Question about Samsung AW0603B Air Conditioner
When do you know to add coolent to a central cooling unit
  • taa43 May 11, 2010
    when the whole system is clean evaporator , condenser and blower wheel then and only then can you accurately charge a unit if freon is needed their is likely a leak that needs professional repair
  • 21 Answers
You dont add coolant to centrl air systems. They have to be charged with the appropriate refrigerant by an EPA certified technician. If the unit seems to not be cooling sufficiently that would be your sign to call someone. this is generally an item checked on an annually cooling heating inspection and tune up. Unless the unit is very old or leaking refrigerant somewhere there really shouldn't be an issue since it is a closed system. Be sure you need a recharge before asking for one, it is not cheap by any means, depending on the type of refrigerant it can run you anywhere from 25-55 dollars per pound and the typical system takes 6-10 pounds to charge fully.
Posted on Jun 17, 2009
Cannot locate cold fill line on impala 2008 coolant overflow tank
Just fill it up 1/4 full with coolent. Coolent expands when hot, which will fill the tank up more, so don't over fill too much. If you think your low on coolent, let the engine cool down, and open the radiator cap and fill it full from there. Filling the tank, will not add ANY coolent to the radiator untill it warms up (expands) and cools down (contracts pulling in coolent from the tank only at this moment.)
Dec 04, 2013 | Chevrolet Impala Cars & Trucks
Bleed cooling system
Drain out coolent from the drain located near the bottom of your radiator. Add whatever your going to use as the flush. Start engine and let warm up completly. let sit till cool. Drain. Refill with proper coolent.
Dec 01, 2013 | 2003 Chevrolet Impala
Found oil in my coolent expansion tank
Generally speaking, if you have engine oil in the cooling system, you have a leak somewhere in the engine, which could be a head gasket.
Is there any sign of coolant in the engine oil ?
Jul 30, 2012 | 2005 Cadillac STS
My A/C blowing air, but it is not cool. It has started freezing up. We just replaced the air filters and since then it is freezing up. We even gently cleaned the a/c coils before replacing the filters. ...
Hello, sounds like it is either a low charge or lack of airflow, what type of filter are you using? sometimes those filters that claim to be super effecient will actually cut down on your airflow and cause the ac to freeze up.
Jul 15, 2011 | Intertherm Heating & Cooling
I need to replace coolent but I don't know what type I need
eythelene glycol any colour or make ,buy the 100% pure stuff and add it neat ,use the whole cooling system with 100% it will never corrode inside the engine .
Nov 19, 2010 | 2004 Suzuki Forenza
My temperature gage is going over in the red and my heat is not
Check the sensor which controls the cooling fans that cools the radiator it prevents the engine from over heating and allows the temp gauge to stay at normal range.recently had problems with my 2003 impala overheating it was the sensor had the thermostat replace as well.
Feb 10, 2010 | 2003 Chevrolet Impala
2001 xtera loosing coolent but don't know where from
These engines had some issues with headgaskets leaking coolant externally. It is a small leak and usually only when hot, so there is no puddle because the coolant evaporates before it gets off of the block.
Get under the vehicle and, using a light, look at the rear face of both cylinder heads. If you see a greenish-white stain, that's the issue. This is a very labor-intensive job and should only be attempted by a qualified technician. I don't know your experience level, so I can't say whether you should try this yourself or not.
If you don't see any staining, a cooling system pressure test would be in order.
If you're located somewhere in central Pennsylvania, I could probably help you out.
Hope this is helpful!
Nissan Scope Technician- 10+ years experience in Nissan dealership.
Oct 29, 2008 | 2001 Nissan Xterra
Fridge not cooling
If you look in the outside compartment do you see a yellowish powder? If you do, or if you smell amonia probably the cooling unit has leaked the coolant. It does not help to add coolant, it will just leak out again quickly. You will need a new fridge or to have the cooling unit replaced. If that is the problem, Dometic has a recall on some models for leaks and will pay for a new cooling unit.
Jun 12, 2008 | Dometic Rooftop RV Air Conditioner
Samsung AW0603B Air Conditioner Logo
151 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
