Question about Car Audio & Video
1997 acura rl - stereo is dead. tried entering code and changing fuse(in dash), to no avail.
  • old2nu442 May 11, 2010
    Does the radio actually light up and/or is the display working?
  • 578 Answers
Back up fuse in the front fuse box
or inside car if you do all that and no radio you need a new one
Posted on Jun 25, 2009
97 rl changed drive rear abs sensor replaced now codes 16 and 18 come on for abs help
did you read the FSM on this ?
the FSM covers the tests and why?
fixing ABS book free is a tall task, no?
buy the factory service manual, for this old a car, try fleabay.
here i will search for you.. see this.
RTM, ,yes, RTM twice sure.
http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313.TR4.TRC1.A0.H0.X1997+acura+rl+FSM&_nkw=1997+acura+rl+FSM&_sacat=0&_from=R40
Feb 13, 2014 | 1997 Acura RL
1997 Acura 3.5 RL right brake light not working (all other rear lights - both left and right work). Changed bulb (two separate bulbs) and still not working. Checked all fuses under dash and hood. Is...
The problem is the socket. Remove the bulb and bend the tabs in the socket so they make contact with the bulb. If this doesn't work you will have to replace the socket. A wire is broke and they usually break at or in the plug.
Jul 19, 2011 | 1997 Acura RL
I need a stereo code for a 1997 acura rl
go to an acura dealer with the vin#.
Sep 02, 2010 | 1998 Acura RL
Have a 1997 acura rd that needs code to operate
You have to do this: If you have jumped or replaced the battery at anytime this will happen. You have to get the serial number off the radio by removing it or partially taking it out to see the numbers on it try not to remove any cords. With the stereo out (to make sure you get the right number off of it) call an Acura dealership with the number and they will give you the another number to enter into the stereo and directions on how to punch the numbers in. Make sure while you have the stereo out you write the serial number down and keep it in a safe place also the number that the Acura dealership gives you because if you sell the car or if it happens again its easily accessible. Good Luck!
Aug 03, 2010 | 1997 Acura RL
Need radio code for 1997 acura rl, didnt work when i brought it
You need to get the serial number off the sticker attached to the radio. It will require pulling apart your dash. Call an Acura dealership with that serial number and they should be able to provide you the code.
Apr 27, 2010 | 1997 Acura RL
97 Acura 3.5 RL-dome lights, bose stereo won't turn on
Are you sure no fuse was blown? there are more than 1 fuse box (in engine and under dashboard).
Jan 30, 2010 | 1997 Acura RL
I bought a acura 1997 3.5 rl and i need the code for the radio.
Here is how: If you have jumped or replaced the battery at anytime this will happen. You have to get the serial number off the radio by removing it or partially taking it out to see the numbers on it try not to remove any cords. With the stereo out (to make sure you get the right number off of it) call an Acura dealership with the number and they will give you the another number to enter into the stereo and directions on how to punch the numbers in. Make sure while you have the stereo out you write the serial number down and keep it in a safe place also the number that the Acura dealership gives you because if you sell the car or if it happens again its easily accessible. Good Luck!
Nov 24, 2009 | 1997 Acura RL
I have an acura 02 rl the radio is giving me a
Jul 18, 2009 | 2001 Acura MDX
1997 Acura RL cigarette lighter Accessory outlet not working
I had the same problem, turns out tere was a fuse in the fuse panel beside the brake pedal that was blown out, however the fuse wasn't for the lighter it was for the headlights or something but the headlights we're still working.... CHECK ALL of the fuses, not just the lighter
Nov 13, 2008 | 1997 Acura RL
Car Audio & Video Logo
131 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
