Question about Danby Portable Air Conditioner
Compressor cuts in and then cuts out
Turns on and air conditioning cycle starts then reverts back to fan only.
ac cycle only lasts about 30 seconds or so no cooling, fan runs constantly.
    Sergeant:
  • 340 Answers
Sounds like compressor is locked up or bad compressor start components or could be tripping on a high pressure switch is condenser clean? .T
Posted on Jun 17, 2009
Air conditioning not turning off
This is due to the fact that the solenoid relay is stuck and so the ac is not cutting off. You need to open the hood and check after starting the car. If the fan is cut , does the ac cut off, if not the relay or the solenoid of the compressor must be checked.
Jul 03, 2012 | 2010 Nissan Sentra
Air conditioning not blowing cold after I changed blower resister
if the fan is running inside and the environmental controll is set to cool the AC compressor under the hood a click is heard and the compressor should start, it should cylcle on and off periodicly , if this dos not happen Have your AC system checked.
Jun 10, 2012 | 2002 Isuzu Rodeo
My ac central air is blowing air but not cold
Problem #1:Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device known as a "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning compressor. Another good device is called a "5-2-1" kit.
Jun 22, 2011 | Goodman CKL36AR36 Air Conditioner
We have Goodman AC unit...not sure what kind. It has blown VERY cold until the last few days where it would stay a little above where I had it set. Then yesterday I realized it was incredibly hot. My...
If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning systems.
Jun 11, 2011 | Heating & Cooling
Dometic Duo Therm Ac, Fan runs, Compressor cuts in and out?
your compressor is locked up. i would try replacing the round start capacitor. you need to check what the exact rating for yours is but I believe one of these two will work for ya. In the meantime do not continue to try to run it, it will kill the compressor.
seth
53-64 mfd
45-53 mfd
Jul 19, 2009 | Dometic Rooftop RV Air Conditioner
SAAB 9000 1995 ACC Stops Working When Car gets Hot
check the relay maybe faulty and overheating
Jun 12, 2017 | 1995 Saab 9000
Compressor fan cycles on and off .1986 carrier mo#38eh0363300l
Usually compressors cycle on and off due to the low preasure switch which disconects the compressor when their is a freeon leak. Put the gages on it and see if the preasures are correct.
Jun 26, 2009 | Carrier 38CKC036 Air Conditioner
Ac compressor cuts on and off and no cool air blows out .
the magnetic clutch used to drive the compressor might have a short.
Apr 29, 2009 | 1998 Mercury Mountaineer
COLMAN TSR
3000 Watts is a little short on the power necessary for the compressor to restart. When it compressor starts it may draw 27 amps or more for a split second. 3000 / 120 = 25 amps. when the fan slows down it is telling you the voltage has dropped and it doesn't have enough power. After the pressure has balanced out in the A/C system the compressor can start against no pressure difference.
Jun 16, 2008 | Coleman Mach 15 Air Conditioner
Danby Portable Air Conditioner Logo
347 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
