Question about Coleman Powermate 11 Gallon Air Compressor
Too low pressure for operating stapler product is coleman powermate compressor
  • Dean
    Dean May 11, 2010
    What are the pressure guages saying? i.e. tank pressure and regulated pressure?
  • 76 Answers
Is the regulator bad or maybe a leak on the head gasket
Posted on Jun 23, 2009
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
I HAVE A 4 HP GAS COLEMAN POWERMATE COMPRESSOR. THE COMPRESSOR KEEPS RUNNING AND WONT SHUT THE PRESSURE OFF UNTIL THE BLOWOUT VALVE BLOWS.THIS COMPRESSOR HAS A HONDA 4 HP GAS ENGINE ON IT.THE PRESSURE IS...
Coleman PowerMate CT4090410 Operator Parts Manual
This unit uses an loader valve to control pressure, it will unload compressor and idle engine back until the pressure falls below 95 psig and the speeds engine up and loads compressor until cutout pressure is reached. I've linked to manual and the unloader is
Coleman PowerMate CT4090410 Operator Parts Manual Page 18
The item number is 9 and part number is 070-0056.. This part is around $100-$110. Ive repaired this type part on air compressors used on mechanics service trucks ., Depending on your skill level and access to tools and parts, it might be better to purchase a new one.g take time ti read to read and understand manual. Good luck
Nov 10, 2017 | Coleman Air Tools & Compressors
Engine starts easly, but will not pump up to operating pressure.
Check your pressure switch.. There are two adjusting
plastic nuts on it. One for high, and the other is for low
setting. To increase your high pressure setting, turn it
clockwise. This should solve your problem.
Oct 30, 2009 | Coleman Powermate 4 Gallon Air Compressor
The pressure reads 40 psi on both guages on this
with it running check regulator knob .it pulls up turn right pressure should go up.if not regulator bad
Jun 20, 2009 | Coleman Powermate 11 Gallon Air Compressor
Coleman powermate 27gal 5hp air supply line and regulater gets very hot and blowes off hose
Is a shroud of any sort been took of ? is there oil in pump assembly ? Is there a fan on this model? At what pressure does the compressor stop pumping (should be less than 135psi aroud120psi) are you using it over it's duty capacity ei:sandblasting....?
Jun 04, 2009 | Coleman Powermate 27 Gallon Air Compressor
Coleman powermate compressor doesnt hold air
CHECK YOUR TANK PRESSURE ADJUSTMENT KNOB ON TOP A LOT OF TIMES THERE NOT SET AT THE FACTORY.HOPE THIS HELP'S
May 22, 2009 | Coleman Powermate 11 Gallon Air Compressor
Coleman compressor no build up of pressure
Parts for coleman are available at www.mastertoolrepair.com your compressor is listed as L0502710. If however you like to tinker, you can make a pretty good reed valve out of aluminum can material or other (any ideas?). It is fairly easy to cut, does not last as long as factory stainless steel, but for short term, why not? Good Luck
Jan 10, 2009 | Coleman Powermate 27 Gallon Air Compressor
your correct either the valves are worn or maybe just need cleaning as for the gaskets,idont know what part of the world your in but check out coleman on the internet or failing that ,i have maid these from gasket material suuplied from my local bearing supplier
Oct 28, 2008 | Coleman Powermate 02 - Gallon Air...
Checking oil in generator
I found some website help. I have this same problem.
http://www.powermate.com/faq.php?cat_id=3
http://www.powermate.com/faq.php?cat_id=3&faq_id=32
I also found out a lot about the Powermate company via a customer service email reply: This has an elusive customer service number that i have not tried yet.
Powermate Corporation is not a part of The Coleman Company, Inc. They have been an independent company for over 10 years and we have no information on their products.
Powermate manufactured generators, pressure washers, air compressors and air powered tools. Information about those products was available from
Powermate Corp.
125 Airport Road
Kearney, NE 68848
Toll Free: 1-800-445-1805 (disconnected)
or 402-758-6303 (disconnected)
Web Page: www.powermate.com
Earlier this year, Powermate transferred the right to sell air compressors and air powered tools to a company by the name of MAT Industries, LLC, 625 Barclay Boulevard, Lincolnshire, IL 60069, 1(800) 628-8815. This company may be able to help you with questions related to air compressors and air powered tools.
In March 2008, Powermate filed for bankruptcy protection. We understand that customer service inquiries to Powermate via emails, mail and telephone calls will not be answered. However, some information about Powermate and its products continues to be available at their website.
If the problem with your unit is with the engine, check the engine manual that came with the unit to determine whether the engine has a separate warranty from the manufacturer. When Coleman was affiliated with Powermate, they did. If so, you can contact the engine manufacturer for a listing of warranty centers in your area. The contact number should be in the engine manual.
If you are needing parts for a powerwasher, please visit the site
http://www.ppe-pressure-washer-parts.com/coleman-powermate-pressure-washer-parts for assistance.
Thank you,
Harold
Coleman Consumer Service
Aug 30, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate 11 Gallon Air Compressor Logo
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
