Question about Kenmore Washing Machines
Oil leaked out
While i had the machine turned over to change the pump i had oil leak out. is this a problem and if so how do i add the oil back and where?
  • 15,935 Answers
These are normally sealed - with a tiny weep hole to eliminate any pressure buildup.
You'll need to remove the Gear case, and attempt to fill it using a needle etc... the hole is REALLY small - and they are designed so you DON'T have to flip the machine upside-down for service.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Oil Leak and Water Pump Leak
you can check the water pump leak yourself as there is a small drain hole in the lower part of the bearing housing that lets the water leak out if the seal is failed
you will see a stain at this point running down the front of the motor
as for the oil leak you will see moist dust on the motor or oil spots on the floor where you park the car
best advice is to look for yourself, keep an eye on the reservoir for the radiator or check the water level in the radiator at the cap
if you have to add water then replace the water pump
check the oil on the dipstick regularly and if you have to add less that 1 pint every 5000 miles then the leak is of small worry
Find yourself an accredited service shop that is familiar with your vehicle as many mechanical shops to don't have the training necessary to be accredited
Nov 05, 2015 | Cars & Trucks
Why is oil coming out the side of my pump, I just changed the oil and it started doing this? I own a Porter Cable 4,000 PSI.
You didn't state your model number so I don't know exactly which type pump you have. With that; there is no 'oil pressure' in power washer pumps. The internal parts work in an oil bath/splash environment and the pump body is vented, usually at the oil fill cap. Thicker oils and stop leak will only mask the problem and make the pump work harder. Where the oil is coming out is key to the problem. Clean the pump well with something like dish soap to remove all excess oil to find exactly where it's leaking. If it's leaking at a part joint, like the pump body to the valve body or at a bolt, you may have a bad gasket or cracked part. If it's coming out the oil cap a likely cause is there is too much oil in the pump. When oil gets hot it expands and will find a way out. If you have an oil site glass, make sure the site glass is only half full of oil. If it has a dipstick, make sure you have the right dipstick and only fill it to the full mark. Most pressure pumps only need to be half full but that is dependent on your particular pump. If you have it consult your owner's manual. If you don't have the manual you can go to http://servicenet.dewalt.com, search for your model number and see if the manual is still available.
Jan 23, 2013 | Garden
MY IMPALA 2007 LT IS LEAKING OIL GASKET WAS REPLACED TWO MONTHS BACK IT HAD BEEN FINE BUT JUST YESTERDAY OIL PRESSURE LOW SENSOR CAME ON & NOW I NOTICE IT'S HAVING A SLOW WATER DRIP PROBLEM AS
Yes or a small bypass hose. You may be able to get a loan of a tester at autozone, oreilys, or advance autoparts. You want a radiator pressure tester. Do not exceed the cap rated pressure. When the engine is warm, you can add pressure and look for water seepage.
There are also chemicals to add to detect leaks if the first method is unsuccessful.
Mar 29, 2012 | 2007 Chevrolet Impala LS Sedan New Cars
How do I change the oil pump on a 2000 Camry, 2.2L??
For oil pump,oil pump pressure,oil warning light,oil low,oil ewplacing and other car engine oil problems,the help links are provided below.Click the link to go through the procedure :-----Oil light came on and the car died?http://schematicsdiagram.blogspot.in/2012/03/oil-light-came-on-and-car-died.html--------How to replace Oil filler cap or breather cap?http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-oil-filler-cap-or.html---------Oil pouring out from left front of engine?http://schematicsdiagram.blogspot.com/2012/01/oil-pouring-out-from-left-front-of.html------Common Causes of Car Oil Leaks?http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html--------Troubleshoot Car Oil leak?http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html--------Oil change details?http://repairhelpcenter.blogspot.com/2012/01/toyota-highlander-sport-oil-change.html---------Low oil pressure light?
http://howtobyme.blogspot.com/2011/11/low-oil-pressure-light-on-dodge-magnum.html
leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html ----------
Car Turns OFF due to low oil pressure warning light?
http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
For more oil and oil pump details check out the direct links below: ---
How to Replace Oil Pan on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-oil-pan-on-audi-a4-and.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Oil pan Gasket on car?
http://howtobyme.blogspot.com/2011/11/oil-pan-gasket-on-1998-toyota-tercel.html
Oil pressure for car?
