Question about Dell Computers & Internet
Nec multisync 1940wcxm shuts off about 5 secs after turning it on. there is a good picture and all of a sudden no backlite
  • 40 Answers
SOURCE: monitor power shuts off without warning
You might check the filter capacitor on the power supply and see if it is swelling or shorted.
srich
Posted on May 27, 2008
Rifaa
  • 99 Answers
SOURCE: nec multisync lcd 2080ux no raster no power indicator light.
If u a tech, try checking the PSU of the monitor for blown fuse or dead driver element ( typically a FET, Power transistor or an Hybrid chip) . U need to take the monitor apart, if unfamiliar, get it to a service tech.
Posted on Nov 08, 2008
SOURCE: NEC Multisync 1770gx lcd monitor goes blank when I move the unit
HI
you must to check the volt at pin 1 of the lcd slot screen you'll get about 3.3 volts if not it can be the problem.
Gilson
flipflopme@gmail.com
Posted on Jun 28, 2009
SOURCE: touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
Posted on Jul 04, 2009
  • 120 Answers
SOURCE: The resolution notifier keeps popping up (NEC
It probably is warning you that your video graphics adapator is puting out a non-native resolution to the monitor.
LCD monitors are designed for a specific resolution. If you don't use that resolution, the LCD has to try to mimick the resolution you've asked for.
Check your display settings and also consider updating your graphic driver if a new version is available.
Posted on Oct 13, 2009
NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Steady red status light on NEC VT45 projector. Would not POWER ON. LAMP was replaced with a new one
the power supply on that model seem to go bad after a while. the caps aren't properly reted it's power needs. they dry up. if you are good at soldering, replace c1 on the board (big cap) with a cap that has a slightly higher voltage rating. or replace the whole power supply. you might not be able to get one from nec, but you can try www.projectordoctor.com
Dec 16, 2009 | NEC MultiSync VT45 Multimedia Projector
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Power problem????
Your Secondary Power supply Hot TRansistor is Faulty, Its situated next to the lopt TRansformer to a Heatsink
May 16, 2009 | NEC MultiSync LCD1770V - Flat panel...
NEC MultiSync VT540 not turning on - Temperature error
Hi
if the status light is blinking red in 4 sec interval it means that there is something wrong with cooling system. you shold check if there is a thermostat failure or if there are any switches that are not turned on. i suggest you to open the device (using screwdriver) and check if there are any switches broken or damaged.
i had pretty much the same problem (one second interval). i took off the cover and there was a broken switch and i just short-circuit it and now it works
Sorry for my english
Feb 18, 2009 | NEC MultiSync VT540 Multimedia Projector
Problem with NEC Multisync MT830
Check to see if the fan is running on the bottom of the unit. If it senses no rpm from the fan, if will shut down to protect the unit.
Jun 26, 2007 | NEC MultiSync MT830 Multimedia Projector
Flashing red status light on NEC VT45 projector
make sure the doors are shut all the way! there is a little button there.
Feb 13, 2007 | NEC MultiSync VT45 Multimedia Projector
Computers & Internet Logo
87 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
