I installed my head unit and new speakers and everything works in the car. however, when i cut up my volume past 17, it cuts out. Why would it do this?
are you running an amp? or just the head unit with speakers? cause if you are running an amp, it may not be the right power for the speakers, and could be cutting out from being over powered. if it is from the headunit only with no amp, then you might need to replace your speakers to the right ohmage, and wattage size, you may be to low on it.if you are running an amp tho, check the amp wattage,it might not be powerful enough to power the speakers.and you would need to step the amp up , if the amp is a 100watt rms remember that it is not really 100 watt, it is broken down about 35 watts per speaker.and if you try over driving it the amp will over heat and shut off.
My car stereo plays for awhile then shuts off and comes on again, and so on and so forth. Before it...
(More)
My car stereo plays for awhile then shuts off and comes on again, and so on and so forth. Before it was because my inline amp fuse was not screwed on tight enough, but now it is. Also, when it shuts off, my lights and other car electrics dim and bog down.
When on the "CD" feature, the dispaly reads "disc read" and then...
(More)
When on the "CD" feature, the dispaly reads "disc read" and then "error." Why is this coming up and how do I fix it?
My alpine cda 9884 is about a year old. A few months ago, the display started flickering and...
(More)
My alpine cda 9884 is about a year old. A few months ago, the display started flickering and sometimes i need to push the faceplate into its receiver more to use the buttons. I know it's a connection problem. Is there any way that I can keep the gold contacts in contact with each other?
Sound is perfectly fine when tuner is on but when in ipod mode right side sound is VERY quiet. I...
(More)
Sound is perfectly fine when tuner is on but when in ipod mode right side sound is VERY quiet. I almost have to turn it up to 20 to hear anything from it. All connections/ speakers are ok. Have tried multiple ipods and still have same issue.
