Question about Kenmore 60721 Refrigerator
Odor from under kenmore refrigerator
Odor has been eminating from under refrigerator off and on for about a year. Seems to be a "plastic" smell, which fills the kitchen. Tech checked refrigerator. It's eminating from the plastic non- removable drip pan. It would be great if I could replace with metal perhaps.
Boba
  • 64 Answers
SOURCE: I cannot get to the drip pan under refridgerator to empty it. It is filled with sludge and smells bad
Thank willie for helping with one: "Well, it looks like the pan is a seperate plastic pan and not the compressor mounting pan like some of the newer ones are. It appears that you have to remove the condensor fan motor and mounting bracket then maybe the pan will left up and over the compressor, or maybe there is enough room to lift the pan up and out the front over the condensor coils"
Posted on Jun 11, 2006
watugot
  • 290 Answers
SOURCE: Foul rotting vegetable type odor in top of Kenmore refrigerator
If the icemaker motor or heater short out it will cause a foul odor. I have never heard it described as cooked broccoli, but it can be pretty bad. Remove the icemaker and inspect the bottom of it where the heater element is and remove the white cover of the motor and look in there. You can take the three screws out of the motor module and see if anything is burned on it.
If you can rule out the icemaker, the next things to check would be the evaporator fan motor and defrost heater. Generally, if a fan motor starts causing an odor it will stop running completely and if a defrost heater goes out it will quit defrosting. It is possible, but unlikely, that something has gotten into the evaporator area and is sitting on the defrost heater so that it is "cooking" during the defrost cycle.
Check the icemaker first, it is the most likely cause of the odor. Post back with complete model number if you need further assistance and we will go through checking everything else.
Posted on Oct 24, 2007
SOURCE: odor in fridge
Probably getting a new Fridge-mother doesn't want to continue to deal with repairs. Thanks anyway.
Posted on Oct 13, 2008
SOURCE: Refrigerator Smell
remove grill. pan will not come out ( leave it in place ) took an empty liquid dish detergent botlle of bleach and water squirt into pan let it sit - scape if needed . then take a wet/dry vac - repeat)
I will let you now if the odor is completely gone
Posted on Oct 17, 2008
  • 10865 Answers
SOURCE: I have an odor cause my fridge has been closed with no power
All refrigerators have a drip pan. Get down on the floor, remove the lower panel, it lifts off, and look inside. there is the drip pan. Clean it thoroughly with vinegar water
Posted on Jun 12, 2009
2when I open refrigerator door there is a terrible odor from the refrigerator. Have removed anything in the refrigerator that could possibly be smelling. got any ideas?
Have you removed the bins and cleaned under them. Sometimes the overflows and drips accumulate there.
It the refrigerator is clean, then baking soda usually helps with absorbing the odor.
But if you still have odor being produced and the unit is clean, you need to look further. If it is a chemical smell you might want to roll the unit out and check to make sure that there isn't a creamy looking liquid on the floor, which COULD be freon.
But the most likely item is that you have some bacteria growing in the drain line that is producing the odor. Suggest you mix a 50/50 mix of bleach and water and pour that down the drain to kill the bacteria. Do that several times over a day or two and see if the odor goes away.
Jun 12, 2011 | Kenmore 53642 / 53644 Side by Side...
Odor eminating from freezer
Dead mouse or rat is a definite possibility.
May 04, 2017 | Haier RRTG18PABB (207 cu ft) Refrigerator
Have a Kenmore model 106.5702602 side-by-side for 1 year and can't get rid of freezer odor...have tried everything and can't put anything in freezer that isn't affected by this smell. Help!
the air blows from freezer to fridge side and then returns from fridge to freezer,so it could be and usually is something on fridge side causing odors or funny tasting ice cubes,check under bottom draws on fridge side,what kind of odor is it?
Nov 28, 2009 | Kenmore Refrigerators
My 2 month old Amana Refridgerator with Freezer on
If your sure about spoiled food. Spoiled lemons are one of the worst, and the machine has not been abused, it's a problem of the selling dealer. Fan motors have been known to create an odor when their windings start to burn. Plastic items that become detached from the interior cabinet and wind up laying on the defrost heater which gets very hot during defrost is another, however, I would demand a service call (free) since everything on it is under warranty. Make sure it's creating the odor when the tech shows up.
Oct 30, 2009 | Maytag MFD2561HE Bottom Freezer French...
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
Foul dead animal smell from kenmoore side by side refrigerator/ice maker
I'm sorry that I don't have a solution, but we have the exact same problem with an older model KitchenAid side-by-side. Did you get this problem solved? If so, can you share what you did?
May 27, 2009 | Kenmore 50522 / 50524 Side by Side...
Our Kenmore Coldspot has an awful odor whenever you open the door
use straight bleach on it. sponge down the whole inside with bleach and if you can leave the doors open on it to let it breathe and clear the odor out. bleach kills most smells if left on for awhile.go over it a couple of times if you have to to get rid of the smell.
Jan 17, 2009 | Kenmore Refrigerators
Odor in fridge
Oct 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Burning plastic smell INSIDE refrigerator
look for a door/light switch, and depress it do the lights go out?? bad switch will keep the lights on and melt plastic lens covers.. could also be nothing and you happened to open open the door right as a defrost cycle was completing( there is a heating elemnt in your freezer) watch your dairy, ice cream nad milk are real good indicators of refrigeration issues. as far as runnig all the time no real" time limit" as to how long it should be running.
Mar 03, 2008 | Refrigerators
Kenmore 60721 Refrigerator Logo
182 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
