Question about Frigidaire GL38LKEC (LP) Grill
Trouble removing gl38 burner
I too am trying to replace, but cannot even get the old burner out. can you tell me how you did that much? i removed the rear top flange and screws, but when i pull the burner too the rear - and it does move back and forth - the front tubes do not clear the front entry holes so i cannot lift the unit out. what is the trick?
thx,
neal
  • 10,865 Answers
Hello Neal. Yes, the trick is to gently bend the tubes to remove them.
Posted on Jun 17, 2009
My brother changed the 3 burners and there s only the one of the left that s working .I ve tried to take them away to put theoldones but Idon t know how to do it..Thanks
The problem may be caused by low gas flow. So, before removing & reinstalling the old burners, do the following:
First be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
If you find you need to remove and reinstall the old burners, I have included a link to the Owners Manual for you grill. Staring on page 21, Annual Maintenance, it will tell and show you how to remove the burners. http://help.weber.com/manuals/ducane/2008%20Manuals%20pdf/20529916_030308.pdf
I hope this helped you and Happy Grilling!! Thanks for choosing FixYa.
Aug 19, 2011 | Ducane 30400040 Stainless Steel Grill
Grill is 6 yrs old, natural gas hard line to house burners have only very low flame (really low) do I need to replace burners or valves? if so what does it take?
Before you start replacing parts, let's try trouble shooting the problem, by asking a couple of questions.
Have you checked the gas line shutoff valve, on the gas line from the house to the grill, to make sure it's fully open?
When was the last time you thoroughly cleaned the grill (i.e. Removed and cleaned the burners, the venturi valves & the burner orifices) ?
If you answered NO, to both or either one of the above questions, that's where you need to start.
If you no longer have the Owners Manual for your grill, please advise me, who the manufacturer is and the correct model number . I may be able to provide you with one. Even if you end up needing parts, you will need the Owners Manual to get the correct part numbers.
Hope this helped in solving your grill problem. Please let me know.
Apr 15, 2011 | Viking DVGBQ532-3RTL (LP) All-in-One Grill...
MODEL 720-0061LP How to replace old burners
  1. Turn off gas, and let grill cool.
  2. Remove cooking grates.
  3. Remove heat plates.
  4. The burners are held in place with hairpins. You may need to go beneath the casing to remove these pins.
  5. Pull the burners back and up to remove.
  6. The part number is 26301 from bbqparts.com.
Mar 13, 2010 | Grilling
Having trouble changing 3 steel pipe burners on Charmglow grill
The best way to install these burners is to get a vice grip/pliers and bend the end of the burner where the screws can be placed. If you notice on that end there appears to be a section where it will bend without impacting the integrity of the burner itself. It will bend enough for you to place the burner in its place. Once installed, bend back and screw in the screws to hold in place.
Sep 09, 2009 | Grilling
Replace main burner bracket - Kenmore 141.17227 nat gas grill
I've been screeming at my employeer about this design for years!!! I know what you are trying to do- I have to work on them,even in 90 degree weather!!!! Find the screws that hold that side panel on,remove screws, have someone else there to help you hold it in place- best to get the HARDWARE pack also, its new screws as the old ones will be rusted in, I've even had to grind some of the old screws to get them removed.. Good luck , at least you know someone else is having same problem...
Sep 05, 2009 | Kenmore 882 sq. in. Cooking Area Gas Grill...
Own a charmglow gas grill 3 burner, having trouble igniting burners will not ignite, how do you match start
I have used those long-necked lighters as a temporary thing. You can buy replacement igniter kits at Lowe's/HomeDepot/similar, and they are easy to use. I hate to admit it, but I have taken the igniter out of the side burner that is attached to the grill and used it, until I bought a replaement. Match starting is a less than favorable option, as you are putting your hands and face in a bad place, but if you just have to do it, remove the grill grate over the burner that you intend to light. Get your fire source to the burner, and turn the gas on low. If the burner doesn't light pretty quickly, remove the fire source,shut off tha gas and wait several minutes with the lid still up for the gas to dissipate. You don't want to be trying to light the grill and have it flash on you. Most grills have an opening at the rear if the grill for manual lighting. Even so, the long lighters are waaaaaay better than the old kitchen match. I'm sure that you know, but always have the lid open when lighting the grill. (I just had to say it!)
Hope that this helps...really!
Best regards, --W/D-- please feel free to rete this solution! Thanx!
Jul 29, 2009 | Grilling
Meridian 5 burner trouble
Yes you can fix it. Carefully remove the screws that hold the panel where the burner knobs are, There are 3 screws on each panel under the side shelf. There is another screw up underneath the face plate as well. Once the screws are out pull the face plate up and out so that all the tubes are disengaged. It should rest about 2 inches tilted back. Now remove the grates and burner covers and inspect the burner tubes. You will most likely find that spider webs or hornets have blocked off the gas flow to the burner. carefully clean every burner tube out and put everything back. You also may want to use a bit of sandpaper on the ignitor tip. Put everything back together and you should be good to go. It seems all Ducanes attract spiders on the burners...
Apr 06, 2009 | Ducane Meridian 32 Inch 5 Burner Gas Grill...
Replacing oven burner element, the lower element, for a GE stove
(I think it is 50 watts or volts??)
Most electric ranges are supplied with 220 volts - this is, especially at 60 Hz, deadly. You were lucky this time.
If the wires are not welded onto the element contacts, they might be so-called 'quick-disconnects' that pull straight off of blades that are part of the elelment.
You probably haven't hurt the range with the momentary short circuit since the chassis of the range is connected to neutral or ground so you just gave your breaker a workout. BTW, I have had to replace late breakers after they tripped. They wouldn't stay reset any more even after the problem was removed from the circuit. Don't be surprised if yours doesn't stay reset; it may not be a fault causing it.
Jan 18, 2009 | General Electric Stove/Oven/Range Chrome...
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Burner replacement on Ducane 30400040
Remove the 2 grill wire cooking racks by lifting them out of the top of the grill, next lift out to remove the 3 heat deflector panels which exposes the 3 burner tubes. Remove the 4 screws located on the outside flanks (2 on each side) of the 5-knob control panel assembly - then gently slide the knob control assembly outward and away from the grill just about an inch or two. You can now remove the old burner tubes and replace them with the new units. Then simply slide the control assembly back into the grill frame and replace/tighten the 4 screws. Voila`
Jul 04, 2008 | Ducane 30400040 Stainless Steel Grill
Frigidaire GL38LKEC (LP) Grill Logo
385 people viewed this question
Top Frigidaire Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Frigidaire Grilling Expert? Answer questions, earn points and help others
