Toshiba Color TV Relay clicks slowly. TV does not come ON.
I have a Toshiba Color TV mod: 20AF41C.
When I plug it in, the relay ''RY501'' clicks about once every 4 seconds. When it clicks, the contacts inside the relay do not stay closed. The coil is not energised enough to close the contacts. Only enough to cause the clicking noise. I have opened the relay to confirm that this is what happens.
I also removed the relay (RY501) and if I connect the set, I hear a very faint click at the same speed (about one click every 4 seconds) I tried to discover the source of this faint clicking, but it is too faint for me to locate where it is coming from.
If I press the power switch, nothing happens. I tested the Power switch, and it is normally opened, and it closes when I press it.
Can anyone help.
  • 668 Answers
Electrolitic Capasitors in the power supply going or being bad will cause this. At some point a low value resister also will start to run hot or burn up. I believe it it a 16v 1500 uf cap near the relay. I would also replace any 10uf 160v caps in the powersupply too.
Hope this Helps,
Skyassoc
Posted on Jun 17, 2009
Dead set toshiba mod. no. 52xv540u no bad caps,no clicking,no led lights on front
Hi, First check that you have good power coming in from plug.
If that is good check out power board (capacitors Bad) replace if oozing out or bulging out. If you are good with soldering then do so.
Replace with same capacitors or better ones.
Jan 13, 2014 | Toshiba 32AV502R LCD TV
I have a Sony STR-K502P home receiver. While watching a program the other day the center channel stopped working. Prior to that I had recently noticed a clicking noise like a relay switching off and...
It wouldn't be your output transistors. If they go bad they blow the fuse. Sounds like a speaker relay problem. Have you checked the solder connections on the relays? They sometimes break down. If that doesn't help, I would replace the relay. Center channel goes through RY501. Sony p/n: 1-755-170-11.
Apr 21, 2013 | Audio Players & Recorders
Visio VP504 fhdtv10a - When I plug it in, it has an amber logo light and makes a click noise (like a relay). When I press the power button nothing happens.
These are problems gradually developed in TV over the years. You may have to look for any dry solder, change the capacitors that look 'puffy' and try.
Jul 30, 2012 | Televison & Video
Tv will not turn on and green light blinks 3 times constantly
Your main power board located in the center where your power cord will plug into is going bad, actually it's just a relay. I have the same problem, tv works for hours til relay overheats, then tv shuts off and tries to restart, hence the clicking and the 3 green flashes, mine will actually restart after 15-30 minutes. search online for the board, ranges anywhere from 150-280. I haven't found anyone to sell just the relay. I am trying tv with rear panel removed and cover removed from relay to see if relay will not malfunction? Board is a simple plug and play, just remember to have the tv unplugged.... you can actually remove the rear panel while on it's stand, just don't remove the screws holding the base onto the tv.
Jul 14, 2011 | Toshiba Regza 52XV645U LCD TV
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
Toshiba 27A51 TV won't power up, relay clicks twice
must be some of parts broken down. you have to check powersupply thorougly.
Dec 16, 2008 | Toshiba 32AF41 32" TV
TP55Hwon't turn on, after unplugging, click and red light flashes
I HAVE THE SAME PROBLEM ,I FOUND OUT AFTER OBSERVING FOR QUITE SOMETIME THAT THE CLICKING NOISE I HERE AFTER PLUGGING IT TO THE OUTLET CAME FROM A RELAY SWITCH LOCATED ON THE POWER BOARD AFTER TAPPING ON IT THE SET WOULD POWER AND THE BLINKING RED LIGHT GOES TO NORMAL..I BELIEVE THIS RELAY IS CAUSING THIS PROBLEM FOR ALL THE FELLOWS OUT THERE WITH THIS TV SET AND THE BLINKING RED LIGHT..IN MY CASE THE RELAY WENT SO BAD NOW THAT THE COIL THAT MAGNETIZES TO CLOSE THE CIRCUIT GAVE UP ,SO I PULLED THE COVER OF THE RELAY TO UNVEIL THE TWO METAL STRPS THAT COME IN CONTACT AND HAVE BENT ONE SLITELY TO REMANE CLOSE THIS POWERS THE TV UP NORMAL BUT IN ORDER TO SHUT IT DOWN I HAVE TO PULL THE OUTLET. THIS IS TEMPORARY UNTIL I CAN FIND WHERE TO GET RELAY SWITCH. PLEASE DONT TAKE MY RESEARCH AS A SOLUTION BUT FOR WHAT EVER ITS WORTH. I WILL GET THIS UP AND RUNNING AGAIN ITS ALL WORTH EVERY DOLLAR TO FIX.
Nov 18, 2008 | Toshiba TP55H60 55" Rear Projection...
Toshiba 57h83 wont do nothing
that relay is supposed to engage power to the tv boards that control the screen.
you will have to take it to a oualified service center , because they have access to parts that are needed for repair
Oct 17, 2008 | Toshiba 57H83 57" Rear Projection HDTV
Toshiba cf32c50 tv will not turn on
This is a typical condition if the power supply has failed or a power-consuming circuit the supply services has exceeded a predetermined current draw. The relay you hear is preventing further damage or even fire.
You will need local tech help with this.
Sep 29, 2008 | Toshiba CF32F50 TV
Mitsubishi VS-5075
Your standby power supplies are most likely at fault you should check the low voltage regulators and see if they are functioning they may be defective.
Jun 16, 2008 | Mitsubishi VS-5075 50" Rear Projection...
Televison & Video Logo
630 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
