Question about Mitsubishi WS-65611 65" Rear Projection Television
Mitsubishi 52725 shuts itself off after hrs of good picture, takes an unplugging and plug back in wait 60 seconds then repeat in a shorter time span. I have replaced 12 caps and put in a dpdt switch, the picture is better than ever but it still shuts itself off and im losing my patience!!!
  • justin NORSTEN Jun 17, 2009
    WHERE IS THIS FUSE LOCATED AND HOW CAN i BUY A NEW ONE
  • justin NORSTEN Jun 18, 2009
    thats not it It has been replaced and still shuts off after an hr or two should i scrap the tv I put time n money into this but the problem still exist
  • Mitsubishi Master
  • 8,617 Answers
Thermal fuse is the most likely cause
Posted on Jun 17, 2009
  • Sonny Berry
    Sonny Berry Jun 17, 2009
    Heres a picture of where its located directly above the Fan. The part number is 299P280010 they are about 85.00 at MCM or UED.net or you can get one for about 45.00 at the following link they dont list it, but I know they have them you would have to leave a email or call them.
    http://servicemanuals.vstore.ca/
  • Sonny Berry
    Sonny Berry Jun 18, 2009
    Did you also replace the same thermal sensor thats for the ;amp? Your set has two one for the DMD and the other for the lamp
I replaced the lamp on 62530 worked fine for a few days, now the picture won't come on and the lamp light does come on.
unplug the unit wait 30-60 seconds & plug back in. Try unplugging your source at TV input & then plug it back in
Jan 03, 2015 | Mitsubishi Cooling Fan Set for WD-62530
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
Feb 04, 2013 | Samsung UN19D4003 TV
Vs-60703 turns off after couple of hrs
Two common issues with this set, one is bad solder connections that develop with age and the other is a possible Glycol leak which usually just gets gradually worse.
This set MAY have the self check feature, when it shuts off do not unplug it, press menu and input on the front at same time for at least 5 seconds and release both buttons, if it has the self check the power light will blink a two digit error code like 2 blinks, 3 blinks and pause and then repeat the code for a total of 5 times.
Let me know if you find an error code what it is, if you unplug the set it clears the error code and you must wait for it to fail again before repeating the test.
Dec 11, 2012 | Mitsubishi VS-60703 60" Rear Projection...
Unplugged my Ws-55711 TV to move it to another room so the carpet could be cleaned. When I moved it back and plugged it in, the green light kept blinking for more than 60 seconds. I unplugged the TV for...
Open up the front, look under the right side picture tube. Look for puddle of oil on signal board. If you see this, it has bad picture tube & signal board. Not a good repair.
Jan 17, 2011 | Mitsubishi WS-55711 55" Rear Projection...
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
My mitsubishi 52725 shuts itself off after acouple hrs
Its most likely the thermal fuse which is causing the problem. It gets up to operating temp then shuts down.
Jun 17, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Another problem with my 52725
It may very well be a connection issue with one of the wire connections as its not giving you a error code. I would double check the wire plug connections
Jul 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Please Help !!! my Motorola RAZR V3i is automatically shutting down ...
take the phone and have the firmware reflash this should correct the issue that you are having
Jun 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Hitachi 60" picture flashes on and off.
I've had the same issue although I don't unplug everything. I turn it off and then unplug it from the wall for 10 seconds then plug it back in. Seems ok after that. Has happened 4 or 5 times over the 10 years I've owned it.
Dec 20, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Mitsubishi WS-65611 65" Rear Projection Television Logo
227 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
