Question about Fisher Dishwashers
The door of my dishwasher cannot be closed although inside is empty. There is no click sound when I will try to close the door. Mashine works if I keep the door closed form outside but need to be keept during the whole process.Any idea how to fix it? Thanks
  • 583 Answers
When your dishwasher door has a problem, check these:
1) Latch: The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
2) Springs: Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
3) Hinges: The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough.
4) Door seal: If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
thanks.keep updated and plse do rate this solution positively.
Posted on Jun 17, 2009
Arm won't retract and door will not close.
hi
here can be two main problems
1) if once you close the door is a continuous click then your problem is the the electric/mechanic lock from top of your dishwasher
2) if once you close the door nothing happening is the switch from inside of the door this one can be tested making a bridge bet-twin the 2 wires are connected to the switch ( please make sure you unplug the dishwasher from mains before you carry any work on it )
once bridge done and dishwasher plug back to the mains the arm will retract in even if you not close the door
Aug 24, 2013 | Miele G 2872 SCVi 22 in Builtin Dishwasher
Dishwasher door will not close properly
usually d/w doors are fine for long time.
1. check if anything blocks it to close securely e.g. the cutlery basket or the dish racks not fully sliding in or may be off track/chanel.
2. try running a cycle empty and see if it closes after doing #1.
Jul 25, 2013 | Neff S51M53X0 24 in. Built-in Dishwasher
Kitchenaid dishwasher KUDS30IXBL door locked open, will not close
There should be a type of hook inside the hole where the door latches to the machine. Hold the handle up and rotate the hook latch so the open side is pointing towards the machine. The click you heard was the latch that holds the door closed moving to the closed position when the door was open, and it needs to be in the release position.
Jan 28, 2013 | KitchenAid KUDS30IXBL Builtin Dishwasher
Close the Maytag dishwasher, cycle starts, but I noticed a leak! Dishwasher door can be opened by putting your fingers on the edge and pulling it open. Tried it again, door clicked, thought it was ok but...
your problem appear to me like it come from your upper basket . pleas try 1st to ensure the basket goes inside untill the end it is important.. thank you
Jun 10, 2009 | GE Dishwashers
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher just emptying
I am at the end of my tether. I have bought a new door latch for my Bosch SGS 43E02 GB45, so door now closes properly and have managed to stop the leak under the front left hand side of the machine. Howver it sounds as if it is constantly emptying. It does not go onto the new wash cycle just keeps pumping out the water. It did run a quick rinse yestreday but now is back to the constant emptying problem. Even when I open the door it still keeps running and staying on a emptying cycle despite there being no visible water left inside the machine. Please help!!
Sep 12, 2008 | Dishwashers
Dishwasher Door Gasket
A new gasket will usually seem too tight, as long as it's the proper gasket and you are sure it is properly in place, this may help. Using a hair dryer, carefully warm the gasket up, don't get it too hot that it deforms. Then close the dishwasher door making sure it latches. Run it through a cycle and use the heated dry option. Leave it closed overnite. This should help, although it may seem a little tough to close for the next few times you run it. It will get better with use.
Jan 24, 2008 | Dishwashers
Indesit dishwasher
I had the same problem, so I took the door apart as explaned above, found it was gunged up with residue from the washihg cycles. Gave it a good clean, while the part was disconected of course, and hay presto! the door works like new again.
Jan 06, 2008 | Indesit 24 in. D63 Free-standing...
Dishwasher not starting or emptying
bit difficult to diagnose this but worth while splitting the door and carefully examining the wiring loom where it goes round the corner at the bottom of the door. its quite common to get breakages at this point as it flexes every time you open or close the door
Mar 20, 2007 | Miele G880 Dishwasher
Door won't close
Had this problem and all i did is pushed the eject button while it was open and it made some noise like it was ejecting and then after that i could shut it again. Hope this helped.
Jan 27, 2007 | Panasonic NV-DS60 Mini DV Digital...
Dishwashers Logo
73 people viewed this question
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
George Merkley
George Merkley
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
