Clear water leaks out of the reservoir. cannot use the automatic mode because most of the water will leak out over night
SOURCE: Unit leaks out of the bottom
Mine just developed the same problem. Me being an engineer, I decided to take it apart and found the problem. There is an aluminum tube shaped like a "C" with a heating element inside of it. Water flows through this metal tube, is heated, and then pushed via steam pressure. There is a metal brace that holds this "C" piece securely to the bottom of the machine. This brace is sharp and overtightened, which caused a small hole to form in the metal, causing the leak (in my machine of course). I am currently researching how to patch aluminum so I can hopefully fix it.
SOURCE: WATER LEAK
I have the same problem with my unit and Cuisinart Warranty is replacing my unit. Please see my post on this issue and perhaps calling them will net you a new machine or a fix to your problem. You will need the Serial number to your unit.
No guarantees by me of this, my machine is under warranty and I have no real information regarding yours.
Cuisinart Warranty 1-800-726-0190
SOURCE: water leaking from bottom of coffee maker
The water hose on the bottom of the coffee maker is worn, due to the heat. It needs to be replaced. this is the second time for mine.
SOURCE: cOFFEE MAKER LEAKS CLEAR WATER FROM THE BOTTOM EVERY TIME I USE T
Have the same issue, looking for my receipt for warranty. All of us having this problem can't be wrong and it must be defective
