Question about D-Link AirPlus Xtreme G DI-624S Wireless Router
Router will not work wirelessly
I have a di-624 router. my comp is wired into it, but i cannot connect my xbox wirelessly to it. the status light is slowly blinking, and so is the WLAN light. the WAN light is strobing. also, i cannot set a wep key. if i do, nothing will connect.
    Scholar:
  • 149 Answers
Reset your router via the recessed reset button on the back, this should reset your router back to factory default settings.
Login to the router and reconfigure as needed.
Good luck, God bless
-Carlos:
Posted on Jun 17, 2009
Di-624 status light flashes steadily & no output to pc's connected
I would suggest you to reset the router once. Hopefully that should help.. If the lights continue to blink, you might have a dead router.
Thanks Ranjit ranjit@supportminds.com
Jun 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Router problem
May i sugest that you get a replacment rounter.
Jan 03, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Lights are solid green: WAN, local network 1,2,3,4
If that is status of the lights on your router there's a big possibility that its already bad and needs a replacement, but you can first try to reset it and check if that will correct the problem
, To reset the router just press and hold the reset button for 30 seconds while the power is ON then after that check if the lights are back to normal if still the same light router is already bad...
Dec 01, 2008 | D-Link AirPlus Xtreme Super-G DI-624...
I can't connect to wireless
looks like a firmware corruption. try running a firmware update from http://support.dlink.com/products/revision.asp
Oct 15, 2008 | D-Link DI-624M Router (DI624MRE)
Can I piggyback a wireless router onto a hard-wired router?
Yes, you can connect the DI-624 to your exitsing EBR-2310, you just need to connect the a cable from port 4 of the EBR-2310 to the internet/wan port of the DI-624, then after that you can already use now the wireless to your laptop and also the wired router to your desktops.
But I may suggest you to just replace the EBR-2310 with the DI-624 so you will only be using 1 router that can cater your laptop and also your desktop, Just connect the cable from your modem that is conencted now to your EBR-2310 to the internet/wan port of the DI-624 then run the setup CD that should be it.
Hope that helps...........
Aug 30, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
DI-624 problem with wireless network
Buy the N router! That is the only solution. My signal weakened and went from the whole home to less than two feet if that at times. I bought the N router and it worked just like the G one did when I first bought it. Ya think somebodies got the limited life span worked out?
Jul 10, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Dlink solutions
you just cleck dlink, then properties, then cleck advance check the computer internet
Jun 18, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
DI 624 Wireless Broadband Router
So- Red - First of all don't rate yet. This will probably take a couple notes. So, let me make sure I've got this straight:
AT&T
V
V
Modem>>>>Linksys>>>>DLink( no status or pwr lt)
v v
ptr ptr
Is this crude diagram about right? Are the ptrs wired or wireless?
How many pcs? Wired or wireless? Getting their ip from which router? Linksys model #? Operating systems?
May 14, 2008 | D-Link AirPlus Xtreme® G DI-624 Wireless...
D-Link DI-624 wireless router is not working after firmware upgrade try
Try to unplug the router and hold in reset button for 30 seconds see if that works, you probably did that already, But if you can get your computer to respond you should be able to open software Bios. and do your firmware update from there. If not I believe a hard reset is with the router plugged in and holding reset button for 30 seconds, I don't know I sure hope that resets it for you. Thanks take care
Dec 23, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
D-Link AirPlus Xtreme G DI-624S Wireless Router Logo
228 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
