Just Connect it to your Computer using the USB Provided. Once your Done with it, Go to My Computer, Select your Music Player there, Go to Music or Sound File Folder, Just Click on the Song You want to Delete and Delete it.... Good Luck!!!!!
Go to your iTunes library of music. UNCHECK the songs you don't want from that list. Then resync the phone and it'll remove all that you unchecked from the phone...
Confusing and over complicated, yes. But the list on iTunes is the list in the phone. So what ever you check or uncheck is whats on or off the phone
Follow the below mentioned steps : 1 Plug the MP3 player into the USB port. Open Windows Media Player, which will recognize that the device is plugged in and register under the "Sync" tab at the top. 2 Click on the "Sync" tab and and the library that is on your MP3 player will be displayed. 3. You can select individual songs or albums for deletion. Simply right click on the song or album to be deleted and scroll down to the "Delete" option. 4. After selecting "Delete," another window will come up which says "Are you sure you want to delete [title of song]?" There are two options at this point--you can delete from the library only or from the library and your computer. Select the one or the other and click "OK." The song will be deleted. The change will be displayed within the library onscreen. 5. When you unplug the player from the port, the library will adjust the files to reflect the change. The player will say "configuring library" or some other message to that effect. Once this has finished, the main screen will be displayed. Depending on the model of the MP3 player, there may be a message stating "library updated."
In case of any additional help please revert back.
http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <----
See this tip posted here.Copy this address into a new tab or window.
Also try and crate a new folder on the player, put your music in that folder.
YOU CAN EITHER DELEATE IT BY 2 WAYS:
1. GO ON UR MP3 PLAYER AND ON THE SONG, PRESS THE MIDDLE BUTTON AND SCROLL DOWN TO WHERE IT SAYS DELEATE OR U CAN PLUG IT N 2 THA COMPUTER AND RIGHT CLICK THE SONG AND CLICK DELETE
1.Go to the MSC menu 2.Press MENU button 3.When you see a song displayed in the LCD, press the Play key to pause the song 4.Once song is paused, press the MENU button 5.Select “Delete All” 6.Use the Menu left/right keys to toggle between “Yes” delete and “No” don’t delete
-Tha Mp3 Doctor
1.Go to the MSC menu 2.Press MENU button 3.When you see a song displayed in the LCD, press the Play key to pause the song 4.Once song is paused, press the MENU button 5.Select “Delete All” (all) or “Delete File” (one-by-one) 6.Use the Menu left/right keys to toggle between “Yes” delete and “No” don’t delete
-Tha Mp3 Doctor
You only have to go to the album that the song is listed on, play the song, go to memo and one of the choices will be to delete the song, but you can only do it from the album listing.
