Question about Lenovo ThinkPad Z61t 9443-XAU PC Notebook
\WINDOWS\system32\c_1252.nls "Windows could not start because the file is missing" I get this message when I try to start up. It suggests I try and start up using the original Setup CD-ROM....unfortunately I don't have it. Any suggestions?
    Problem Solver:
  • 3 Answers
You didn't say which operating system. But this usually happens in XP. You have a corrupt start up file.The easiest way to fix this is to boot the machine from an XP cd. When it asks you if you want to install windows click enter. Hopefully it will show that there is an existing copy of windows. Then it will tell you to hit R if you want to repair the existing copy of windows. If you have succeeded this far it is pretty much automatic after that. The repair install will ask for the product code (on the MS COA sticker) Hope this helps!
Rockman10
Posted on Jun 17, 2009
  • 10,515 Answers
The above error refers to Corruption/Deletion of the Windows Basic File.
The only way is to reinstall the Windows or Search for the above mentioned file.Add to the Window's directory and run.
To be really Honest, the second one would not a recommend option as it will add the frustration and time consuming to search for few files out of billions.
Any further help, let me know.
Thanks for using "Fixya".
    President:
  • 828 Answers
What windows system you use
Error prompt: \WINDOWS\system32\c_437.nls
you have a windows system file corruption on the c_437.nls file which is a national languages file required by windows to run.
repair this problem following these instructions-
1. Boot your computer from your Windows installation CD- ie-insert the CD and restart your computer.
2. Select 'R' for the recovery console and log on as administrator.
3. At the command prompt type the following:
cd system32
then press enter
4. Then type the following:
ren c_437.nls c_437.old
then press enter
EXPAND D:\I386\c_437.nl_ C:\WINDOWS\system32\c_437.nls
then press enter
(If your CD drive is different than D: or your primary hard
drive/partition is other than C:, substitute the appropriate
drive letters.)
4. Select yes when you're prompted to overwrite the existing file.
5. Reboot the computer.
Depending on the level of file corruption, you may have to repeat this
process for additional files. To do this follow the instructions above substituting the file name.
//javaftper
Aug 01, 2010 | Dell Latitude D620 Laptop (Latitude-C620)...
Error message on boot: NTLDR is missing. Set to
Follow this link:
http://www.tinyempire.com/notes/ntldrismissing.htm
than tell its solved or not.
Feb 18, 2010 | ASUS Eee PC 900 Notebook
I have an asus eeepc 900. i have an error message
hi charmed4031this netbook comes with an internal harddisk on which windows is installed but lacks any optical drives so far.
You will have to get an external CD/DVD-drive plus a Windows-CD for it from which you safely can reinstall windows or replace the missing file. Please find out which windows version you are using(Win200, Win XP Home for e.g.,), lend or buy this external drive, connect devices and let the computer work it's magic, if still facing diffifculties, you know where to find us ;-)
Sep 18, 2009 | ASUS Eee PC 900 16G Notebook
Samsung N120 Netbook won't start Windows. stuck on black screen.
See if you can download it from Microsoft. It seems to be related to the languge translators in Windows (NLS file).
Jul 31, 2009 | Samsung NC10-14GW Notebook
After Rescue n recovery with F11, i got error messeges & all data
probably not easiest way is get a cd and do a fresh install
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 21, 2009 | Lenovo ThinkPad T61 Notebook
C_437.nls file is corrupted and windows cannot start, i also do not have the windows installation disc.
boot in safe mode and run system restore if you cannot boot in safe mode you will have to get a disc and reinstall unless you know how to use the repair panel
Dec 17, 2008 | HP Computers & Internet
Turn on computer- Wont boot Please Help!!!
Borrow an XP install disk from anyone. Since you are not installing a new copy you don't need a keycode or serial number.
I am willing to bet however that you are going to need to do a re-install having lost this file to corruption. The source of the corruption is the unseen elephant in the room. Be aware that if you can get the computer running move any personal files to new new folder on the C drive. One that you create and not in 'My Documents' or any other windows created folder. When re-installing windows any/all windows folders are deleted and new, empty ones are created resulting in your loss of everything.
1. Boot the laptop;
2. press F12 to go to boot menu;
3. Selected CD/DVD-RW Drive;
4. Press any key to boot to CD; worked fine...
5. Press R to repair;
6. At the recovery console, selected 1: C:\WINDOWS and hit enter;
7. This brought me to C:\WINDOWS> prompt;
8. Typed this C:\WINDOWS> EXPAND -R D:\I386\c_437.nl_ C:\WINDOWS\system32\c_437.nls
type exit
9. And got the error message: The parameter is not valid. Try /? for help.
IF the disk is in the D drive then use this command instead: expand d:\i386\c_437.nl_ c:\windows\system32\
Oct 19, 2008 | HP Compaq Presario 6310US (DA201A#ABA) PC...
Os booting problem
Try running the repair console from the CD.. fixboot, Fixmbr, And chkdsk /p may repair the missing or corrupt file other wise you can replace/install the missing file with another good working system and put the drive in an external enclosure.
Jul 27, 2008 | Microsoft Windows XP Professional for PC
Acer lap top won't boot
without operating cd you will not be able to solve the problem
Jul 02, 2008 | Acer Aspire 3680 Laptop
Lenovo ThinkPad Z61t 9443-XAU PC Notebook Logo
830 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
