Question about FixYa Service
1990 accord ex sedan.
The temperature gauge is running high. both fans run. what do u think it is. head gasket or temperature sensor.
  • 715 Answers
Could be a bad thermostat or a clogged radiator, the cheapest would be to replace the thermostat
Posted on Jun 17, 2009
2010 mercury Milan. The needle goes to c when driving
check coolant level. have a compression test done to check for head gasket or cracks. If you have a viscous fan hub then replace it and check fan operation if an electric fan . Run fault codes to check for sensor faults.
Jun 01, 2014 | Cars & Trucks
Hello I have a 06 Ford freestar I'm getting a p1289 code also fans run on start up and temp gauge sits at cold
Head temperature sensor. Either the sensor is bad or you blew a head gasket. Since you indicate that the fans run on start up it is most likely the sensor.
Sep 07, 2012 | Ford Freestar Cars & Trucks
1990 honda accord ex overheating fans not turning on, tested sensor conectors with jumper and fans come on.starts overheating at stoplights but temperature drops to normal while driving. have been told...
You will have to replace the fan sensor. If the fans are not working then the temperature will rise when stopped and cool down when running because of the air coming through he radiator.
A head gasket leak will show up by lose of water and bubbles in the radiator, with it topped up to the neck of the filler. Worst indication is water in the oil and out the exhaust.
Oct 05, 2011 | 1990 Honda Accord
Equniox have changed thermosate and coolant sensor and no leak still running hot
There are several things that can cause an engine to overheat. This is why the problem should be DIAGNOSED before spending a bunch of money replacing parts. You can go broke replacing parts and never fix the vehicle.
First, is your radiator cooling fan working? If not, then you must diagnose the cooling fan and cooling fan circuits to find out why.
Did you replace the coolant sensor for the computer or the one for the gauge? (Yes, there are two engine coolant temperature sensors) This brings us to the next question:
Are you sure the engine is actually overheating or is it possible that the gauge could be "lying" to you?
The actual engine temperature should be taken with an infrared thermometer to see if it agrees with the gauge.
When you changed the thermostat and the temp sensor, did you bleed the cooling system properly? There may be air trapped in the engine.
Has the engine been checked for a possible blown head gasket? If it has overheated at all, it is highly likely that you may have a warped cylinder head and/or a blown head gasket.
Is the water pump circulating the engine coolant like it is supposed to? You could have a damaged water pump impeller or a clogged radiator keeping the coolant from circulating properly.
Sep 10, 2011 | 2005 Chevrolet Equinox
1992 Toyota Celica - coolant spraying out of overflow, fan didnt seem to be going on. Smells like coolant, so dont think that it is the head gasket. Temperature gauge going up now, but not at first....
There is a fan coolant temperature sensor on the bottom of the radiator, it has an electrical connector on it, with the key on disconnect the connector, if the fans run constantly with the connector off replace this sensor.
Aug 19, 2011 | Toyota Celica Cars & Trucks
Hello, I have a 1995 mercury sable and just replaced the upper radiator hose last weekend and for the past week, I have been dealing with overheating, I have added 50/50 coolant and the temperature...
First replace your Thermostat, and then have your Electric cooling fan checked.
Try getting a scan at Autozone, Advance, or Oreillys autoparts. They will do it for free. Or if you just want to buy a few parts, observe if the cooling fan even comes on. There are 2 temperature sensors on most Ford's and one makes the dash gauge work and the other makes the Electric cooling fan work. Just have the car a little warm and when you get the dash gauge to move, disconnect the temp sensors one at a time until you find the one that controls the gauge. The remaining sensor controls the cooling fan. Remember, the gauges only work when the engine is running.
If your cooling fan still does not work, ask the parts guys how many speeds your vehicle is suppose to have on its fan. Usually, when the A/C is turned on, high speed kicks in; for sure when you have overheating, it should be on high speed. The Electric cooling fan has a Relay that can be bad. The fan motor can also be bad.
The loss of Antifreeze in the system can be from boil over. As long as the car runs decent, there is no reason to expect a blown head gasket. With the Radiator cap off, you may be able to see bubbles on the surface of the radiator if a head gasket is allowing compression to get into the cooling system.
Just start with the easiest things like a Thermostat, then go to the next solution and work your way through the possibilities. I hope my comments are useful to you.
Jun 26, 2011 | 1995 Mercury Sable
2000 focus temp gauge fluctuate from norm to red when travelling at speed ..but all coolant levels ok and not loosing anything and fan working.
Hello, on your model the Head sensor sends a signal thru a resistor pak and the ECU. If the fan runs on high speed when you turn on the A/C then the resistor pak is good. If the resistor pak is bad neither of the fans will run when the A/C is on. Change the resistor pak.
If the fan runs on high with the A/C on, then the head sensor is not indicating a high temperature condition when the A/C is off. The A/C switch overides the head sensor. The head sensor is on the Passengers' side of the car above the Alternator. The head sensor is not throwing a signal to start the High speed fan. The head sensor is a long pin screwed into the head at that location.
While you say the fan is working, it may not be working well enough because of the head sensor.
Mar 13, 2011 | 2001 Ford Focus
Engine overheating
is the radiator low on coolant? dont think you have a bad head gasket, does sound more like a bad cooling fan and/or thermostat
Feb 07, 2010 | 1991 Honda Accord
FixYa Service Logo
42 people viewed this question
Top FixYa Computers & Internet Experts
Mark Magill
Mark Magill
Robin Hill
Robin Hill
Are you a FixYa Computer and Internet Expert? Answer questions, earn points and help others
