're exerting too much force, you may be doing it incorrectly.  Each cartridge is removed in similar fashion.  Grasp the new replacement cartridge and pull the clear plastic piece off if it's present, then pul the taped tab off the bottom.  Insert the new cartridge with the label facing up so that you can read the words.  Put the bottom in first (the part where you removed the tape) at a 45 degree angle, then place your thumb on top and push up and forward to snap in the new cartridge.  After you insert the cartridge(s), close the front white panel.  The printer should recognize the cartridges and start aligning them and you should be able to print after that.  If it gets stuck aligning, you may need to power off the print and turn it back on.  Hope this helps!
Dec 15, 2008 | HP Photosmart C4280 Aio Printer
Refilling ink cartridge for Lexmark z1480 printer (instructioons)
you need to peel the label off and make a hole in each of the 3 indents. It's quite difficult but if you've managed it with the black then you'll know what I mean. Then using a syringe put your yellow in the top left at the front end of the cartridge, cyan in the top right and the blue one at the bottom. Should take about 20mls or around that each. If you're ever not sure which colour goes where put the syringe into the hole first and try and draw a little of the remaining ink out to check 1st. Put the sticky label or some tape back on.
Jan 06, 2008 | Office Equipment & Supplies
HP OfficeJet 7310 All-In-One InkJet Printer Logo
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