http://schematicsdiagram.blogspot.com/2011/12/oil-pressure-for-2001-gmc-jimmy-v6.html
How to replace Oil Pan on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil Pressure Sensor on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
How to replace Oil Pump on car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-oil-pump-on-2008-honda.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil light blinks on dashboard?
http://schematicsdiagram.blogspot.com/2011/12/oil-light-blinks-on-dashboard.html
Oil pressure issues on car?
http://repairhelpcenter.blogspot.com/2012/01/oil-pressure-issuers-on-toyota-tundra.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Wire running from oil pan to alternator?
http://technoanswers.blogspot.in/2012/02/wire-running-from-oil-pan-to-alternator.html
Why car leaks oil from oil filter?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-leaks-oil-from-oil-filter.html
Why engine is consuming lots of oil?
http://schematicsdiagram.blogspot.in/2012/02/2008-scion-xb-24l-engine-is-consuming.html
Maint REQD message on car dash?
http://schematicsdiagram.blogspot.in/2012/02/maint-reqd-message-on-2008-lexus-rx350.html
Remove Sump oil pan?
http://repairhelpcenter.blogspot.in/2012/03/remove-volkswagen-sump-oil-pan.html
Sump not coming OFF?
http://repairhelpcenter.blogspot.in/2012/03/sump-not-coming-off.html
How to remove the sump on car?http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-sump-on-vw-beetle.html----------Car oil sump removal diagram?
http://repairhelpcenter.blogspot.in/2012/03/volkswagen-beetle-oil-sump-removal.html
This will help.
Thanks.
Feb 05, 2012 | 2000 Toyota Camry
1995 dodge dakota truck has no oil pressure
Car oil leak?
This will help.
Thanks.
Feb 04, 2012 | 1995 Dodge Dakota
Greasy oil and water is leaking from under the washing machine?
Hello, the good news is the water is coming from the pump and is easily replaced, the bad news is if you are seeing a yellow oily substance your transmission has a leak and will go bad at some stage soon. The question here you need to ask yourself is do you want to spend $35 on a new pump when your going to need to buy a new washer? If so pull the machine out and puch it back so it leans against the wall umder it's own weight. wedge some thing underneath the washer so you can access the bottom without the washer falling on you. you will see the pump attached to the motor which is attached to the transmission. remove the 2 clips and 2 pipes from the pump, remove the pump and replace it, reassemble in reverse order, you should be able to see where the leak came from the pump at the point where the motor shaft connected to the pump. Also while you are under there look at the base of the transmission, you should see some oily residue where the transmission fluid is leaking. Hope this helps! if you have any other questions please feel free to comment again. Good Luck!! Mike
Jul 21, 2009 | Whirlpool LSR5132PQ Top Load Washer
Pump leaks not to much pressure and when i you the prime pump
Hello rr61
If the pump is leaking you will not get pressure. You need to get the leak fixed. Where is it leaking from?
Leaning back to star and run sounds like the motor oil is low. You are "tricking " the low oil sensor. I would change the oil and be sure it has the correct amount.
Jul 17, 2009 | Briggs & Stratton Garden
My 2004 dodge durango is leaking oil what should I do? Just bought the car 2 days ago from a used car dealer.
Hurry back !! Tell them right away.. Tell them you did not see this the day you got it.. Tell them you want it fixed right away..
In some states you can return the car within 3 days..
Check what your state laws are on auto purchas..
Jul 08, 2009 | 2004 Dodge Durango
My Whirlpool washer LA768M leaks water during the cycle.
Hi, it does sound like a pump but, you should not have oil with it. Tip the washer back against the wall and look underneath to see if there is transmission fluid/oil leaking.
Please let me know and I can assist you with changing the pump.
Thanks
Vic
May 18, 2009 | Whirlpool LSB6200KQ Top Load Washer
Flipped Kenmore over to replace pump now oil leaked out, where?
did you tip the washer all the way over? bad idea if you did. is the washer functioning ok? if so don't worry about it. but no....you cannot put the oil back in. It might be ok as long as it does not leak any more oil. This oil is comeing from your transmission. which controls your agetation and spin.
Mar 26, 2009 | Kenmore 22642 Top Load Washer
Washing Machines Logo
52 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
