Question about Mitac Mio 168 Pocket PC
N u please help with connection problem
The pins in the connection soket have got bent can they be replaced?
Regards
Mick
  • Anonymous Nov 09, 2007
    HI YOU CAN BUY A REPLACEMENT PART TO REPAIR THE MIO 168 ,IT REQUIRES SOLDERING TO BOARD IN TWO PLACES
Tried it works fine !!
Posted on May 24, 2008
  • 537 Answers
Are they bent or broken off? If they are only bent you could carefully straighten them. If they have broken you would have to replace the connector which I believe is a 22 pin connector.
Look at this link for more technical information on replacement of this connector:
http://myweb.tiscali.co.uk/taximania/maxx/repair.html
Posted on Nov 01, 2007
Konica minolta 6501 error code c-c101
had a circuit board replaced recently??? if so check each and ever connection, pull each connection and reseat each connection one at a time while each connector is removed check all pins for a bent pin. Or replace the Print control board, Interface control board, image control board, and the overall control board, $$$$$$$$$$$$$$$$$$$$$$$$$ more then what you paid for the machine!!!! Then you will still have to remove each connection and reseat them and look for bent pins!!!!!
Jul 03, 2014 | Konica Minolta Bizhub C 6501 Color...
Phone says "connected to computer" even when no cords are connected
Hi. This problem is for micro usb soket of your phone 1st open your phone and clean usb soket with petrol and tooth brush.
Please clean properly and see if problem is solved or not then replace the soket
Apr 10, 2013 | Samsung C3300/3303 CHAMP QUAD BAND...
Hi, Ref, S4 manual, petrol, 6 plate Trying to find out if the pin from the clutch pedel to the clutch master cylinder should be straight or bent please? Have had an ongoing problem with the clutch pedel...
Hi Julian,the pin should be straight.the only way it could get bent is if undue pressure was applied with limited travel.your mech will understand.
Mar 30, 2011 | Audi S4 Cars & Trucks
My ds slot does not show up on my choose games even though i put the games in it says 'no ds card inserted" please help me i have my ds but only the gba slot works
There is probably one or more bent pins inside the top slot (SLOT 1). Remove the battery by removing the battery cover on the bottom (held ny a screw). Shine a small torch into SLOT 1 and look inside to see if any of the pins are bent differently to the rest of the pins. If any pins are bent they can be bent back to their correct positions by using a suitable small tool such as a precision screwdriver. If a pin is actually broken then the complete slot will need to be replaced.
If it is not a bent or broken pin, there may be some other type of blockage inside SLOT 1.
If there is nothing wrong with the pins and there is no blockage inside the slot, then there may be a dry joint where the slot is soldered to the PCB inside the DS. This kind of fault will require the DS to be opened with a special tri-wing screwdriver and the use of a multimeter to check all the connections. If you have soldering experience (and tools) then you can try re-soldering the connections.
Be advised that opening the DS is much easier than putting it back together again!
Feb 14, 2011 | Nintendo DS Lite Console
Power cable connection
connect to smps smps>24pin socket [white soket]motherboard as well as P4 pin also
Jun 24, 2010 | Intel D945GNT Motherboard
No picture...check signal cable Analog message following movement and re-connection
Check for bent pins in the signal cable. Unplug the cable from the back of the computer and look at the end, you will see small pins sticking out. We have seen many times when people move systems that a pin will get bent over and when you plug it in to the PC it gets flattened out all the way. If you find a bent pin you may be able to straighten it out with a pair of needle nose pliers but if it breaks you can get a replacement cable for $6.50 shipped, http://www.ccl-la.com/catalog/product_info.php?products_id=54
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 26, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Olympus fe-280 usb socket bent pins Anyone ever took one apart & attempted to fix?
open the camera ,take precautions of stativ electricity,discharge the flash condensor and then attept to fix the USB soket.
Mar 26, 2010 | Olympus FE-370 Digital Camera
How do i connect my extrernal usb ports
Just look at your motherboard you will see soket with 9 pin with written word USB1 or 2 so connect that soket with your external usb cable. it will work
Aug 17, 2009 | MSI 865GVM2-LS Motherboard
Canon rebel xti says cf card replace i have replaced same fault
Check with a magnifier and a flashlight the conditions of the CF memory reader pins. Usually this kind of cameras have the common problem of have bent or broken the CF reader pins. This may caused the original CF error. If you tried to format a CF memory card, then the bent or broken pins may caused the Error 99. By the way, error 99 is applicable to a very open range of problems (lens contacts, faulty shutter, CF memory card access errors, etc). If is under warranty your camera, once you confirm the reason of the problem, send it to Canon for repair. If is out of warranty, you need somebody to repair it, which is not easy for the common person. If need help on repairing it, please contact the ID user Great_items_2004 at ebay. Regards and good luck.
Jul 08, 2008 | Cameras
Mitac Mio 168 Pocket PC Logo
269 people viewed this question
Top Mitac Computers & Internet Experts
Alun Cox
iphone service
Are you a Mitac Computer and Internet Expert? Answer questions, earn points and help others
