GE (74896) Clock Radio Logo
A
Anonymous Posted on Apr 07, 2014
Old jcpenney clock radio how to set time - GE (74896) Clock Radio
2helpful
Daylight savings time changes at wrong date on my brookstone 'smartset' alarm clock. (It changes at the old date, of course - so it is wrong 4 times a year...)
The DST schedule is hardwired into the older clocks and cannot be modified to run on the new schedule. If the clock has a DST switch, you can can turn it OFF and reset the clock only twice a year. On my old "ATOMIC" clock, I've set the DST function OFF, and I use the time zone switch for my adjustments. Sorry, but your only other choice is a new clock.
Bill B
1helpful
Since the time change I can't reset my clock. It
If your clock radio is more than two years years old it will be operating on the old changeover schedule, and there's no way that you can change the schedule. What you can do though, is turn the DST switch (if so equipped) to the OFF position and change the time manually. If yours is an "atomic" clock you can force the change by setting the clock to a different time zone. (I have an atomic clock that's set up on the old schedule. DST is OFF, and I change the zone between the Central and Eastern time zones.)
Bill B
Change day light savings setting on old t311t
It won't understand. It was mfg before the new change
Trying to set the time on the clock. This device is about 10 years old and I have not instuctions
yorx model 5285 clock radio cassette player , the clock keept blinking and cannot set it.
Hi . My clock radio clock continuously displays
Likely a bad backup battery inside the clock, or a capacitor that is leaking a charge.
Emerson SmartSet Dual Alarm Clock Radio Won't Stop "Flickering"
Problem was solved. When clock was plugged in after a few more days, it finally stopped flickering and reported an incorrect time and day. Low battery was now blinking! Checked calendar and found all memory was lost. Purchased and installed a new battery and this time when clock was plugged in it correctly set itself! Fixed.
2answers
Emerson Research SmartSet Clock Radio
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
2answers
Top GE Audio Players & Recorders Experts
Rob Hill
Rob Hill
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
