Best Solution
posted on Jun 17, 2009
Rank: Master
Rating: 91%, 4 votes
Maybe this will help, found online:
http://autoforum.classifieds1000.com/Chevrolet-S10_Blazer/208607-radio_unlock_code
".... Call a GM dealer. They will instruct you how to extract codes from your
locked radio. Give them the codes you retrieved from your radio. They
will call a special number at Delco radio to get you an unlock code.
They (the GM dealer parts or service person) will give you the unlock
code, and the procedure for your specific radio. Follow the
instructions, and you're radio is working!Now, here is the big tip
on this- Some dealers will get the code for you NO CHARGE. Others will
charge you around 50 bucks. It depends on the dealership, and how much
you deal with your local dealership. I worked in a GM parts department,
and I had NEVER charged one of my regular customers for the code to
unlock their radio.
Also, no dealer will unlock a radio, unless
you can show ownership of your vehicle. It's just like getting new keys
form VIN# for your vehicle, from a dealer, it's a legal issue."
ALSO found:
http://www.thechevytruckclub.com/forum/showthread.php?t=2534
"... Try this, it worked for my 1998 Sunfire and a 1975 Monte Carlo.
Press & hold the 2 & 3 buttons @ the same time for about 10
seconds; a 2 or 3 digit code will appear, write this # down,press &
hold the am/fm button for about 10 seconds: another code will appear,
write this # down, then call 1-800-537-5140 and enter 202108 followed
by the # key, then enter the #'s that you wrote down from your radio
followed by the * key. The call will give you a 3 or 4 digit override
code. Write this code # down so you have it if you ever need it again.
Enter this # into your radio following the instructions in your owners
manual. If you get an override code that starts with 0, you drop the 0
when entering the code into your radio.
If you don't have an owners manual, try this, press & hold the hour
button until the first 2 digits of your code come up, then press &
hold the minute button until the last 2 digits show. Then press the
am/fm button. This should reset your stereo. It did mine...."
