Question about Black & Decker CTO100 Toaster Oven with Convection Cooking
Cook's all in one ultimate oven lot no. 2128
All three heating elements ( two are in back for rottisetrie, and are special kind) quit heating after 1 1/2 years of light service! All fans, motors and lights still work. I can't find any kind of fuse, and the manual is no help! I can't find a small appliance place that will work on it! I paid 200.00 dollars on sale, normal price was 400! It is now discontinued!
  • gsnack Jun 17, 2009
    gsnack on Jun 16, 2009
    Their is no way all three elements went out at the same time, two of them are special, and only come on with the rottiserie. I was hoping there is a fuse, thermostat etc problem, that you guys may know about!!
    President:
  • 2,187 Answers
It may be a bad fuse or wiring problems or a bad switch.
The thermal fuse of ovens may be located at any of the following places:
  • Under the cooktop
  • Back of the oven, behind a cover
  • Somewhere around the vent tube or a similar pipelike construction
It looks like a round device with 2 wires connected and may or may not have a reset button. If it does, just press it and you should be good to go.
If it still does not work after checking the fuse out, you may want to trace the wires for loose connections.
Posted on Jun 17, 2009
    Genius:
  • 1,341 Answers
I suggest you remove the elements and test it with an electronic meter,if faulty then replace the element which you can easily find on ebay.Hope this helps..
    President:
  • 2,923 Answers
The oven toaster's heating element can be replaced. Here are some links that will help you.
* How to repair a toaster oven:
http://home.howstuffworks.com/how-to-repair-small-appliances2.htm
* Fixing Toaster Ovens:
http://www.bobvila.com/HowTo_Library/Fixing_Toaster_Ovens-Oven-F2188.html
* Heating elements:
http://www.globalsources.com/manufacturers/Oven-Heating-Element.html
* Possible repair shop:
http://www.yelp.com/topic/san-francisco-repair-shop-for-small-appliances-toaster-oven-cheap
Hope the information helps and have a great day!
Black & Decker Toaster Oven - elements cycle on and off, which makes for a SLOW cook.
Oven has three modes: 1) oven mode cycles elements on and off to maintain a specific temp setting for up to 60 min. 2) toast should keep all elements on for a few min. 3) broil mode top elements only always on, up to 60 min. Make sure you have dials in correct position and use the toast timer.
Apr 17, 2014 | Toaster Ovens
Need Cooks ultimate oven model #2128 instructions
Yea, I need one of those as well! I have searched high and low for one, and haven't had any luck! The only thing I did find, was a really good website for receipes!! Cooks com Recipe Search and More
Sep 20, 2013 | Black & Decker CTO100 Toaster Oven with...
HEATING ELEMENTS
The heating elements are inside on the top and bottom
Jun 08, 2013 | Bella Cucina 13049 1500 Watts Toaster Oven...
Heating units bottom stopped working. Then the top heating bars stopped working. It's a radiant oven.
it is several prosibilites for your problem:
1) the wire of the oven is damaged;
2) the thermostat is decalibrated or damaged;
3) one or more heating element is intrerupted or burned.
solution's:
1) check the wire an replace or repair where is posible whit similar heat resistant wire;
2) replace the thermostat whit similar one;
3) replace the heating element
Feb 21, 2010 | Oster 6239 Toaster Oven with Convection...
Bottom elements on DeLonghi AD699 failed.
Solution: buy a new toaster oven. I determined that the manufacturer stopped selling replacement heating elements in 2006, three years after the model year (2003). After market parts makers don't sell the elements for safety and liability reasons. So I got a new one.
Nov 17, 2009 | DeLonghi AD699 Airstream Digital 1500...
Rival to606 temperature control doesnt work, unit doesnt heat up
The heating bar or element needs replacement.you can find it in electrical shop or electronic and electrical supplies in your area.
If you find this answer helpful, kindly vote it.
Nov 09, 2009 | Rival TO606 1500 Watts Toaster Oven with...
Oven does not cook at temperature set at. 2 hrs.
Could be the gasket is not sealing in the heat and you are experience heat loss through the door. Does it seal tightly? Can you feel heat coming around the door area? If so, replace the gasket
Nov 05, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Parts for ge 168947
I have three heating elements available.
Contact me direct at:
tlowery@pobox.com
Dec 23, 2007 | GE 168947 Toaster Oven with Convection...
Heating elements
I think this is a common problem with these kind of toaster ovens. Mine isn't a Toastmaster - mine is Cook's Essentials (from QVC), and my upper elements have also warped and split, although mine are curved downwards.
Dec 12, 2007 | Toastmaster 328 Toaster Oven with...
Black & Decker CTO100 Toaster Oven with Convection Cooking Logo
1,100 people viewed this question
Top Black & Decker Toaster Ovens Experts
Steve
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
