Question about Sharp LC46SB54U 46 in. LCD TV
Sharp Aquos E203 No Broadcast now
Intermittent reception on one over the air channel, cutting out for a couple seconds--E203. Does not happen on other LCD TVs connected to same antenna. Or on other channels on same tv. Signal strength near full strength
  • Devon Sacco
    Devon Sacco May 11, 2010
    Here a possible solution for the manual.
    E203 • Check the broadcast time in the program guide.
    New Friend:
Google blocking facebook hacking my account phone tv
Posted on May 15, 2017
My LC46D64U just started doung the same thing for any over the air channel that starts with 6. It cuts out for a few seconds about every 60 seconds. Has anyone found a solution for this?
Posted on Feb 28, 2010
Broadcast fail to show (E202)
U just take ur tv original remote just turn to channel 3?Why is ur cable service connected to channel 3?The proper way to connect to cable service is get the pay cable connected.Take ur original tv remote.Push Menu on ur remote,go to SET UP go down the CH Setup,pick cable,than scan for all the pay cables channels you pay for.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
"Failed to receive broadcast"
On your TV remote,press "INPUT".It is hard to find,but it should be there.Select"TV" and press"ENTER" button.I believe it is on the top of the list.On some cable boxes you have to select channel 3 and use the cable box remote to change channels.Also,make sure your TV antenna setting is set to "Cable" from the "Air/Cable"(Antenna setting).You will have to read your manual to find out how to get to this menu.After that do a "Ch Search"[Channel search].This automatically searches for all available channels and stores them. It will take some time.You will see the channel numbers as it does it's search.This is done so when you press channel up and down keys it will only go to next channel available and not to one with no signal.Hope this is of some help.
Feb 19, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Does my LC-13S2U have a digital tuner?
Going over you manual for the tv, it doesn't have a digital tuner.
You'll need a digital converter box for broadcast channels.
Indoor antenna will work. But, an outdoor antenna will work best for reception.
If you need a copy of your manual, you can download one with this link:
http://www.sharpusa.com/files/tel_man_S2Useries.pdf
Jun 14, 2009 | Sharp Aquos LC-13S2U-S 13 in. EDTV-Ready...
Turned on set....screen all black except a dark blue rectangle in center which reads:Failed to receive broadcast [E202]
That message is presented when a selected digital channel is too weak to decode. Let us hope that something was accidentally changed:
Is the channel legitimate?
Is the antenna/cable still connected (to the Digital input)?
Go into menu - setup - channel setup. Is the selection of either cable or air channels correct for your situation?
Use menu - setup - Antenna Setup-DIGITAL to examine the signal strength. Is there nothing at all, or is it just a question of strength?
Odds favor a change in channel setup that you would not have made intentionally, or a simple physical problem (input cable, etc.). Start from scratch, and check the settings and connections you originally made. Hopefully it will be simple and cheap!
May 22, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Error code e203 tv sharp lc-46sb54u
My sharp manual says E203 means "No broadcast now".
Under possible solution, it says " Check the broadcast time in the program guide".
My manual says nothing else after that.
I hope that helps. Please rate me. :)
Feb 28, 2009 | Sharp LC46SB54U 46 in. LCD TV
Sharp Aquos LC-52D64U LCD-52 wdscrn tht won't scan in digital...
Seeing that you have a superior brand and not getting channels is a bummer. It may have to do with the setting, make sure you're set to cable rather antenna and then do a rescan. Btw, often times channels from an over the antenna is much clearer than from cable because cable tv has to compress the signal. If you're high in the air like the top floor of a building a cheap $10 will pull in great free digital channels. It helps to experiment and read the troubleshooting guide in your manual.
Dec 03, 2008 | Sharp Aqous LC-26D5U Television
Sharp Aquos Audio Intermittent
This is a problem with the ATSC channel's reception. Usually switching to another channel and back solves the problem.
Jul 28, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp LC46SB54U 46 in. LCD TV Logo
3,262 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
